Old Sep 05, 2010, 08:27 AM
Damian Couzoff is offline
Find More Posts by Damian Couzoff
Damian Couzoff's Avatar
Melbourne,Victoria,Australia
Joined Apr 2010
.I am also waiting on a reply from the seller,of a multiplex ASW 27b-2.6 metre.Its got all radio installed and has flaps,only thing to add is my receiver.Hoping he gets back to me,so l can purchase it, for a bargain price.It has alot more wing area than my ASW 28-2.6 metre,the wingloading would be alot lower-good for thermal or slope.Heres my ASW 28-regards damo
Damian Couzoff is offline Find More Posts by Damian Couzoff
Last edited by Damian Couzoff; Sep 05, 2010 at 08:32 AM. Reason: CMPRO SPOILERS ADDED FOR SLOPE.
Old Sep 05, 2010, 03:45 PM
Heathy is offline
Find More Posts by Heathy
Heathy's Avatar
Wiltshire England
Joined Aug 2010
I'm now at the throw setting stage, i read about 8mm of up elevator in a earlier post, where is this measured from?
Is it from the inside edges or outside?
Also, is it o.k to have the rudder at max deflection?
Heathy is offline Find More Posts by Heathy
Old Sep 05, 2010, 04:52 PM
steve wenban is offline
Find More Posts by steve wenban
Crikey never leave beer behind
steve wenban's Avatar
Mt Annan Sydney Australia
Joined Dec 2003
Rudder as much as you can get it wont hurt that 8.0mm elevator throw is maximum thats up and down deflection measured from centre best to start with 6.0mm up and down preferably. Set the 2 throws on a rate switch and launch with the lower settings.
SteveW
steve wenban is offline Find More Posts by steve wenban
Old Sep 05, 2010, 04:56 PM
Joined Dec 2003
Have you flown yours yet Damo??
SteveW
Old Sep 05, 2010, 05:14 PM
Heathy is offline
Heathy's Avatar
Wiltshire England
Joined Aug 2010
Thanks again Steve,
This babys needing alot of lead up front, going to have to buy some more!
Old Sep 05, 2010, 05:19 PM
Joined Dec 2003
yeah they take a fair bit to balance.
SteveW
Old Sep 05, 2010, 05:22 PM
Heathy is offline
Heathy's Avatar
Wiltshire England
Joined Aug 2010
Steve, can i just ask quickly about the small amount of wash out you spoke about in a earlier post.
You mentioned having ailerons up about the thickness of the leading edge.
I take it thats both ailerons?
If so i might well have that on a rate switch also.
Old Sep 05, 2010, 05:27 PM
Joined Dec 2003
Its Reflex and its the thickness of the Trailing edge but its used to induce washout
and reduces tip stall tendency. The 28 flys the best out of the lot of 2.6mtr lot .
Just dont try and float the thing just let it fly you'll love it.
SteveW
Old Sep 05, 2010, 05:32 PM
Heathy is offline
Heathy's Avatar
Wiltshire England
Joined Aug 2010
So is that both facing upwards? I'm still learning about these type of things here!!
Old Sep 05, 2010, 05:40 PM
Joined Dec 2003
Yes both ailerons are raised slightly above the Trailing edge of the wing
SteveW
Old Sep 05, 2010, 05:41 PM
Heathy is offline
Heathy's Avatar
Wiltshire England
Joined Aug 2010
Cheers Steve
Old Sep 05, 2010, 07:40 PM
viper1 is offline
Find More Posts by viper1
viper1's Avatar
Melbourne, Australia
Joined May 2006
cockpit floor
Hi all,
I'm just finishing mine (just started making a semi-scale cockpit) and I noticed that many of you used the black cockpit floor included in the kit.
I was not going to use it anyway as I want to make a full-depth cockpit.
But just out of curiosity; Mine is more than 6 mm (1/4") wider than the cockpit opening. How did you guys solve that, or did this particular part fit better on some kits?
Thanks in advance,
GJ
P-51 Homepage;
http://users.tpg.com.au/gmustang/
viper1 is offline Find More Posts by viper1
Old Sep 06, 2010, 12:50 AM
Roger Lombard is offline
Find More Posts by Roger Lombard
Confused? Who, me?
Roger Lombard's Avatar
United Kingdom, England, North York
Joined Jan 2005
You may not be short of ideas for the cockpit but a friend of mine built a custom "scale" cockpit for his ASH 26. You can see his thread here http://www.rcgroups.com/forums/showthread.php?t=798983
Roger Lombard is offline Find More Posts by Roger Lombard
Old Sep 06, 2010, 01:23 AM
viper1 is offline
viper1's Avatar
Joined May 2006
Never enough ideas !!
Thanks for the link.
I hope it will look only half as good as this one:
http://www.soaringissa.org/Reference...X-HKMASW28.htm
P-51 Homepage;
Old Sep 06, 2010, 08:29 AM
Joined Apr 2010
Message for Steve W.
Steve-No,have not flown mine yet,still building my 1/4 scale pik 20.It sounds like the multiplex asw 27b-2.6 metre is no longer for sale-missed out on that one.Once l complete the pik 20,its all flying,not building, these birds, from then on.regards damo
HF models ASW-28 3M soaringMoe Scale Sailplanes 7 Aug 21, 2003 04:49 PM
Asw-27, Asw-28, 82" Carter Scale Sailplanes 14 Aug 03, 2003 11:39 AM
EMS ASW 28 3m Radek Z Thermal 15 Jul 29, 2002 12:58 PM
NSP's ASW-28? Ben74 Slope 5 Jun 06, 2002 11:41 AM
