Go Back   RC Groups > Aircraft - Electric - Airplanes > Giant Electric Planes
Old Jun 03, 2007, 12:44 AM   #1
ILoveInn
BoneDoc's Avatar
Send a message via AIM to BoneDoc Send a message via Yahoo to BoneDoc
The 35% Dalton Aviation Extra 260 19.2 lbs Build, Fly, .... and Repair thread
Hi Guys,
As a few of you might know, my wife and kids are out visiting their relatives in Indonesia for a full 2 months. Meanwhile, I have to find something to do otherwise, I'd go nuts .
So I've always been impressed with large E-Conversions. However, most are converting ARFs designed for gas, and I'm not about to fork out the electron's version of a 100cc engine.
Enter Bob Sawyer. On this thread in FlyingGiants.com, he actually took a 40% Carden 260 all the way down to 28 lbs, equipped with DA 100. Many thought the plane would not fly, or break at the first snap. Yet to this day, he's had 40 pretty hard flights of it without any signs of wear or fatigue.
So my mind start churning. What if I can take a 35% plane and take it all the way down to 20 lbs, and use the available powerplant that most people here are overpowering their 50cc conversion with? I have a 110 HV already, so I just need battery and motor.
Since there are no ARFs out there that comes even close to 20 lbs with standard setup, I have to resort to a kit. Enter Dalton Aviation's Extra 260. Many raves about its flying qualities as well as overall IMAC / 3D performance, so 814 dollars later, I'm off to the most ambitious project I've ever tackled. The most I've done in terms of building is a SA Edge 540. Any of you SA owners / builders out there, there's no plane that will fly as well / light as an SA. Likewise, properly built, I should be able to nail this down.
Wish me luck .
BoneDoc is offline Find More Posts by BoneDoc   Reply With Quote
Old Jun 03, 2007, 12:47 AM   #2
Koolaid Junkie
NumbSkull's Avatar
Good luck Josh!!
Cant wait to see how this works out for ya!!
NumbSkull is offline Find More Posts by NumbSkull   Reply With Quote
Old Jun 03, 2007, 01:27 AM   #3
God is my co-pilot.
sun.flyer's Avatar
This should be a fun project to watch. I am assuming Josh you will be doing a build thread on this as well? Looking at the manual it definately looks like there is the opportunity to take out some weight on it without compromising the structure.
Ditto on Numbs comment, Good luck Josh!!
Tim
sun.flyer is offline Find More Posts by sun.flyer   Reply With Quote
Old Jun 03, 2007, 02:37 AM   #4
ILoveInn
BoneDoc's Avatar
One of the neat concept that Bob taught me is the idea of "weight budget." Come to think about it, since it makes sense to budget our finances, time, etc, why not budget the weight? Bob has kindly given me the realistic budget to hit (since I have zero experience with this).
Fuselage 40 ozs.
canopy complete 10 ozs.
Tail feathers 20 ozs.
Engine cowl with topcoat 12 ozs.
Carbon wheel pants and landing gear with
Titanium axles & Kavan wheels 16 ozs.
Tail gear 1.5 ozs.
Carbon wing tube 5 ozs.
Wings 64 ozs.
Carbon spinner 4 ozs.
Prop 6 ozs.
Servos 16 ozs.
Battery and switch 4 ozs.
Receiver, hardware and extensions 17 ozs.
Covering 12 ozs.
Graphics 3 ozs.
Total 14.406 lbs.
That will leave me 6 lbs for the power system. I'm considering 12S 5000 mah setup mated to a 2 lb motor, which will give 4000 watts. That's 200 watts / lb, not as "crazy" as some of these models, but definitely plenty.
Old Jun 03, 2007, 04:56 PM   #5
Site Sponsor
blucor basher's Avatar
Josh -
Awesome. Glad you decided to jump into this one head first.
When do you expect to finish?
blucor basher is online now Find More Posts by blucor basher   Reply With Quote
Old Jun 03, 2007, 09:32 PM   #6
ILoveInn
BoneDoc's Avatar
It has to be done before July. My 2nd year start in July, and then I'll be too busy to do anything meaningful (RC related at least ).
Old Jun 04, 2007, 04:17 AM   #7
ILoveInn
BoneDoc's Avatar
Ok, so here is where I am right now.
I've framed up the fuse, sheeted the turtle deck, and sheeted both elevator / H Stab. Not bad for several day's worth. And in the process, I've removed over 1/2, probably closer to 3/4 lbs altogether.
