It's hard to believe that the one extra battery makes that much difference in weight.
I tried the 11.1 3 cell on the Sabre, and well, it flew great a few times. It would take off at about half throttle. I had just glued the head set solid, then I loosened it on the bearing with some mineral oil, and it was hovering and responding better than ever. It was on the kitchen table. Any way, one time it was getting too close to the edge, so I set it down, and it fell off the side, and that was it. When I picked it up, the main blades where trying to spin. As I tried to disconnect the battery, I got that famous white smoke. Everything still works but the main motor. Only the IC, or FET I guess from what I've read, is all that is bad. Here is a thought, maybe it would be possible to use an 11.1 LiPo if you put a resister on it to bring the voltage down to about 8-9 volts. I have a bunch of different resisters here. I am going to see if I can find one that will do this. I'll post my findings later. |
So far, on the resistor with the 3 cell LiPo, it's at about 350K-425K ohms that looks like it would put it around 8.4-9.?. I just need to find one that can handle the 10C battery (max 12C for a few seconds) that I have. Maybe I wouldn't have blown my RX in the Sabre if I was using my 8C LiPo? Does anyone know if this would have been enough to make the difference? Or is it still just too much voltage? |
| Thread Tools | |
| why does my heli pull so hard right? | night_flight | Micro Helis | 16 | Feb 29, 2004 02:58 PM |
| Why does my S-400 get so hot? | tradernfl | Power Systems | 16 | Dec 12, 2003 01:26 AM |
| Why does my foamie "tip-stall" with winglets? | thwang99 | Foamies (Kits) | 1 | Jul 17, 2002 06:37 AM |
| Why does Channel 60 not work on my plane? | RPatrick | Power Systems | 8 | Jun 17, 2002 01:03 AM |
| Why does my motor not stop???? | Hammer | Electric Plane Talk | 4 | Jun 18, 2001 03:13 PM |
