This thread is privately moderated by simo10, who may elect to delete unwanted replies.
Old Jun 05, 2007, 11:09 AM
simo10 is offline
Find More Posts by simo10
Trader Rating: 2
Planes from 1oz to 55lb's
simo10's Avatar
USA, FL, Orlando
Joined Aug 2004
Trader Rating: 2
Sold
VIPER 500: quickie 500 pylon racing plane with servos, batt, and switch.
Hello,
I have a great planes Viper 500 for sale. It is a quickie 500 class plane which can be used to pylon race. it is AMA legal for quickie 500 races.
It includes:
2 futaba s3003 servos - $20
1 high torque, high speed Hitec HS 605BB - $35
1 Hobbico CS 61 $10
1 futaba switch harness $8
1 Custom 4 cell AAA 700MAH battery $10
Original plane cost $120
total original cost $203+work+shipping
Detailed specs:
Wingspan: 52" (1320mm)
Wing Area: 504 sq in (32.5 sq dm)
Weight: 3-3.4lb (1360-1530g)
Wing Loading: 13.7-15.4 oz/sq ft (42-47 g/sq dm)
Length: 41.25" (1048mm)
Airfoil: Selig Center of Gravity: 3" (75mm) Back from the wing's leading edge at the fuselage sides.
Control Throws- Low Rate High Rate Ailerons: Up & Down 1/8" (3mm) 3/8" (9.5mm) Elevator: Up & Down 1/8" (3mm) 1/4" (6mm) Rudder: Right & Left 1/4" (6mm)
You only need an 25-50 size engine and an RX!
The plane is used with few flights. The landing gear mount was reinforced after it buckled a little bit.
It has a laminate composite wing made of foam, fiberglass, and wood sheeting covered in monokote. It also has a removable tail and landing gear.
I am asking $135 Shipped!
Paypal or money order are accepted, UPS shipping will be used, tail and landing gear will be removed for shipping (they are removable)
Thanks for looking,
simo10
simo10 is offline Find More Posts by simo10
For Sale JR Racing XR3i with servos Stealth Assassin Boats (FS/W) 0 Mar 13, 2007 08:42 AM
Sold RTF plane w/servos and batt $20. shipped Butch777 Aircraft - Electric - Airplanes (FS/W) 2 Aug 04, 2006 08:37 PM
Sold L-39 Albatross Albatross PSS Jet With Servos and Batt Z06kal Aircraft - Sailplanes (FS/W) 4 Feb 25, 2006 02:24 AM
Pylon type plane with a .25 instead...? dephela Fuel Plane Talk 2 Jan 01, 2004 08:48 AM
Quickie 500 with an Astro 605g....Rock and Roll!!!!!!!!! Advice needed with diet. mrtim Power Systems 3 Jul 24, 2001 08:53 AM
