Now for the uppy-downy mover bit.....
I used the supplied hardware for the elevator. The cross section of the elevator is not a highly tapered as the ailerons, so the Zip horn should be OK here. I used a HS-56 servo (rescued complete with extension soldered on from the wreck of the CMPro Discus). The was secured to the fin surface using 5 minute epoxy thickened with Q cells. I roughed up both surfaces 1st to provide some purchase for the glue.
And on the menu tonight is...........
A can of peas
Alright. Can o pee, you know, the clear bit at the front. Another 24 hours of glue drying. I would have applied the decals but found I have run out of Windex. I'll grab some tomorrow and put them on then.
| Thread Tools | |
| HF models ASW-28 3M | soaringMoe | Scale Sailplanes | 7 | Aug 21, 2003 04:49 PM |
| Asw-27, Asw-28, 82" | Carter | Scale Sailplanes | 14 | Aug 03, 2003 11:39 AM |
| EMS ASW 28 3m | Radek Z | Thermal | 15 | Jul 29, 2002 12:58 PM |
| NSP's ASW-28? | Ben74 | Slope | 5 | Jun 06, 2002 11:41 AM |
