Old Jun 04, 2007, 10:57 AM
capn is offline
Find More Posts by capn
United States, CA, San Diego
Joined Sep 2005
Question
Use of Omnidirectional 2.4 ghz antenna?
Has anyone used an omnidirectional antenna like the one listed below on a diversity receiver? I am curious because I was thinking of trying one of these along with one of the 12dbi patch antennas that I got from FutureHobbies.
http://www.hyperlinktech.com/web/hg2412u.php
Maybe this isn't even necessary? I'm going to be using the FutureHObbies 1W transmitter along with their diversity setup. I thought that maybe a good compromise between distance and range would be a bigger omni like the one above used in conjunction with the high-gain vertical/horizontal polarized patch antenna.
What do you guys think?
capn
capn is offline Find More Posts by capn
Old Jun 04, 2007, 11:43 AM
JettPilot is online now
Find More Posts by JettPilot
JettPilot's Avatar
Miami
Joined Apr 2005
The omni will work close in, so you do not have to aim the patch, that will give you both good long and short distance video.
I standard vertical and a patch will also work very well on a diversity receiver for the same purpose. The vertical would give you a little better medium range as it has gain to the sides. The omni might give you a very slight less dropouts in very close range than the standard vertical, so if super clean production quality video while you are close in the pattern is important to you, the omni might be worth the extra money. If you want good medium and long range, I would use a vertical antenna with the patch instead of omni.
JettPilot
JettPilot is online now Find More Posts by JettPilot
Site Sponsor
Old Jun 04, 2007, 12:20 PM
twinturbostang is offline
Find More Posts by twinturbostang
Fly FPV, sleep; repeat
twinturbostang's Avatar
United States, MD, Hagerstown
Joined Mar 2006
I have used an omni in conjunction with a patch on a diversity setup. Works quite well for short range flying around, and longer range in a particular direction.
The antenna you linked to might not be a good candidate though due to the gain. Omni's have 360 degrees of coverage, but as you go higher and higher with the gain, you loose vertical range. Someone else gave a good example once.... think of it as a doughnut. As the gain increases, you flatten the doughnut some. So you get farther range to the sides, but less above (or below) you. Take a look at the gain patterns on that link and you will see what I mean. It's pretty flat.
twinturbostang is offline Find More Posts by twinturbostang
Old Jun 04, 2007, 01:04 PM
Kilrah is offline
Find More Posts by Kilrah
Happy FPV flyer
Kilrah's Avatar
United Arab Emirates, Dubai
Joined Sep 2006
Yes, if you check the diagram the vertical beamwidth it 8... and half of that being in the ground! An omni in conjunction with a patch is good, but stay with a 0-3dB omni and use it when you're close.
Kilrah is offline Find More Posts by Kilrah
Old Jun 04, 2007, 01:36 PM
zaguruinzasky is offline
Find More Posts by zaguruinzasky
Smoke on , go !
zaguruinzasky's Avatar
Verona - Italy
Joined Jan 2007
you're right Kilrah, the vertical range is very poor:
zaguruinzasky is offline Find More Posts by zaguruinzasky
Old Jun 04, 2007, 01:38 PM
Smoke on , go !
Verona - Italy
Joined Jan 2007
what is the best combination (if any) of antennas with a diversity receiver to have omni directional capability? a couple of 3db omni? if yes with same angle or.. ?
Old Jun 04, 2007, 02:25 PM
capn is offline
Joined Sep 2005
Thanks guys! So I should just stick with the standard omni that came with the Futurehobbies setup? I could just use one of the 12dbi patches in that case, along with the small whip.
This brings up another question...should I go with vertical or horizontal polarization with the patch? Also, what exactly is the difference between vertical and horizontal polarization?
Old Jun 04, 2007, 03:22 PM
Kilrah is offline
Happy FPV flyer
Kilrah's Avatar
Joined Sep 2006
Vertical or horizontal is the same antenna, just turned 90
If your TX antenna is vertical most of the time, install the RX one it vertically, etc so they use the same polarization.
I just come back from flying with 8dBi patch and standard whip, I like this a lot as I'll be able to still have very good range alll around as the whip is already good for a few hundred meters. If I want to fly far, then I'll go where the patch points.
Old Jun 04, 2007, 04:13 PM
Smoke on , go !
Verona - Italy
Joined Jan 2007
That's what I was thinking about, where do I find a diagram of the standart whip ?
Thanks!
Old Jun 04, 2007, 11:50 PM
jmendell is offline
Find More Posts by jmendell
Awesometown
jmendell's Avatar
Boston, MA
Joined May 2007
Don't use anything more than 8dbi on an omni, the beam width is ridiculously low, you'd have 7-10degrees to work with, its like a pancake.
jmendell is offline Find More Posts by jmendell
Question Futaba 6EX-2.4 Ghz FAAST R606FS ReceIver Antenna rckowal Radios 6 Aug 19, 2008 11:18 AM
2.4 ghz better antenna? pdemon Aerial Photography 2 Dec 08, 2005 11:37 PM
Video Link Antenna 2.4 Ghz JettPilot UAV - Unmanned Aerial Vehicles 2 May 23, 2005 01:32 PM
Found WTB 8dbi Patch Antenna for 2.4 ghz gizmointhesky Aircraft - Electric - Airplanes (FS/W) 0 Mar 09, 2005 05:22 PM
Question 2.4 GHz 30dB Audio and Video Compatible Amplified Receive Antenna johnsloper Aerial Photography 13 Dec 03, 2004 12:20 PM
