The F5-E in Swiss markings |
| Wingspan: | 760mm/30-1/2" |
| Wing Area: | 12.44dm sq |
| Weight: | 37.5 oz. |
| Length: | 1312mm |
| Wing Loading: | 72.3g/dm sq |
| Servos: | 9 nine gram servos |
| Transmitter: | JR 7202 |
| Receiver: | Hitec FM Supreme IIS with autoshift |
| Battery: | 14.8 volt 4-cell 2,200 mAh Lipoly battery |
| Motor: | outrunner brushless motor |
| Fan unit: | 70 mm ducted fan unit |
| ESC: | 40 Amps |
| Manufacturer: | StarMax |
| Available From: | Hobby-Lobby |
| Price: | $279.00 with an intro price of $259.00 |
Big! Bright! Beautiful! All of that, and truly Almost Ready to Fly with 9 installed servos including working retracts and steerable nose gear. It called out to me, "Fly and review!”
Included in the kit:
Items need to finish the plane and fly:
The first thing I did was place the 4-cell battery on my Bantam 8 charger so it would be ready when I was.
Per the instruction manual, I glued on the nose cone first using the supplied glue and added the vertical stabilizer with rudder and pre-installed rudder servo. I used foam safe CA in the fuselage and sprayed kicker on the bottom of the stabilizer and let it dry. I wanted this to be a quick set, and also because the supplied tube of glue did not have a lot of glue in it.
I wanted to install the control horns to the elevators, but I found the four small screws supplied for that task were somewhat short. I carefully compressed the foam area with the control arm and the mounting plate and secured the front screw by pressing hard with a Phillips screwdriver. I got the screw into the mounting plate. I then added a screw diagonally in back and tightened both. I repeated the process on the other elevator. The elevators are pre-hinged to the stabilizers.
The horizontal stabilizers/elevators had a rectangular block on the fuselage mounting side that had a top, a side, and two ends in contact with the fuselage, which is a nice design for gluing on the stabilizers. I put a thin layer of the supplied glue on the top, side, front and back surfaces of the stabilizer and the matching surfaces on the fuselage and pushed the part into place holding it firmly for a minute while checking on the alignment. I checked on it a couple of times over the next fifteen minutes and repeated the process on the other side. I let those parts dry while I installed the wings. The next morning I connected the elevator control horns to their respective servos in the fuselage to complete the process. (This Camo version had two elevator servos. My friend's earlier Swiss marking version had only one elevator servo. This should be a big improvement in control at higher speeds.
If this weren't for a review, I might have made a modification by adding a wing spar. know that many RCGroups members love to increase the power with bigger, more powerful motors, and if you are one of those, I strongly recommend that you plan to add a carbon fiber wing rod support or two or add a thin layer of fiberglass on the bottom of the fuselage and wing that doesn't interfere with the ailerons or the retracts.
As it is, the designed wing support is this: gluing the wing onto the side of the fuselage and on top of a short slightly interlocking ledge. I placed a bead of glue along the top of the ledge and against the fuselage above the ledge. I also placed the glue on the matching places on the wing panel as well as the side of the wing out to the front and to the back. I connected the aileron servo on the first wing panel to the extension wire in the fuselage, and the tight pull of the wire got a little glue from the wing panel onto the fuselage where I didn't intend for it to be. I got the wing in place, cleaned up the glue, pressed the wing hard against the side of the fuselage a couple of times during the first five minutes and let it sit for a half hour. It looked like a nice tight fit.
After the half hour, I repeated the process for the second wing panel except this time I didn't plug in the aileron servo to the extension wire. I pressed the wing firmly in place while holding it for five minutes, and then set it aside for a half hour and checked on it a couple times during that time.
I got out my Pacer Formula 560 canopy glue and trial fit the canopy onto the fuselage. There was a molded line where it rested, and I laid a thin bead of glue along that line, wiping the excess with my finger and carefully placed the canopy where it belonged, pressing it against the glue softly. I repeated this every half hour 2 more times, and by the last time the glue was getting tackier, and the canopy was holding against the sides of the fuselage better. One last time, and all gaps were gone. The glue wasn't dry, but it was tacky and holding the canopy in place and would now dry with the canopy in place.
The next morning I connected the control arms to the elevators and their respective servos and adjusted the clevises mechanically as necessary to have neutral elevators with the servo arms at 90 degrees down. plugged in the second aileron servo to the extension wire coming out of the fuselage to finish the wings.
I moved to the retracts and examined how they each connected to their own servo with a short control arm and figured out how they should work and be installed. I hadn't needed any instructions to this point, and the build to this point had been straightforward anyway, but I would have liked some instructions or pictures for the retracts, and there were none. But I quickly saw how to position it and set the short control rod between the retract and the controlling servo.
I decided I wanted to install the retracts in the landing gear down position so I would have access to the servos if I needed to adjust the control arm locations. So I skipped ahead and installed my receiver and the battery pack, and then moved the retract servos to the down position (front wheel lowered) and installed the main gear. There was a little play towards the inside on both of the main gear wheels, so I moved one servo control arm to tighten up one to match the other side, but both still had some play.