Here are some pics.
  • Name: PIC_0008.jpg
Description: Fuse framed and lightened Fuse framed and lightened 66.2 KB · Views: 677
  • Name: PIC_0009.jpg
Description: Another view, please pardon the mess : ). Another view, please pardon the mess : ). 64.5 KB · Views: 535
  • Name: PIC_0011.jpg
Description: Lightening holes galore Lightening holes galore 57.1 KB · Views: 515
  • Name: PIC_0012.jpg
Description: Pieces sawed off (not including holes from drilling) Pieces sawed off (not including holes from drilling) 40.8 KB · Views: 475
  • Name: PIC_0013.jpg
  • Name: PIC_0017.jpg
Description: tail.  Don't worry, I added some braces to strengthen the phenolic. tail. Don't worry, I added some braces to strengthen the phenolic. 34.1 KB · Views: 501
  • Name: PIC_0018.jpg
  • Name: PIC_0019.jpg
Description: Tape the sheets together first. Tape the sheets together first. 17.9 KB · Views: 435
  • Name: PIC_0021.jpg
  • Name: PIC_0022.jpg
  • Name: PIC_0024.jpg
Description: 2 lbs, 2 Oz... not bad 2 lbs, 2 Oz... not bad 40.2 KB · Views: 464
  • Name: PIC_0025.jpg
Description: Side sheeted.  I can't believe how sheeting the side alone (TD not glue yet), really adds a lot of rigidity.  This plane is solid now.  Even if you go gasser, it'll hold Side sheeted. I can't believe how sheeting the side alone (TD not glue yet), really adds a lot of rigidity. This plane is solid now. Even if you go gasser, it'll hold 28.1 KB · Views: 592
  • Name: PIC_0028.jpg
  • Name: PIC_0029.jpg
Description: Just hit the mark of 40 Oz.  Goal met.  There are some lightening holes to be done still.  I have not removed some weight from the LG plate and motor box. Just hit the mark of 40 Oz. Goal met. There are some lightening holes to be done still. I have not removed some weight from the LG plate and motor box. 25.0 KB · Views: 517
Old Jun 04, 2007, 09:14 AM   #8
Site Sponsor
Impressive!
Old Jun 04, 2007, 09:23 AM   #9
God is my co-pilot.
sun.flyer's Avatar
Sweet looking good Josh. Looks like one Giant sized SA kit thats for sure. What motor/esc are you planning on using?
Tim
Old Jun 04, 2007, 12:06 PM   #10
mexico's Avatar
subscribed
What does this mean? "I have not removed some weight from the LG plate and restaurant."
mexico is offline Find More Posts by mexico   Reply With Quote
Old Jun 04, 2007, 01:42 PM   #11
ILoveInn
BoneDoc's Avatar
Lol, it was 3:17 am when I posted that message. I must be half asleep.
What I meant was LG plate and motor box. There's at least 2 Oz to be had by lightening them.
Old Jun 04, 2007, 01:55 PM   #12
mexico's Avatar
I guess we now know who does the cooking in your house.
Old Jun 04, 2007, 02:32 PM   #13
Koolaid Junkie
NumbSkull's Avatar
Looks great Josh..
Any chance you take a shot of the fuse by that extra 330 so that we can get an idea of the size of this bird?
Old Jun 04, 2007, 02:40 PM   #14
mexico's Avatar
35% Extra 260 should be just over 100" I think.
Old Jun 04, 2007, 02:47 PM   #15
God is my co-pilot.
sun.flyer's Avatar
Dalton Aviation
WS=103"
Tim
Build Log Funtana 1.40 - Build and Fly Thread: Part 2 Harley Sport Planes 528 Sep 25, 2009 01:46 AM
Discussion Costruccion De Extra 260 42% De Dalton Aviation RICHARDCAMBEROS Mexico 104 Aug 30, 2007 04:12 PM
Question any build/fly tips for the GWS BN-2 Islander? kahuna_socom Foamies (Kits) 0 Apr 16, 2005 05:01 PM
35% Pirate Extra 260 For Sale jlovitt Aircraft - Fuel - Airplanes (FS/W) 0 Oct 06, 2003 11:04 PM
Extra 300S by DAW, anyone Build and fly this plane? War Bird Radio Sport Planes 11 Jul 30, 2003 04:38 AM
Congratulations SimpleM!
