Go Back   RC Groups > Vendors > Millennium R/C
Old May 29, 2007, 02:04 PM   #1
Site Sponsor
jkarpy's Avatar
Micro SSX Build
This is the start of the Micro SSX Build thread. The intention of the thread is to cover both the kit and ARF version. Post number one will serve as an index to the body of this thread and other related threads. Post number one can change daily as new information and ideas are available. Relevant posts are any thing related directly to the Micro SSX or any product that can be used with the Micro SSX.
Note: This is a work in progress 5/29/07
  • Name: Micr-SSX-2.jpg
  • Name: 100_1284.jpg
  • Name: DSC00472.jpg
Description: The Frisbee hand launch The Frisbee hand launch 108.7 KB · Views: 1101
  • Name: MicroSSX-Multi.jpg
Description: For the true Micro SSX fan; wallpaper for your home computer. For the true Micro SSX fan; wallpaper for your home computer. 23.3 KB · Views: 830
  • Name: DSC00483.jpg
  • Name: DSC00482.jpg
  • Name: DSC00485.jpg
jkarpy is offline Find More Posts by jkarpy   Reply With Quote
Old May 29, 2007, 02:04 PM   #2
Site Sponsor
jkarpy's Avatar
Tape hinges
Pull out the horizontal stabilizer and elevator from the kit. Put a long strip of Scotch tape along the trailing edge of the horizontal stabilizer so that half of
the width of the tape hangs over the trailing edge. Place elevator with beveled side UP and the beveled edge parallel with the trailing edge of the horizontal stabilizer. Slide the elevator down the trailing edge of the horizontal stabilizer until it attaches to the tape. While holding the elevator at a 45° angle to the horizontal stabilizer, lift the horizontal stabilizer,
while at the same time allowing the elevator to rest flat on the table, keeping them at a 45° angle. Flip over and secure the tape with finger. Fold both pieces flat onto each other, with the hinge tape on the inside. Cut off excess tape. Take another piece of Scotch tape longer than the hinge edge, and
attach it to the opposite side of the bevel. Again, cut off excess tape from the ends. Roll both pieces over the extended edge of the tape so that now both sides of the hinge are covered.
Rudder Hinge Assembly: Line the top edges of the rudder and vertical stabilizer. Start out with a piece of tape the length of the vertical stabilizer. Using the same method as previously mentioned for the horizontal stabilizer, apply hinge tape.
Aileron Hinge Assembly: Use same method described above for aileron hinges.
  • Name: 100_1243.jpg
  • Name: 100_1241.jpg
  • Name: 100_1244.jpg
  • Name: 100_1237.jpg
  • Name: 100_1240.jpg
  • Name: DSC00535.jpg
Description: Rudder control horn location Rudder control horn location 56.4 KB · Views: 467
  • Name: DSC00537.jpg
Description: Elevator control horn location, note; The Z bend in this photo is inserted from the inside. In this position the elevator control rod can move freely without being obstructed by the rudder. Elevator control horn location, note; The Z bend in this photo is inserted from the inside. In this position the elevator control rod can move freely without being obstructed by the rudder. 40.9 KB · Views: 452
Old May 29, 2007, 02:05 PM   #3
Site Sponsor
jkarpy's Avatar
Servo Mount
Servo Mount
  • Name: DSC00182.jpg
Description: Note: smaller servo arm than the one shown in this picture should be used. Note: smaller servo arm than the one shown in this picture should be used. 40.9 KB · Views: 629
  • Name: DSC00178.jpg
  • Name: 100_1253.jpg
  • Name: DSC00190.jpg
  • Name: DSC00172.jpg
  • Name: DSC00184.jpg
Old May 29, 2007, 02:06 PM   #4
Site Sponsor
jkarpy's Avatar
Wing Mount
Do not glue wing mounts to fuselage until after balancing.
  • Name: 100_1261.JPG
Old May 29, 2007, 02:06 PM   #5
Site Sponsor
jkarpy's Avatar
Tail Mount
Many of you have expressed confusion over how the tail mount goes together. This should clear things up.
UPDATE: The best configuration for the Micro SSX is to have the longest tail possible. Build the entire tail section and mount, wing and motor mount/ battery tray assembly. Assemble the entire plane without gluing the parts to the fuselage. That means all electronics installed also. Do not connect the rudder and elevator pushrods yet. Place the tail assembly as far out on the fuselage end as possible. Check the balance. If you are a good pilot, you will want the CG to be neutral. The neutral CG is about ¾” past the spar. Line-up the wing and tail and tack glue in place. Line-up the battery/ motor assembly and tack glue. Check all alignments and do your final gluing. Make sure the P12 is not glued to P12A.
