Old Jul 22, 2012, 12:45 AM
xsputnikx is offline
Find More Posts by xsputnikx
United States, GA, Barnesville
Joined Sep 2006
The build will be put on hold until I can order some more covering tried again today and it just ain't working so I will save what I.got for.a larger scale model that requires less bends lol
xsputnikx is offline Find More Posts by xsputnikx
Old Jul 22, 2012, 12:03 PM
jkarpy is offline
Find More Posts by jkarpy
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
I Like Ultracote Light or Ultracote parklite. Solite is also good but it is the harder of the two to use.
jkarpy is offline Find More Posts by jkarpy
Old Aug 07, 2012, 07:47 PM
pwhavens is offline
Find More Posts by pwhavens
pwhavens's Avatar
Pacific Northwest US
Joined Nov 2008
Rx setup
Crimp connectors with AWG24 (I think) from Spektrum A2020 servos to Spektrum AR400 Rx. Words to the wise: Use a quality crimper and don't drop micro crimp connectors onto the carpet.
P
pwhavens is offline Find More Posts by pwhavens
Old May 17, 2013, 03:46 PM
Joined Sep 2006
My micro ssx has still not been built yet it has became a shelf queen I still have to get all my electronics but I really wanna fly this looking at my back yard space I have now someone should slap me for not taking the time to get er done
Old May 17, 2013, 05:52 PM
Wamp is online now
Find More Posts by Wamp
Wamp's Avatar
Joined Mar 2012
Yup er.
I was nervous after flying the sim.
Use some room on the maiden.
Experiment with props.
It will fit! Good luck Chris
Wamp is online now Find More Posts by Wamp
Old May 18, 2013, 02:06 AM
Joined Sep 2006
Well not so much nervous as just spreading myself too thin on other projects. I think ima try to find time in June. What motor ESC size do u guys recommend ?
Old May 18, 2013, 07:27 AM
Wamp is online now
Wamp's Avatar
Joined Mar 2012
I understand the time thing.
Was happy with a park 250, but a light nose in bent the can.
Now have a fire power 250 from Heads Up RC with integral prop saver.
Had to make a new motor mount for the 3 point ,also integral mount.
Cool thing is the can is held on only by the magnets!
To put on a prop, pull off the can first!
A 360 2cell seems plenty.
The GWS 6X5 was great. Out of them about to try a 7X3.5.
Thing is on the sim it felt like a flea on crack, in the field it is well mannered!
Good luck Chris
Old May 18, 2013, 11:20 AM
Joined Sep 2006
OK thanks I will look at those
Old May 18, 2013, 01:10 PM
Wamp is online now
Wamp's Avatar
Joined Mar 2012
You are welcome.
Of note, mine came in on the light side.
With the 360mah it does not carry kinetic energy well.
It will harrier/spot land almost in it's own length!
It handles more wind than I would have ever guessed too! Chris
Old May 19, 2013, 11:23 AM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
For the ESC, I use the Castle thunderbird 6 or 9. The Higher end 10 amp Castle will also work. The best servos are the HiTec HS35 or The Diamond D47. Yes, any 250 motor is good. I have the Schulman version in stock. Call me if you want one. Have not had time to get it on my site.
James
Old May 19, 2013, 12:45 PM
Wamp is online now
Wamp's Avatar
Joined Mar 2012
James
Glad to see you have your ear to the ground!
Thanks again Chris
Old May 20, 2013, 07:17 PM
Wamp is online now
Wamp's Avatar
Joined Mar 2012
Thanks again Chris
Got SSX up after work.
The 7X3.8 stretches the O ring with any solid T input.
The 3.8 pitch speed is faster than I would have guessed.
Had fun and my first hand launch into a harrier.
Smooth and predictable! Chris
Old May 20, 2013, 09:26 PM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
Glad to hear
Old May 20, 2013, 09:30 PM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
Micro SSX ARF
The Micro SSX ARF is nearly out of stock. I have about 12 left and that will be it for the ARF. I have no plans to bring the ARF version of the Micro SSX back. Get them while you can.
http://www.flyerc.mybigcommerce.com/microssx-arf/
I also have motors but you need to call to order.
James
Old May 21, 2013, 10:24 AM
Joined Sep 2006
James
But the kit will continue to be available right ?
Micro Hydroplane Build Attemp thailandboy2 Racing Boats - Electric 29 Aug 25, 2015 10:31 AM
Micro speedwing build schoey Foamies (Kits) 46 Aug 08, 2005 10:22 AM
another Micro IFO build richw286 Parkflyers 19 Feb 24, 2005 11:05 AM
House of Balsa Micro Cub Build OCModels Parkflyers 52 Aug 29, 2003 10:47 PM
Micro-light Build Questiions DLC Parkflyers 5 Jun 22, 2001 02:17 PM
