Old Jun 02, 2007, 09:12 AM
HoverTim is offline
Find More Posts by HoverTim
HoverTim's Avatar
Joined Mar 2007
Sanding sealer
Hello
I have just got some sanding sealer form my local shop but i am not too sure how to use it do i
A can i use ordinary tissue paper
B How do i apply it
C do i use it like a paper mashaa
Regards Tim
HoverTim is offline Find More Posts by HoverTim
Old Jun 02, 2007, 11:08 AM
Kmot is online now
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
The sanding sealer I have used is designed to fill balsa before painting. You apply the sealer with any paint brush. Let it dry, then sand smooth. Then prime, and paint.
Kmot is online now Find More Posts by Kmot
Old Jun 02, 2007, 11:41 AM
Umi_Ryuzuki is online now
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
You don't need to use tissue if all you are doing is sealing the wood.
Light model airplane "Silkspan" is what we apply to combat warship hulls. It is used to stop splitting the grain when a round comes through the hull.
If you are applying tissue, paint the hull with the sanding sealer, and as you apply the laquer, press the tissue into the wetted hull. Brush or press out all the air bubbles as you work along the length of the model.
Precut your pieces to work around the details. Especially all those ribs if you are applying it to the top of your hover craft.
Umi_Ryuzuki is online now Find More Posts by Umi_Ryuzuki
Old Jun 02, 2007, 02:02 PM
HoverTim is offline
HoverTim's Avatar
Joined Mar 2007
tissue
can i use ordinary tissue or is it special stuff
Old Jun 02, 2007, 02:23 PM
Sea Dragon-Lover
PDX, OR
Joined Dec 2002
I don't see why not.
I would test a piece on some scrap balsa or something to see if it holds up, or starts to tear out while you are brushing it onto the hull, and bushing sanding sealer over it to thoroughly saturate the paper.
JK Perkins Sanding Sealer thething84 Scale Boats 10 Apr 11, 2005 04:00 PM
Foam Sanding Sealer / Filler : Tip BlueFielder The Builders Workshop 3 Jun 28, 2003 04:44 PM
Compatible sanding sealer? Doc Data The Builders Workshop 0 Sep 14, 2002 10:13 AM
Sanding Sealer & 'cote? tiggs Electric Plane Talk 4 Jun 18, 2001 11:39 AM
