Espritmodel.com Heli Air
Old May 31, 2007, 04:10 PM
Russ Young
isoarthenland's Avatar
United States, UT, South Jordan
Joined Mar 2006
Shrike Build Question
Are most of you Shrike builders permanently affixing the vtails to the tailboom, or have you found a way to keep them removable (but not while flying )
Russ
isoarthenland is offline Find More Posts by isoarthenland
Old May 31, 2007, 04:14 PM
Yes, ALL your money...
winchdoc's Avatar
A hut in the woods in Oregon
Joined Jan 2003
If you pinch the wires together ever so slightly, they will retain the surface pretty well without resorting to s small strip of tape along the underside of the V.
winchdoc is offline Find More Posts by winchdoc
Old May 31, 2007, 04:18 PM
ALL IN !
Louied's Avatar
Carlsbad, California, United States
Joined Feb 2004
I do what Doc says it works very nicely. It very nice to keep them removable in the case you need to travel.
Louie
Louied is offline Find More Posts by Louied
Old May 31, 2007, 04:22 PM
Russ Young
Joined Mar 2006
Thanks guys...I really did want to keep them removable. I'll probably pinch and tape, just in case.
Westerly Windina
screamin' eagle's Avatar
Pacific Palisades, CA
Joined Jul 2004
Same here. I use just the wires and no tape. Tail feathers slide on and off and stay on in flight no problem. The whole plane packs flat into a 36" aluminum gun case. Very smooooooth....
screamin' eagle is offline Find More Posts by screamin' eagle
Old May 31, 2007, 04:50 PM
sno
winds a blow'n Im a go'n!
sno's Avatar
The Sticks!! Central Oregon
Joined Mar 2005
Yup! Bend the wires a bit! I also put a small piece of clear tape on the bottom just to make me feel better!
Your still not done building that thing??? ;-)
sno is offline Find More Posts by sno
Old May 31, 2007, 10:54 PM
Russ Young
Joined Mar 2006
Sno...it will maiden this weekend....other stuff got in the way...mainly helping my son install his sprinkler system
Old May 31, 2007, 11:59 PM
sno
sno's Avatar
Joined Mar 2005
Cool! Good luck on the maiden! I would put the cg just ahead of the wingrod to start with...mine was barely flyable centered!
Old Jun 01, 2007, 04:01 PM
Russ Young
Joined Mar 2006
Weights
OK then...do I have a bloated Shrike on my hands ?
AUW balanced a little in front of the steel wing rod: 31oz
Left wing: 5.6 oz
Right wing: 5.4oz
Left stab: .6 oz (without pins)
Right stab: .6 oz (without pins)
I bagged the stabs in .5 oz glass
The wings are bagged Obeeche with a few coats of water based poly, sanded lightly between coats
Receiver: Berg 4
Servos: HS 5245-MGs
Where do you think my problem is?
Do I care in the big wind at Point of the Mountain?
Russ
Old Jun 01, 2007, 04:18 PM
sno
sno's Avatar
Joined Mar 2005
How much weight did you have to add in the nose? What size battery pack are you running? I am not sure what my AUW is...I do know that it was flying GREAT with an extra 6oz on board at Eagle!
Old Jun 01, 2007, 04:27 PM
Westerly Windina
Joined Jul 2004
Mine was 21 oz with the steel wingrod. I sealed and painted but didn't glass the tailfeathers. I did not paint the carbon boom.
Later I primed and painted the boom and needed another 1.5 - 2oz of noseweight to compensate. I can imagine glassing the tail feathers could result in lots of added weight in the nose. I for one wish I'd glassed mine - they are weak.
You could always go back to the carbon rod if need be.
Old Jun 01, 2007, 04:40 PM
Russ Young
Joined Mar 2006
Battery: 700mh square pack - 3.2oz
Lead: 4.2oz
Old Jun 01, 2007, 04:41 PM
Westerly Windina
Joined Jul 2004
I'm using a 1000mah AAA pack from Canuck Engineering.
Old Jun 01, 2007, 04:43 PM
Russ Young
Joined Mar 2006
Screamin'...
I'll probably fly it as is for the maiden...then maybe:
- Cut some lightening holes in the stabs and cover with something light
- Try the carbon rods
- build another set of lighter stabs
- leave as-is if I'm happy with it.
Old Jun 01, 2007, 04:46 PM
Westerly Windina
Joined Jul 2004
I wouldn't worry about the weight at all.
T-IFO Build Question Mighty Dingus Electric Plane Talk 10 Jul 07, 2002 11:50 PM
T-IFO Build question Mighty Dingus Indoor and Micro Models 5 Jul 07, 2002 09:28 PM
Zagi 400X Build Question HavingFun2002 Foamies (Kits) 4 Apr 25, 2002 07:58 AM
Mini Tornado build question Crashmaster Foamies (Kits) 1 Mar 26, 2002 07:38 PM
Scratch build question Steph280 Beginner Training Area (Aircraft-Electric) 7 Nov 02, 2001 04:30 PM