  • Name: 100_1246.jpg
  • Name: Tail Mount.jpg
Description: Micro SSX Tail Mount: Note the fuselage stick does not extend all the way to the end of the mount. Micro SSX Tail Mount: Note the fuselage stick does not extend all the way to the end of the mount. 23.1 KB · Views: 427
  • Name: 100_1248.jpg
  • Name: 100_1267.jpg
  • Name: 100_1270.jpg
  • Name: DSC00187.jpg
  • Name: DSC00188.jpg
  • Name: DSC00189.jpg
  • Name: 100_1271.jpg
Old May 29, 2007, 02:07 PM   #6
Site Sponsor
jkarpy's Avatar
Landing Gear and Battery Mount
Reserved for Landing Gear and Battery Mount
  • Name: DSC00181.jpg
  • Name: 100_1276.jpg
  • Name: 100_1249.jpg
  • Name: 100_1250.jpg
  • Name: DSC00176.jpg
  • Name: 100_1278.jpg
Old May 29, 2007, 02:08 PM   #7
Site Sponsor
jkarpy's Avatar
Motor Mount
Reserved for Motor Mount
  • Name: 100_1274.jpg
Description: Glue together the two halves of the motor mount.
Note that the motor mount in the photo does not show a center hole in one of the pieces. Later models will have a larger hole in the outside half to accommodate the Hacker motor.
Glue together the two halves of the motor mount. Note that the motor mount in the photo does not show a center hole in one of the pieces. Later models will have a larger hole in the outside half to accommodate the Hacker motor. 42.2 KB · Views: 419
  • Name: DSC00179.jpg
  • Name: DSC00180.jpg
  • Name: DSC00183.jpg
Old May 29, 2007, 02:08 PM   #8
Site Sponsor
jkarpy's Avatar
Balancing
Balancing requires that the wing not be glued directly to the fuselage. You must be able to move the wing forward or aft on the fuselage for balancing. Install all gear, push rods and the battery before balancing. The balance point is 1/8th inch behind the main spar.
After the model is balanced, check to be sure the tail section is aligned with the wing and then glue the wing mounts to the fuselage using medium CA.
  • Name: 100_1280.jpg
Old May 29, 2007, 02:09 PM   #9
Site Sponsor
jkarpy's Avatar
Ready for final assembly
  • Name: DSC00193.JPG
Old May 29, 2007, 02:09 PM   #10
Site Sponsor
jkarpy's Avatar
Final Assembly
1. The CG for this model is 1/8” inch to the rear of the main spar. Balance the plane at the CG by holding wings with your fingertips as shown. Try to maintain the distance from the front fuselage to the leading edge of the wing at 2 1/8” by adjusting positions of your hardware first. If necessary, change position of your wing to balance.
Update: The best configuration for the Micro SSX is to have the longest tail possible. Build the entire tail section and mount, wing and motor mount/ battery tray assembly. Assemble the entire plane without gluing the parts to the fuselage. That means all electronics installed also. Do not connect the rudder and elevator pushrods yet. Place the tail assembly as far out on the fuselage end as possible. Check the balance. If you are a good pilot, you will want the CG to be neutral. The neutral CG is about ¾” past the spar. Line-up the wing and tail and tack glue in place. Line-up the battery/ motor assembly and tack glue. Check all alignments and do your final gluing. Make sure the P12 is not glued to P12A.
2. Once aircraft is balanced, adjust the horizontal stabilizer so it is parallel to the wing. Then glue the front and rear wing saddles to the fuselage stick.
3. Position servo, battery and motor mounts. Motor should have 2 ° of right and 2 ° of down thrust. This can be achieved by shimming the motor or by offsetting the motor mount during gluing. Glue the motor mount to the fuselage and battery mount using thick CA glue.
4. Square the vertical stabilizer to the horizontal stabilizer. Glue the vertical stabilizer to the horizontal stabilizer by bleeding thin CA into the mount.
5. Glue all control horns with thick CA.
6. Install control linkage. The E-Z connectors are for the aileron servo control horn. Feed the rudder and elevator pushrods through the rear pushrod guide before attaching to servos. Use Z bends for rudder and elevator servos. Be sure to center your servos first.
7. Permanently install receiver, motor and speed control. Make sure your antenna does not touch the carbon fiber fuselage or any metal. Use double stick foam tape to mount speed control to the top of battery mount.
