Old Nov 06, 2007, 02:41 PM
jkarpy is offline
Find More Posts by jkarpy
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
Spectrum 6100 receiver mount
Secure the 6100 receiver to the mount with servo tape included in the Micro SSX kit and ARF.
jkarpy is offline Find More Posts by jkarpy
Old Nov 18, 2007, 05:26 PM
_Lunchbox_ is offline
Find More Posts by _Lunchbox_
Hodgehound # 3
_Lunchbox_'s Avatar
Adrian, GA
Joined Mar 2005
James, I picked up my Christmas present from Hodges' yesterday...a micro SSX.
The only problem will be is that now I have to wait until Christmas to have it.
_Lunchbox_ is offline Find More Posts by _Lunchbox_
Old Nov 18, 2007, 06:07 PM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
Thanks! what servos, motor and ESC did you get?
Old Nov 18, 2007, 06:52 PM
Hodgehound # 3
_Lunchbox_'s Avatar
Adrian, GA
Joined Mar 2005
I got the ARF because they didn't have a kit
I went with the Eflite park 250, Futaba s3114? (I think that was the number), CC TB 9 esc, Berg 4L, and an EVO 2s 400 battery I also got a couple different props to try out...
Old Nov 18, 2007, 07:20 PM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
The Futaba s3114 should be fine. I use the GWS 6-5 SF for the Park 250.
Old Nov 18, 2007, 07:23 PM
Hodgehound # 3
_Lunchbox_'s Avatar
Adrian, GA
Joined Mar 2005
The GWS 6-5 was one of the ones I got. I'll start with that one. It'll probably be the only one I need
Old Dec 17, 2007, 03:28 PM
GBR2 is offline
Find More Posts by GBR2
Stress Be Gone
GBR2's Avatar
Snohomish, WA
Joined May 2000
With a lot of stopping and starting I finally finished my Micro SSX a couple of weeks ago. I added a couple of washers under the left mounting screw for the motor to feed in a bit right thrust. Pretty impressed with the Hacker motor despite its small size. I'm using the GWS 6x5 that was recommended. I got the Spektrum receiver mounting shelf from James and it installed with no problems. I like how the receiver just tucks up into the space. I ended up using Dymond D37 servos as everything else I tried was basically cr*p, including the Cirrus 101. 3 failed in a row during burn in testing due to bad pots. I had to add an extremely small piece of lead to get the plane to balance. It fit easily into the rear of the tail mount bracket and held in place with a dab of epoxy. All up weight comes to 4.88 oz.
Flies very well.
GBR2 is offline Find More Posts by GBR2
Old Dec 17, 2007, 05:39 PM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
Originally Posted by GBR2
With a lot of stopping and starting I finally finished my Micro SSX a couple of weeks ago. I added a couple of washers under the left mounting screw for the motor to feed in a bit right thrust. Pretty impressed with the Hacker motor despite its small size. I'm using the GWS 6x5 that was recommended. I got the Spektrum receiver mounting shelf from James and it installed with no problems. I like how the receiver just tucks up into the space. I ended up using Dymond D37 servos as everything else I tried was basically cr*p, including the Cirrus 101. 3 failed in a row during burn in testing due to bad pots. I had to add an extremely small piece of lead to get the plane to balance. It fit easily into the rear of the tail mount bracket and held in place with a dab of epoxy. All up weight comes to 6.12 oz.
Flies very well.
How did it end up 6.12 oz? They usually weigh less than 5 oz. Is it the battery? I have built plenty of them and never had one that heavy. You build looks great!
I have been doing a lot of testing with the CS101 and have found that they always fail when you drive them over the standard 2 millisecond range. I have several of them working very well. I have been setting my travel adjust just bellow or at 100%.
Old Dec 17, 2007, 05:42 PM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
Flies very well.
How is the centering on the D37? I know I need to get some and try them!
