Old May 16, 2001, 01:19 PM
Chris True is offline
Find More Posts by Chris True
St. Mary, Maryland, United States
Joined Dec 1996
Couple issues that might lead you to choose a softer Kv motor. Do you ever want to run more than 8 cells? That motor would be well over 40K on 10 cells which is a little fast IMHO.
The other thing is what is the no-load current on that motor? I don't know, but generally it gets higher as the Kv goes up and may be in the range of 3.5-4 amps. If you are only running in the low to mid 20 amp range then a motor with such a high Io (no load current) is not desireable, the extra couple amps just goes to heat.
I think there is a 500-27 which should be OK with a 22 or 24 tooth pinion. You possibly would need to make up a new motor mount plate though. I'm in the process of installing an Aveox motor with a Kv of just under 2600 in my Voyager. I got it installed last night with a 22 tooth pinion and ran it up without the main rotor blades attached, full throttle was 1800 head speed on 8 cells so i think with the blades on it will be in the 1600-1700 range which should work.
Why run it with no blades? Cause I started going through a freeing up the ball links using the squeeze technique and promptly broke 2 out of three! I'm waiting for replacement links now as well as the sizing tool, hopefully they will arrive in the mail today. Incedently it takes 60-75 watts to turn the mechanics and tail rotor at 1600 rpm and hover pitch on the tail. I started at 75 and then got it to go down to the 60-65 range by lossening the belt tension some.
FWIW, I am not too experienced at Heli's but have 20 years E-flight experience and know a thing or two about motors...
Chris True is offline Find More Posts by Chris True
Old May 17, 2001, 12:25 AM
e-heli is offline
Find More Posts by e-heli
San Francisco, CA USA
Joined Sep 2000
Kontronik FUN-series motor in Voyager E?
Has anyone tried using the new Kontronik FUN-series brushless motor in the Voyager E?
I realize everyone has been using the Hacker B40-9L or similar, which has a Kv of 3750 rpm/volts. But I want to try a Kontronik motor because I really like the other Kontronik equipment I have (very high quality).
I was thinking of the FUN 500-48, which has a Kv of 4800 rpm/volt. With a 15 tooth pinion, that is 1800 RPM head speed (approx.) with 8-cells at full throttle. It is slightly heavier at 185g vs. 175g.
Thanks in advance for any response.
--Anil
e-heli is offline Find More Posts by e-heli
Old May 17, 2001, 01:22 AM
Steph280 is offline
Find More Posts by Steph280
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
One advice: dump those JR links. JR makes good helis, but those links are horrible. People have been complaining about them since the first Ergo came out. They break easy when squeezed, and will not seat correctly without manual resizing using JR's tool.
I have built various helis in the past, and the best links are the ones from Kalt. They are white in color, and will fit onto JR's balls. I am using them on my Voyager (and all other helis). The black ones on Thunder Tiger Raptors are great, too.
Sorry to be off topic. I have responded to Anil's post on Voyager list. Kontronik motors are made by Hacker so no problem with quality.
Steph280 is offline Find More Posts by Steph280
Old May 17, 2001, 04:38 AM
Michael Franz is offline
Find More Posts by Michael Franz
Germany, Rottenburg
Joined Jan 2000
Wrong!
Michael Franz is offline Find More Posts by Michael Franz
Old May 17, 2001, 07:58 AM
gpeden is offline
Find More Posts by gpeden
-Flight enthusiast_
gpeden's Avatar
Lake Louise, AB, Canada
Joined Feb 2000
Michael, since you are undoing what is often repeated as "common knowledge" "over here", could you elaborate a bit? Are they the same motors? Does Kontronik make Hacker motors?
You weren't refering to the off-topic part, right?
Cheers!
Glen
gpeden is offline Find More Posts by gpeden
Old May 18, 2001, 12:17 AM
Germany, Rottenburg
Joined Jan 2000
No
Discussion Align Brushless Motor in Voyager E? tdriedger Electric Heli Talk 14 Jun 01, 2006 06:16 PM
Mega Brushless Motor in a Voyager??? Coyoteair Electric Heli Talk 5 Aug 08, 2002 02:42 PM
IPS vs. EDF motor in an E box MKH Parkflyers 8 Jul 10, 2002 11:20 AM
Kontronik Fun-400-36 in a ProJeti Tim H. Foamies (Kits) 5 Jun 11, 2002 04:15 PM
aveox b/l motor for Voyager e Antyoo Electric Heli Talk 8 Nov 29, 2001 11:00 PM