8. Control throws are as follows:
Elevator: 45 ° up and down 20° low rate
Rudder: 45 ° left and right
Ailerons: 45 ° up and down 20° low rate
I recommend using expo if you have it!
Old May 29, 2007, 02:10 PM   #11
Site Sponsor
jkarpy's Avatar
Servo/Radio setup tips
1. Use the small arms for all servos.
2. Connect pushrods at outer most hole of control horns and servo arms.
3. Micro servo cases are typically press fit. The bottom can easily be pulled apart and if you don’t put it back correctly, you can ruin the servo. I recommend using a piece of clear tape and place it so that it straddles the bottom of the servo. This will keep the bottom from falling off.
4. Use a micro receiver such as the Berg 4L or Micro Spectrum receiver.
5. The spectrum receivers can easily be placed inside the wing between the center ribs.
6. The Berg 4L can be secured to the fuselage with a Velcro strap or tape.
7. Use a Micro antenna with the Berg 4L receiver if possible.
8. Do not allow your antenna to touch the fuselage or pushrods during flight. This can reduce the range of your receiver. The fuselage of the Micro SSX is carbon fiber, carbon is a conductor.
Tip: Run servos for several cycles before first flight. This will improve centering.
Old May 29, 2007, 02:10 PM   #12
Site Sponsor
jkarpy's Avatar
Micro SSX Build Kit.
This is the Micro SSX build it your self Kit. It is identical to the ARF version with some enhancements to make it easier to build. All the parts are laser cut and interlocking so no pins are needed to assemble this kit. The wing can be assembled in ½ an hour by most modelers.
Hardware included in kit:
4 micro control horns
2 Dubro micro light wheels
2 Dubro wheel retainers
Wire for push rods, aileron linkage and tail skid
Preformed wire landing gear
15” Wrapped carbon fuselage
Velcro pads
Velcro “One Wrap” Battery strap (RED)
Servo tape (Used to hold speed control in position)
6 # 0 - ¼ sheet metal screws (Servos)
2 # 1 – ¼ sheet metal screws (Motor)
  • Name: DSC00706.jpg
  • Name: DSC00709.jpg
  • Name: DSC00710.jpg
Old Jun 08, 2007, 09:02 PM   #13
Site Sponsor
jkarpy's Avatar
Micro SSX Wing kit Assembly
Please, no glue until told to do so.
Cover tail section and wing with light model covering such as World model Lightex or So light.
  • Name: DSC00715.jpg
Description: Cut, don’t break the balsa and plywood parts from the parts sheets. Breaking the parts out of the sheets can damage the parts. Remove all “W” balsa parts and P8, P9, P10 and P11 plywood parts.  Sand smooth the break points
Parts are prepped and ready for Cut, don’t break the balsa and plywood parts from the parts sheets. Breaking the parts out of the sheets can damage the parts. Remove all “W” balsa parts and P8, P9, P10 and P11 plywood parts. Sand smooth the break points Parts are prepped and ready for 50.7 KB · Views: 428
  • Name: DSC00716.jpg
Description: Assemble a frame from parts W1, W4 and W5. Use a small square to insure a square corner. Use thin CA at corners Assemble a frame from parts W1, W4 and W5. Use a small square to insure a square corner. Use thin CA at corners 46.4 KB · Views: 379
  • Name: DSC00717.jpg
  • Name: DSC00719.jpg
  • Name: DSC00720.jpg
Description: Install ribs W6 at wing tips. Bend the part slightly to fit. Install ribs W6 at wing tips. Bend the part slightly to fit. 37.3 KB · Views: 365
  • Name: DSC00721.jpg
  • Name: DSC00001.jpg
Description: Center ribs W2, servo deck P10, front wing saddle P11, P9 and main spar brace P8. Note P8 is no longer needed. Center ribs W2, servo deck P10, front wing saddle P11, P9 and main spar brace P8. Note P8 is no longer needed. 33.3 KB · Views: 372
  • Name: DSC00002.jpg
Description: Install the servo deck P10 so that the flush mounting tabs are closest to the spar. Install the servo deck P10 so that the flush mounting tabs are closest to the spar. 26.4 KB · Views: 342
  • Name: DSC00722.jpg
Description: Assembled wing center section from parts W2, P10 and P11. Assembled wing center section from parts W2, P10 and P11. 50.2 KB · Views: 331
  • Name: DSC00723.jpg
Description: Install Center section into the leading edge W4 Install Center section into the leading edge W4 45.8 KB · Views: 340
