Old Oct 30, 2002, 01:35 PM
AMTJIM is offline
Find More Posts by AMTJIM
"Bible Thumper"
AMTJIM's Avatar
United States, AZ, Tucson
Joined Mar 2001
Brushless engine for glow Mig-27 target drone
Hobby Lobby doesn't think the brushless motors they have will fly this, whats next? 67in wingspan 792 sq in area 4lbs out of the box. Normally flew with size 60 engine.
AMTJIM is offline Find More Posts by AMTJIM
Old Oct 30, 2002, 01:38 PM
AMTJIM is offline
"Bible Thumper"
AMTJIM's Avatar
Joined Mar 2001
pic
Old Oct 30, 2002, 01:51 PM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Re: Brushless engine for glow Mig-27 target drone
4lb out the box...so needs at least 4lb of flightpack (you want excitement right?) and an AUW of 8lb....so around 800W of power on maybe 32cells?
Thats fine, around 25A is fine...so you need a motor that can handle 25A on 32cells, or maybe a bit more on a few less, for extra excitement.
I think the biggest hackers will do that OK. And others. I think possibly a big kontroniks will - check their sites.
Not going to be a slow model tho
Old Oct 30, 2002, 04:12 PM
Troy is offline
Find More Posts by Troy
Caution:Makes sharp left turns
Troy's Avatar
United States, CA, Lake Forest
Joined Feb 1999
Cool, I haven't seen one of those in Years! That shouldn't be hard to find a motor for at all. One of the big Hackers/Kontroniks/Aveox's geared down swinging a 15-16" prop would haul it around nicely!! A friend of mine has a .60 size P-51 and he's running a large brushed 1800 series Plattenberg 2:1GB (high torque motor) on 24-2400s swinging a 16X10" prop at 7500RPMand it is a 90-100mph plane out of a slight dive and climbs out of sight at a 45 degree angle. Flight times are 5-6 minutes of lead footed driving If you ran 30+ cells you could get away with CP1700 sized cells and a lower Kv motor.
Where's Ed with his motocalc??
Troy is offline Find More Posts by Troy
Latest blog entry: Flying Ghost
Old Oct 30, 2002, 08:01 PM
twest is online now
Find More Posts by twest
100% electric since 1990
twest's Avatar
United States, MA, Ware
Joined Jul 2001
If the kit weighs 4 lbs, assume 20 cells (conservative). Assume about 2 oz. per 2400 mah cell, so you are up to 64 oz. + 40 oz =104 oz. Add the weight of a motor, gearbox, radio system, etc., and you are in the ballpark of 7.5-8 lbs (I am rounding here). At eight lbs, you need 800 watts to reach the 100watts/lb. rating that you will want. That means you will have to draw 40 amps on twenty cells. There are many brushless motor systems that will fit that bill.
twest is online now Find More Posts by twest
Old Oct 30, 2002, 08:13 PM
modest-master is offline
Find More Posts by modest-master
modest-master's Avatar
Palm Bay, FL, USA
Joined May 2001
Hacker
I fly 8.25 lbs. pattern plane with this set up.
Unlimited vertical.
Hacker B50 9XL w/5.2:1, 16x10, 20 cells
www.EspritModel.com
modest-master is offline Find More Posts by modest-master
Site Sponsor
Old Oct 30, 2002, 09:59 PM
King Kong is offline
Find More Posts by King Kong
King Kong's Avatar
los alamitos ca
Joined Jun 2001
where'd you get one of those? and for how much? That looks pretty fun.
King Kong is offline Find More Posts by King Kong
Old Oct 31, 2002, 02:49 AM
jak is offline
jak
Find More Posts by jak
jak
jak's Avatar
Taipei Taiwan
Joined Feb 2000
Same question as King Kong, where do we get em.
jak
jak is offline Find More Posts by jak
Old Oct 31, 2002, 12:44 PM
Troy is offline
Troy's Avatar
Joined Feb 1999
Yah, are these still available? I remember these and the autogyro Hind helicopter were sold to modelors. The Hind was really cool looking in the air. Both were catapault launched for the military.
Old Oct 31, 2002, 01:24 PM
AMTJIM is offline
"Bible Thumper"
AMTJIM's Avatar
Joined Mar 2001
Check with chicago bill and seneca on rc unverse in the used aircraft classifieds, run a search on"mig" using the bottom of the page search engine. Chicagobill has like 8 boxes of these. He also has some profile F-16s.
I have never seen anything about the Hinds, that would really be a collectors item.
Whoops! What Engine For Rbc Mig 29 With Mini Fan 480 MAIZOR Electric Ducted Fan Jet Talk 14 Nov 25, 2004 11:41 PM
RS Systems/Goldberg Mig-27 Target Drone byrocat Electric Ducted Fan Jet Talk 3 Nov 02, 2004 07:30 PM
WTB brushless system for Wattage Mig-15 spencer6891 Aircraft - Electric - Airplanes (FS/W) 1 Sep 03, 2004 10:47 PM
Yippee! Mig-27 target Drone forSale Whiskey Aircraft - Fuel - Airplanes (FS/W) 5 Nov 08, 2003 06:42 AM
Finished Mig-27 target drone AMTJIM Fuel Plane Talk 4 Nov 24, 2002 11:20 AM
