Covering 101
Multi color
1. Cover the bottom of the wing first. 2. Make sure your glass is clean and smooth. 3. First, I cut the pieces of the covering. Make sure you cut the pieces with a 1/4” overlap. 4. Lay the pieces out onto the glass one at a time. Iron each piece to the glass as you move along. Do not forget the ¼” overlap. 5. Once you have all the pieces in place, turn the temperature up on the iron and seal all the seams. 6. Wait for the glass and covering to cool. 7. Peel the covering up from the glass. Do to put tension on the seams. 8. Place the covering on the wing and tack the four corners at the end ribs. Disregard the wing tips for now. 9. Tack the middle. Be sure to pull all the wrinkles out and continue tacking symmetrical points of the wing. 10. After all the wrinkles are gone, start at the center of the wing with the iron and in a sweeping motion work your way out to the last rib. Never apply pressure to the covering in the area between the ribs. Be careful to avoided applying too much heat to the seams. 11. Divide the wrinkles evenly throughout the wing tip. I then use the heat to shrink out the wrinkles. At the same time, I am pulling and stretching around the wing tip edge. I also use my fingers to brace the wing tip to prevent it from breaking. Use your thumb and index finger to grip the covering and the remaining fingers push the opposite side of the tip you are covering. If you have a hot grip glove, it helps. Ultracote Lite is best, but you should be able to get good results with Monokote. I recommend covering the model with the Ultracote Lite. Here are the stock numbers for the lite Ultracotes. Do not mistake standard transparent for lite transparent. Ultracote Lite Transparent Yellow HANU967 http://www.gravesrc.com/SearchResult...Search=HANU967 http://www.horizonhobby.com/Products...ProdID=HANU967 Ultracote Lite Transparent Blue HANU969 http://www.horizonhobby.com/Products...ProdID=HANU969 Ultracote Lite Transparent White HANU965 http://www.gravesrc.com/HANGER_9_ULT..._p/hanu965.htm http://www.horizonhobby.com/Products...ProdID=HANU965 Ultracote Lite Transparent Purple HANU968 http://www.gravesrc.com/HANGER_9_ULT..._p/hanu968.htm http://www.horizonhobby.com/Products...ProdID=HANU968 Ultracote Lite Transparent Clear HANU964 http://www.gravesrc.com/HANGER_9_ULT..._p/hanu964.htm http://www.horizonhobby.com/Products...ProdID=HANU964 Ultracote Lite Transparent RED HANU966 http://www.gravesrc.com/HANGER_9_ULT..._p/hanu966.htm http://www.horizonhobby.com/Products...ProdID=HANU966 Ultracote Lite Transparent Scale White HANU973 http://www.horizonhobby.com/Products...ProdID=HANU973 Ultracote lite can also be identified by the markings “ORALIGHT” on the backing. You can purchase these coverings from
Hey guys, I'm bummed. Plane is set up and ready to fly but I'm having issues with the ESC or maybe the motor? I bought the Hacker and X5 esc with the plane. Everything is wired up and programmed. When I plug in the battery with the throttle stick down and move the stick forward the motor just makes a clicking sound. If I give it a little flip with my finger it fires right up and will run at full and most of the throttle range. if I take it back down to off the same clicking starts again and it won't spin back up. I need to mention that somewhere along that while trying to figure this out got a little puff of smoke out of the ESC once and immediately unplugged it. That concerns me, but the problem I'm having was already occuring before that? Any tips? Is something fried out of the box or should I stick to my glow planes??? Thanks!
repairs@aero-model.com James |
I've heard good things about their customer service, so I wasn't worried about that. You know how it is though when you're all set to maiden and then something goes wrong.
Does this problem sound more like the motor or the ESC? I suppose I should send in both to be on the safe side. |
Make sure you have good solder joints. Pour soldering can ruin a brushless ESC. If one leg has pour conductivity, it confuses the ESC timing and causes damage to the ESC. I have seen this happen a few times since I started selling brushless motors with my kits. |
| Thread Tools | |
| Micro Hydroplane Build Attemp | thailandboy2 | Racing Boats - Electric | 28 | Apr 17, 2010 07:23 PM |
| Micro speedwing build | schoey | Foamies (Kits) | 46 | Aug 08, 2005 10:22 AM |
| another Micro IFO build | richw286 | Parkflyers | 19 | Feb 24, 2005 11:05 AM |
| House of Balsa Micro Cub Build | OCModels | Parkflyers | 52 | Aug 29, 2003 10:47 PM |
| Micro-light Build Questiions | DLC | Parkflyers | 5 | Jun 22, 2001 02:17 PM |