  • Name: DSC00724.jpg
Description: Insert remaining ribs W7 into the leading edge. Insert remaining ribs W7 into the leading edge. 63.4 KB · Views: 360
  • Name: DSC00725.jpg
Description: Install spar crutch W10, Use caution Install spar crutch W10, Use caution 60.0 KB · Views: 323
  • Name: DSC00726.jpg
Description: Sand smooth one side of the 3/32 spar sticks. Test fit them into the ribs. If sticks protrude beyond the ribs then sand the sticks till they are flush with the top of ribs. Center ribs on trailing edge and tack glue. Sand smooth one side of the 3/32 spar sticks. Test fit them into the ribs. If sticks protrude beyond the ribs then sand the sticks till they are flush with the top of ribs. Center ribs on trailing edge and tack glue. 38.2 KB · Views: 338
  • Name: DSC00727.jpg
Description: Hold spar stick in position and glue. Be sure that the spar stringers are butted up against the spar crutch W10. This forms a very strong “I” beam. Hold spar stick in position and glue. Be sure that the spar stringers are butted up against the spar crutch W10. This forms a very strong “I” beam. 63.7 KB · Views: 351
  • Name: DSC00728.jpg
Description: Install front wing saddle brace. Make sure front wing saddle is square to the wing frame and glue with thin CA. Install front wing saddle brace. Make sure front wing saddle is square to the wing frame and glue with thin CA. 53.1 KB · Views: 338
  • Name: DSC00729.jpg
Description: Install leading edge stringers top and bottom. Make sure they are flush and sanded before gluing. At this time it is OK to glue all remaining joints of the wing. Install leading edge stringers top and bottom. Make sure they are flush and sanded before gluing. At this time it is OK to glue all remaining joints of the wing. 47.6 KB · Views: 359
  • Name: DSC00732.jpg
Description: Remove excess spar stick and leading edge stringers. Remove excess spar stick and leading edge stringers. 50.9 KB · Views: 322
  • Name: DSC00733.jpg
Description: Sand flush with rib W6. Sand flush with rib W6. 49.2 KB · Views: 330
  • Name: DSC00734.jpg
Description: Prepare wing tip braces for installation. (Sand and Split) Prepare wing tip braces for installation. (Sand and Split) 32.4 KB · Views: 333
  • Name: DSC00736.jpg
Description: Bevel wide end of W9 before assembly. Bevel wide end of W9 before assembly. 25.1 KB · Views: 327
  • Name: DSC00737.jpg
  • Name: DSC00738.jpg
Description: Install servo deck cover. First glue to spar. Then, following the contour of rib; glue the trailing edge. Flip the wing over and glue the cover to the inside. Sand cover flush with trailing edge. Install servo deck cover. First glue to spar. Then, following the contour of rib; glue the trailing edge. Flip the wing over and glue the cover to the inside. Sand cover flush with trailing edge. 42.2 KB · Views: 310
  • Name: DSC00739.jpg
Old Jun 08, 2007, 09:02 PM   #14
Site Sponsor
jkarpy's Avatar
Tail Section
Tail Section:
  • Name: DSC00740.jpg
Description: Glue together vertical stab pieces S3 and S4. Prepare remaining parts to be covered. Remove burnt edges with 220 sand paper and round off corners. Stop sanding when burnt edge is faint. Do not distort the original shape of the part. Glue together vertical stab pieces S3 and S4. Prepare remaining parts to be covered. Remove burnt edges with 220 sand paper and round off corners. Stop sanding when burnt edge is faint. Do not distort the original shape of the part. 45.9 KB · Views: 356
  • Name: DSC00741.jpg
Description: Bevel leading edge of rudder S5 elevator S1 and ailerons W3 45 degrees. Bevel leading edge of rudder S5 elevator S1 and ailerons W3 45 degrees. 37.7 KB · Views: 340
Old Jun 08, 2007, 09:03 PM   #15
Site Sponsor
jkarpy's Avatar
Flight
Flight:
Micro speedwing build schoey Foamies (Kits) 46 Aug 08, 2005 11:22 AM
Micro Hydroplane Build Attemp thailandboy2 Racing Boats - Electric 27 Mar 17, 2005 03:52 PM
another Micro IFO build richw286 Parkflyers 19 Feb 24, 2005 12:05 PM
House of Balsa Micro Cub Build OCModels Parkflyers 52 Aug 29, 2003 11:47 PM
Micro-light Build Questiions DLC Parkflyers 5 Jun 22, 2001 03:17 PM
Bored? Want to fight?
Join the RCGroups clan!
