Old Jun 04, 2007, 09:13 AM
thinkingabout is offline
Find More Posts by thinkingabout
Joined Jun 2007
by the time.....i ordered now one of this pretty modell with fast delivery.
I hope so, getting mine the next 3-5 days.....but i cant believe...its a long way to good old germany.. :-)
My hometown...
www.vierkirchen.de
25 miles northern of
http://www.muenchen.de/home/60093/Homepage.html
Best Soccer Club in the world ;-):
http://www.fcbayern.t-com.de/en/inde...3ba1986ae17b03
back to topic..
thinkingabout is offline Find More Posts by thinkingabout
Old Jun 04, 2007, 08:55 PM
fishovertime is offline
Find More Posts by fishovertime
United States, FL, Miramar
Joined Aug 2006
Hobby88.com
Might be the same people....
Andrew
fishovertime is offline Find More Posts by fishovertime
Old Jun 06, 2007, 01:47 PM
Joined Jun 2007
Hi Salisbug,
its going on...very nice.!
Which kind of glue do u take? Epoxy or hot glue for the Connectors...?
I order my ASW last monday. Do u get a Feedback -Email after ordering? i donīt get one. How long did u wait for the ASW?
Monday-
, then 3-5Days shipping...i think i will get it till next Monday.
Make my Day...some more picture please.. :-)
Old Jun 06, 2007, 05:41 PM
salisbug is offline
Find More Posts by salisbug
I failed linkage geometry
salisbug's Avatar
Melbourne, Australia
Joined Jun 2002
G'day thinking,
I got a confirmation Email from Albert after ordering. It took 5 calendar days to get to Australia.
The wires are set in position and into the recepticle using hot glue and the connector recepticles are installed into the airframe using epoxy.
More photos tonight as I get her closer to flying
salisbug is offline Find More Posts by salisbug
Old Jun 06, 2007, 05:46 PM
Joined Jun 2007
Originally Posted by salisbug
G'day thinking,
Great.. I didnīt get one
Maybe it wasnīt the last one...maybe there was no one.....
I mailed Albert, 2 hours ago....waiting for response.
Salisburg, what time is it right now in Australia?
Hier in Germany its 00:45,Thursday morning....time for bed
Old Jun 06, 2007, 05:55 PM
salisbug is offline
salisbug's Avatar
Joined Jun 2002
8:45 am
Old Jun 06, 2007, 06:00 PM
Joined Jun 2007
Oh, good Morning :-)
Iam a idiot!
I find out, how to get the latest order information...
Just going to aero-fever.com and checking My Account.....
There all information......Package was send today :-)
Old Jun 09, 2007, 12:52 AM
Joined Jun 2007
G'day thinking,
Hi Salisbug,
where r the Photos? :-) ...or r u still Off?
i think, we together r the only ASW 28 owner....no one else with feedback about this glider...
Old Jun 10, 2007, 05:00 AM
salisbug is offline
salisbug's Avatar
Joined Jun 2002
Wing to fuselage
Didn't get the model ready for my flying trip. Just not enough motivation.
I only build under tight deadlines for the Australia Day weekend.
Tonight I got one wing on with the MPX connectors doing the spoileron hook-up automatically. Now I have to complete the other side
Old Jun 10, 2007, 06:16 AM
salisbug is offline
salisbug's Avatar
Joined Jun 2002
The other side is now done.
All zipped up & ready to go. Wing to fuselage joint is acceptable.
Old Jun 10, 2007, 10:30 AM
Joined Jun 2007
Hi Salisbug,great Job!
For hook-up automatically, u started with the fuselage....
After this, how do you mark the right position for the MPX connectors at the wing?....for doing the spoileron hook-up automatically.
Fixing the Wing-Connector against the Fuselage-Connector a little bit at the left or right side and i will have a little Problem..i think so..
Old Jun 10, 2007, 08:16 PM
salisbug is offline
salisbug's Avatar
Joined Jun 2002
The wing has a hole for the servo lead exit as supplied.
* Put the wing on the joiner and get it a couple of inches away from the fuselage.
* Plug the wing connector to the fuselage one.
* Mark the fwd and aft ends of the connector boss on the wing root.
* Remove the wings and use a dremel router bit to open up the root rib
* Install the connector into the wing and mark the outline of the connector flange.
* Rout the recess for the flange
* Mask the fuselage root fairing around the connector plug
* Re-assemble the wing and connector leaving the wing an inch or so out from the fuselage
* Apply a some adhesive on the inside of the wing connector flange
* Place the wing in its final position and hold there for 5 minutes
* Dis-assemble, remove the tape and its done
Old Jun 11, 2007, 12:38 AM
salisbug is offline
salisbug's Avatar
Joined Jun 2002
Mounted the taiplane
I used my mk 1 Lego jig to align the taiplane to the wings. The photos below show the issues I faced.
* The fin is slightly out of vertical
Nothing could be done apart from trying to hit it with the heat gun but I decided against that action. It takes a fair bit of heat and there's a fair chance of damaging the glass & finish. I'll learn to live with the crooked fin. So to fix it I sanded a bit off the top R/H side of the fin using my Permagrit sander but stopped when I hit glass. The tailplane was still nowhere near level and it took 8 staggered layers of masking tape on the top left of the fin dropping off evenly to half way across the fin to get it to sit straight.
To make matters worse the front tailplane fixing screw hole was partially blocked and needed a clean out using a fine Dremel router bit. The screw then went in but at a horrible angle. To top it off the threaded insert buried within the glass layers came loose when tightening the screw and needed to have some thin cyano wicked in to keep it from turning.
A bit trying but done none the less.
Old Jun 11, 2007, 06:00 AM
salisbug is offline
salisbug's Avatar
Joined Jun 2002
Just a tad more.........
Made an rx tray from hard balsa. I then smeared some 5 minute epoxy over it to smooth the surface for the adhesive backed velcro to stick to. I attached the rx and stuck the tray and the switch in using hot glue.
I was about to do a rough radio setup, but the battery pack was just like a dodo. It's on the charger and I'm sitting on my lemon watching the tube.
HF models ASW-28 3M soaringMoe Scale Sailplanes 7 Aug 21, 2003 04:49 PM
Asw-27, Asw-28, 82" Carter Scale Sailplanes 14 Aug 03, 2003 11:39 AM
EMS ASW 28 3m Radek Z Thermal 15 Jul 29, 2002 12:58 PM
NSP's ASW-28? Ben74 Slope 5 Jun 06, 2002 11:41 AM
