This particular ASW 28 is already a fairly heavily loaded model as it is, Its flys fast but it is predictable .Adding more weight will make it faster and harder to land without any aero dynamic braking system in place. the foils section would be the same as the Salto and the DG1000 that being an Eppler 205 for polars check a program call Profili. The data that comes in the box is very basic indeed consisting of a small drawing of the model and where parts fit together and thats it. Good luck and have fun.
SteveW |
Latest blog entry: 4 days
A word of warning, if you are using Flaperons meaning your Aileron deflect down when applied then you maybe in for a shock as your roll control will be reduced to nothing so picking up a low wing on approach could give you a heart attack ,also using ailerons as flaps forces an aerodynamic washin on the wings increasing the risk of tip stall at low airspeeds. My advise is to land clean a long flat approach into wind will be the answer.
On the other hand if you use the ailerons as spoilerons eg they deflect upward they will increase the decent rate but does have a small effect on airspeed due to the drag they create, but on this model it also make the wings tuck down when applied which can cause a more rapid arrival than planned. Of course you can choose to ignore this and find out through your own experience ![]() SteveW |
| Thread Tools | |
| HF models ASW-28 3M | soaringMoe | Scale Sailplanes | 7 | Aug 21, 2003 04:49 PM |
| Asw-27, Asw-28, 82" | Carter | Scale Sailplanes | 14 | Aug 03, 2003 11:39 AM |
| EMS ASW 28 3m | Radek Z | Thermal | 15 | Jul 29, 2002 12:58 PM |
| NSP's ASW-28? | Ben74 | Slope | 5 | Jun 06, 2002 11:41 AM |