After a couple of flights I remembered that the retracts have computer adjustment on my transmitter. While they all three closed nicely, the two mains had some play towards the inside. Using my computer programing, I took the sub-trim from 100% in the downward movement and moved it out to 125%, then later back down to 120% of normal throw. This still got the wheels to the full down position, but the main wheels were pushed out harder, and there was almost no play towards the inside. My plane’s main wheels were in a much firmer straight down position with no give to the inside.
I opened up the radio and battery compartments and installed a new Hitec Supreme IIS receiver and found numbers on the servo connector plugs in the compartment. The "instructional manual" had no explanation for the numbers. I made my best guess as to how they they would match up and they proved to be a good guesses.
The connector's numbers matched up as follows:
I had to reverse the aileron and elevator directions on my programmable JR-7202 transmitter. Throttle, rudder/steering and retracts all worked in the correct direction. I was hoping to find a tube for the antenna in the fuselage, but no such luck. I ran it over the battery box out of the way and then outside and taped it to the bottom of the fuselage. I secured the receiver in the radio compartment with Velcro. I had to make very minor mechanical adjustments to the ailerons and elevator clevises as well as to the servo arms on the front wheel and one of the main retracts. The rudder servo required no adjustment.
The plane was ready to fly 13 hours after I received it from Hobby-Lobby, and that included a good night's (by my whacked out sleep standards) sleep. The assembly was easy, and except for the vertical stabilizer, was done with the supplied glue which seemed to work very well. Although I only added a one ounce receiver, my plane's RTF weight was 37.5 ounces, 2.5 ounces heavier than the suggested weight.
The servo count: two aileron servos, two elevator servos, one rudder servo, two main retract servos, one front retract servo and one front wheel steering servo for a total of nine.
I added decals after the plane had flown two patrols, morning and evening.
From the text on the Hobby Lobby’s website:
"This jet has plenty of power to take off from a smooth surface or runway. The speed range is moderate with very good manners. Difficult to stall, the jet will slow to a crawl and still maintain full control. Great to land, the approach is easy to control and smooth landings are easy to do."
That’s a very accurate description. The top speed was only moderate but seemed faster than that after literally crawling around the sky with the plane at a slow throttle setting for a pass or two and then hitting full throttle.
Elevator response is good on my plane at both slow and high speeds. The ailerons will allow for good turns and axial rolls. Bringing in the rudder with the ailerons allows for smoother turns and barrel rolls. It continues to be controllable even at speeds under 10 miles per hour with a very nice flight envelope.
All flights have started with a run down the runway and have been wonderful takeoffs. She takes off without any problem or lack of power. Landings have mostly been with the retracts down on runways, and I have enjoyed watching the gear go up after takeoff and come down for landing (very high cool factor for me).
So far my landing gear has worked as it should! I generally don't slam the plane in on landing like a naval aviator making a carrier landing. I prefer to flair and set down gently so I am pretty easy on my planes’ landing gear in most cases. I have made a slide landing on the grass at the park when conditions (large dogs on the loose in runway area) required it. That landing was nice and smooth as well, but wasn't nearly as much fun to watch as when the gear drops on final approach followed by touch down.
My favorite maneuver (on a fresh battery pack) has been slowly flying down the field with the nose high and then hitting full throttle and climbing. It looks like a US Air Force show maneuver have seen the F-16 perform. WAY COOL! The F5 also does a nice loop and good tight axial rolls. Top speed was only moderate, but seems faster especially after a very slow pass. The plane flies inverted very well, much better than I do. Control and handling have been excellent. Speed ranges from very slow to good moderate, which is fine for me.
My plane's elevator response at full throttle is quicker than my friend's F5-E with Swiss markings first batch that only had one elevator servo. Hopefully they will add a second elevator servo to it as well. This was one improvement where I could easily see the difference.
When not at the field I keep the retracts in the up/retracted position. My plane lies on a carpeted bench at home in storage and in my car going to the field. Far less chance of damage to the retracts or the plane itself by storing it this way.
With no self correction, I go with Hobby Lobby's call of it being for the intermediate pilot or better.
A true ARF with a quick and easy assembly. It’s a lot of fun to be able to fly the plane fully assembled the morning after I receiving it from Hobby Lobby. I was a happy pilot from the get go.
Pluses:
Minuses
| Thread Tools |
Joined May 2006
In case anyone is wondering the high speed pass at 1:20 in the aerobatics video is 74-75 mph. It might be higher or lower depending on what the temperature was when the video was shot. Still, that is better than some of the other Starmax planes.
Latest blog entry: more NY style pizza
Actually a five channel will do!
Ailerons Elevator Rudder/steering Throttle Retracts Thanks for the catch. If you have a five channel transmitter and receiver that will fit the bill you are good to go. My mistake. Mike H. |
Latest blog entry: New receiver packs and asking Castle for...
| Thread Tools | |
| Article Manzano Laser Works 37" Skyraider Kit Review | Bajora | Electric Warbirds | 119 | Aug 19, 2009 07:52 PM |
| For Sale HDX-450 V2 KIT CF w/ BL MOTOR L/N | cobra command | Aircraft - Electric - Helis (FS/W) | 8 | Jul 22, 2007 12:39 PM |
| Article Manzano Laser Works S400 Sopwith Camel Review | Jim Walker | Scale Electric Planes | 17 | Jun 11, 2007 08:49 AM |