Old Dec 17, 2007, 10:54 PM
GBR2 is offline
Stress Be Gone
GBR2's Avatar
Snohomish, WA
Joined May 2000
Corrected my post, all up weight with battery is 4.88 oz. I was looking at the wrong notes when I put that up. The D37's center well but also have a rather large dead band. However, control movement is smooth and they work well. I burned each of them in for over 45 minutes each (HiTec servo tester moving the servo from one end of travel to the other) with no problems. The servo tester normally goes between 900us to 2100us and that is probably what killed the pots in the Cirrus servos. Just recently got some 3.7 servos from LightFlite that they are going to be using in the new Mini BUG. Ron claims he looked high and low before he found these. Haven't tested them yet but they look nice.
Old Jan 07, 2008, 01:45 PM
mpoyneer is offline
Find More Posts by mpoyneer
Thank a US Soldier
mpoyneer's Avatar
Syracuse, NY
Joined Jul 2005
I had taken the wing of a wrecked E-flite Mini Ultra stick and combined it with the tail group from my wrecked PA Katana Mini on my "MiniUltraSlowStiKatana" and my buddy and I love the way it flies. I saw your SSX and had to buy one for my friend and the wing/tail group for me.
Talk about customer service - James and Karen should write a manual for the younger generation to teach them what real customer service is all about! I bought the SSX kit and one SSX wing and tail group kit and of course the MicroSSX ARF, and can't wait to complete the MicroSSX for an upcoming indoor event.
These kits are the best way to transition from a Slow Stick to an aileron trainer with aerobatic ability, IMHO.
Back on topic:
My Micro SSX -
I will be using the park 250 and the GWS 6x5 SF, along with the Spektrum Nanolite RX and three DSP60J servos. I'm thinking about ordering just the MicroSSX wing kit and build it with two servos for flaps and see how that works for really slow flying.
mpoyneer is offline Find More Posts by mpoyneer
Old Jan 07, 2008, 02:54 PM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
Back on topic:
My Micro SSX -
I am not sure how flaps will work. I have been experimenting with taking weight out of the plane and using the lightest possible servos, motor/ESC and receiver. I have a little 9 gram motor that I will be selling on my web site.
I am using blue arrow servos (not to be confused with blue bird), they have been pretty reliable. I am also using a little 350 mah 2 S lipo. I am also adding some positive incidence to the wing. You can make an adjustable incidence (See picture).
Old Jan 08, 2008, 02:31 PM
mpoyneer is offline
Thank a US Soldier
mpoyneer's Avatar
Syracuse, NY
Joined Jul 2005
I don't want to mess with the incidence, and if we can keep the AUW down, two servos should do the trick. Also, since the servos are acting on less surface area than in a single aileron servo configuration, we should be able to use smaller servos.
If the dual servo mod works and the weight stays down, I would think it would handle like a mini ultra stick using flaps/2 servos. With the incidence left standard, inverted flight would not be affected, and with 2 servos we could introduce elevator to flap mixing for tighter loops. Er, wait, is that Flap to Elevator mixing?
I have to log back on to your site and see what the wing kit goes for and get it ordered. I think this idea will fly...pun intended!
Old Jan 08, 2008, 02:32 PM
mpoyneer is offline
Thank a US Soldier
mpoyneer's Avatar
Syracuse, NY
Joined Jul 2005
Has anyone used the tiny Park 180 with this yet? I would think it a hair too small, but if the right diet were imposed, it could work.
Old Jan 08, 2008, 04:03 PM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
I think the Park 180 would be ideal for indoor flying.
Micro Hydroplane Build Attemp thailandboy2 Racing Boats - Electric 29 Aug 25, 2015 10:31 AM
Micro speedwing build schoey Foamies (Kits) 46 Aug 08, 2005 10:22 AM
another Micro IFO build richw286 Parkflyers 19 Feb 24, 2005 11:05 AM
House of Balsa Micro Cub Build OCModels Parkflyers 52 Aug 29, 2003 10:47 PM
Micro-light Build Questiions DLC Parkflyers 5 Jun 22, 2001 02:17 PM
