Old Aug 19, 2007, 11:00 PM
nomadd is offline
Find More Posts by nomadd
Lakeland, FL
Joined Feb 2005
Picked one of these up at Graves on Saturday. Can't wait to get it finished and in the air. It was nice to be able to speak to the designer of a plane before you buy it. I will try and post some pics of it progress.
nomadd is offline Find More Posts by nomadd
Old Aug 20, 2007, 09:22 AM
jkarpy is offline
Find More Posts by jkarpy
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
Oh no , I forgot to autograph your wing!
It was nice meeting you also. I hope you enjoy the plane.
jkarpy is offline Find More Posts by jkarpy
Old Aug 22, 2007, 12:26 PM
Kruzer1 is offline
Find More Posts by Kruzer1
Nall-ified Pilot
Joined Jul 2007
Been away all of last week.
I did power up the Micro and had the rudder and elevator servos suffering from extreme jitters. Decided not to try to fly it. Funny I did fiddle with the aileron one manually before I read not to but that one works fine. Any suggestions James or do I just chuck the servos and put in new ones?
Kruzer1 is offline Find More Posts by Kruzer1
Old Aug 22, 2007, 12:51 PM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
Are they new servos? I thought you got some new blue birds from Steve.
Old Aug 22, 2007, 12:55 PM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
Does the jitter stop if you apply a load to the servo? I had some servos that jittered on the ground but stopped once the plane was flying.
Old Aug 26, 2007, 09:33 PM
Kruzer1 is offline
Nall-ified Pilot
Joined Jul 2007
Yes the servos are brand new. No, it does not stop with load. Have been pretty busy so no time to fiddle around with them lately. Will let you know when I get some time again if any change. Should be talking to Steve soon too so I will let him know. Was wondering if I was just lucky or has anyone else had any problems with them? No fuss.
Old Aug 26, 2007, 10:07 PM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
It’s been kind of touch and go with the small Servos. When they work, they work well. Some times I get one that just will not center.
I have had good luck lately with the Cirrus and Blue Arrow servos.
Old Aug 27, 2007, 07:47 AM
kenverkjl is offline
Find More Posts by kenverkjl
Joined Aug 2007
1. The CG for this model is 1/8” inch to the rear of the main spar. Balance the plane at the CG by holding wings with your fingertips as shown. Try to maintain the distance from the front fuselage to the leading edge of the wing at 2 1/8” by adjusting positions of your hardware first. If necessary, change position of your wing to balance.
2. Once aircraft is balanced, adjust the horizontal stabilizer so it is parallel to the wing. Then glue the front and rear wing saddles to the fuselage stick.
3. Position servo, battery and motor mounts. Motor should have 2 ° of right and 2 ° of down thrust. This can be achieved by shimming the motor or by offsetting the motor mount during gluing. Glue the motor mount to the fuselage and battery mount using thick CA glue.
4. Square the vertical stabilizer to the horizontal stabilizer. Glue the vertical stabilizer to the horizontal stabilizer by bleeding thin CA into the mount.
5. Glue all control horns with thick CA.
6. Install control linkage. The E-Z connectors are for the aileron servo control horn. Feed the rudder and elevator pushrods through the rear pushrod guide before attaching to servos. Use Z bends for rudder and elevator servos. Be sure to center your servos first.
7. Permanently install receiver, motor and speed control. Make sure your antenna does not touch the carbon fiber fuselage or any metal. Use double stick foam tape to mount speed control to the top of battery mount.
8. Control throws are as follows:
Elevator: 45 ° up and down 20° low rate
Rudder: 45 ° left and right
Ailerons: 45 ° up and down 20° low rate
I recommend using expo if you have it!
kenverkjl is offline Find More Posts by kenverkjl
Old Aug 27, 2007, 09:50 AM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
What is this ?
Old Aug 27, 2007, 09:21 PM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
Millennium R/C at the Neat Fair
Who is going to Neat Fair?
Old Aug 28, 2007, 10:39 PM
Kruzer1 is offline
Nall-ified Pilot
Joined Jul 2007
James, I have a couple of Vortex 8.4g servos ( by IMEX) originally for a chopper. Will this work? Physically they're about the same size. Otherwise I will have to wait until I get another load of stuff.
Old Aug 28, 2007, 11:30 PM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
It will be a little heavy. I have some Blue Arrow servos that are less than 4 grams. I think I have your e-mail, I will send you a quote if you are interested.
Old Sep 01, 2007, 08:43 PM
Kruzer1 is offline
Nall-ified Pilot
Joined Jul 2007
Thanks very much James but it does not make sense to ship small packages out here, just not economical. I already have a list in the making for Steve and I am due there at the end of Sept. Hope I get to see you, my schedule is tight but I do have a couple flying days set aside. I plan to make up for lost time on the Venus :-)
Old Sep 01, 2007, 09:20 PM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
Let me know what days you are flying.
Old Sep 02, 2007, 08:25 PM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
Servos
We are now shipping combos with Blue Arrow/Blue Bird or Cirrus servos. The Cirrus servos are an additional $16.00 in the Combo.
Micro Hydroplane Build Attemp thailandboy2 Racing Boats - Electric 29 Aug 25, 2015 10:31 AM
Micro speedwing build schoey Foamies (Kits) 46 Aug 08, 2005 10:22 AM
another Micro IFO build richw286 Parkflyers 19 Feb 24, 2005 11:05 AM
House of Balsa Micro Cub Build OCModels Parkflyers 52 Aug 29, 2003 10:47 PM
Micro-light Build Questiions DLC Parkflyers 5 Jun 22, 2001 02:17 PM
