Old Jun 03, 2007, 04:16 PM
stereotype is offline
Find More Posts by stereotype
Joined Oct 2006
Sensitive drill press
I've been looking for a sensitive drill press for ages to use in my hobby of clock making, the FEW i've seen are all 3 phase and the motor an integral part of the machine (so a motor change is not on), were their ever any single phase ones made ? David
stereotype is offline Find More Posts by stereotype
Old Jun 03, 2007, 04:50 PM
Tom
Tom
Guest
n/a Posts
Re: Sensitive drill press
Yes, also machines with separate motors, but your whereabouts may
determine which makes may be available.
Tom
Posted via a free Usenet account from http://www.teranews.com
Old Jun 03, 2007, 04:55 PM
Scruff
Scruff
Guest
n/a Posts
> stereotype
> stereotype's Profile:http://www.rcgroups.com/forums/member.php?u=119209
> View this thread:http://www.rcgroups.com/forums/showthread.php?t=694661
I have an old 1/4" Jones and Shipman sensitive bench drill that's been
converted to single phase. Uses an ordinary foot mounted motor.
A point that I would raise is that a lot of the commercially built
sensitive drills - AREN'T!!!
My little J&S (and a pretty similar Meddings that we had at work) uses
a rack and pinion feed for the quill just like a conventional bench
drill. Not really sensitive enough for the really fine stuff, for
which a lever action feed would be better.
Probably the best advice I could offer is to consider building a
George H. Thomas universal pillar tool, as covered in his "Workshop
Techniques" book. The kit is available from Hemmingway, here:
http://www.hemingwaykits.com/acatalo...llar_Tool.html
Cheers, Scruff.
Old Jun 03, 2007, 08:58 PM
DCreed is offline
Find More Posts by DCreed
Joined Sep 2006
Its like the old saying, its not what you have but how you use it, i have 2 drills side by side, one is high speed, one is low speed, both are eastern imports, i have drilled .5mm with the high speed free hand with no problems and the other takes care up to 1/2inch dia, Dave
DCreed is offline Find More Posts by DCreed
Old Jun 04, 2007, 12:22 PM
steamer
steamer
Guest
n/a Posts
--Here's a link to the one I've got:
http://www.cameronmicrodrillpress.com/
--Nice company, good people, good product.
"Steamboat Ed" Haas : I still miss
Hacking the Trailing Edge! : rock and roll...
www.nmpproducts.com
---Decks a-wash in a sea of words---
Old Jun 04, 2007, 03:19 PM
Bob Minchin
Bob Minchin
Guest
n/a Posts
"stereotype" <stereotype.2rmd4n@rcgroups.com> wrote in message
news:stereotype.2rmd4n@rcgroups.com...
> stereotype
> stereotype's Profile: http://www.rcgroups.com/forums/member.php?u=119209
> View this thread: http://www.rcgroups.com/forums/showthread.php?t=694661
A three phase motor on a small drill is not automatically to be rejected.
Check that the motor is marked 240/440 volt. It should have six terminals
under a cover plate. Wire this as delta mode 240 volt.
connect two of the terminals to 240 live and neutral and an 400vAC rated
capacitor between the third terminal and one of the others. The value of the
capcitor should be about 40mfd/hp of the motor.
You possibly have to spin the chuck to start the motor but it should run OK.
hth
Bob
Old Jun 05, 2007, 04:34 PM
DCreed is offline
Joined Sep 2006
There is a guy on youtube who shows his small drill, it looks a realy useful tool, Dave
Old Jun 06, 2007, 12:17 PM
steamer
steamer
Guest
n/a Posts
--Here's a link to a photo of a widget I made, to get more sensitive
feel when using a milling machine to drill tiny holes. Something like it
would work equally well on a drillpress.
http://www.nmpproducts.com/feedlevr.htm
"Steamboat Ed" Haas : Mostly somnambulent,
Hacking the Trailing Edge! : occasionally brilliant...
www.nmpproducts.com
Old Jun 07, 2007, 11:33 AM
Scruff
Scruff
Guest
n/a Posts
> would work equally well on a drillpress.http://www.nmpproducts.com/feedlevr.htm
> www.nmpproducts.com
Steamer, I'd forgotten about that sort of attachment. There are plans
on chris Heapy's site (archived here:http://tinyurl.com/29ffp6) for a
similar one. It's a few items down on the workshop projects page. It's
a pretty handy looking thing. Hopefully I'll get round to making one
eventually.
Cheers, Scruff.
Old Jun 07, 2007, 12:20 PM
David Littlewood
David Littlewood
Guest
n/a Posts
In article <4666de04$0$14121$742ec2ed@news.sonic.net>, steamer
<steamer@sonic.net> writes
Myford sell a similar one for use in the tailstock of the 7 series
lathes.
David
David Littlewood
Old Jun 07, 2007, 02:08 PM
Dave A
Dave A
Guest
n/a Posts
Handy. What method did you use to provide the rotational drive to the
chuck as it slides up and down, please?
Dave
Old Jun 08, 2007, 12:08 PM
steamer
steamer
Guest
n/a Posts
--Ah. It's store-bought and modified. I think it's just referred to
as a "sensitive drill attachment" or some such. It consists of a Jacobs #0
chuck on a stem that slides inside a 1/2" rod. It's got a spring to retract
it and the back of the chuck has a bearing with a ring pressed onto it. To
operate the ring can be grabbed and used to push the chuck down into the
work. My widget fastens onto this ring, then provides a lever a little
farther away. Will check the big catalog and get back with a part number.
www.nmpproducts.com
Old Jun 08, 2007, 12:25 PM
steamer
steamer
Guest
n/a Posts
--Yeah, found 'em in a couple of catalogs. Travers Tool has
something called "Accu-Driller" 'sensitive hand drill' and they sell them
for as little as $54.60, but one with a decent chuck costs about twice that.
Their part number for this one is 63-003-205. In the Rutland catalog it
"Hand drill feed with chuck", model# 5000 2200 for $115.11
Hope that helps!
www.nmpproducts.com
Old Jun 10, 2007, 12:22 AM
Dave A
Dave A
Guest
n/a Posts
> Hope that helps!
Thanks. I'll have a look at those.
Dave
Small drill press recommendations? TMorita The Builders Workshop 6 Jan 19, 2003 10:53 AM
FS:Dremel 395 mototool, and 212 drill press bmwbob Aircraft - Electric - Airplanes (FS/W) 1 Jul 12, 2002 05:48 PM
Unimat/Taig Micro lathe/drill press/milling Bleriot Electric Plane Talk 5 Feb 18, 2002 11:14 PM
Unimat?taig Micro Lathe/drill Press/milling Bleriot Parkflyers 9 Feb 16, 2002 08:08 PM
