Old May 28, 2007, 10:43 PM
jrhyne is offline
Find More Posts by jrhyne
baltimore
Joined Apr 2007
ESC, programming
Hi, obviously, by the question to come, I'm very new. Anyway, what's the deal with programming the ESCs?
I see that some vendors sell cards to do this, but why and how? Isn't my throttle proportional to start with?
Thanks, sorry for the embarrassingly newbie question.....
jrhyne is offline Find More Posts by jrhyne
Old May 28, 2007, 10:48 PM
ratb is offline
Find More Posts by ratb
ratb's Avatar
Joined Jan 2007
It's not the proportionality of the throttle you program. It's other behaviors of the ESC.
I have a Castle Creations Pixie-20 brushed ESC that is programmable in a variety of ways. You can program the voltage at which the Low Voltage Cutoff will engage. You can program the behavior of that cutoff ("hard" or "soft"--I don't remember what those mean, but I remember I liked the default). You can program one other behavior that I can't remember what it is...
It's a "set it and forget it" kind of deal (obviously!) and they generally come with pretty smart defaults.
ratb is offline Find More Posts by ratb
Old May 28, 2007, 10:51 PM
jrhyne is offline
baltimore
Joined Apr 2007
So these things are pretty easy to program? I'm so new that most of this makes just enough sense to me that I'll be dangerous!!
Old May 28, 2007, 11:30 PM
keyman923 is offline
Find More Posts by keyman923
Former Futaba employee
Joined Aug 2006
most of the program cards are real inexpensive and some work for more then just 1 brand of esc. I think jeti-dynam-pulso and some others use the same card
keyman923 is offline Find More Posts by keyman923
Old May 29, 2007, 01:06 AM
NoFlyZone is offline
Find More Posts by NoFlyZone
Joined Jul 2006
Hi jr,
First off, there's no such thing as a stupid question!
"Programming" esc's is usually done right at your transmitter. To "program" an esc means that you make certain decisions about how you want the esc and motor and battery to interact. When you plug in your esc, and go into programming mode, the esc will use a series of audible sounds and blinking lights to "ask" you things like "What size battery are you using?" To answer the question, you most often use the left stick of your transmitter by moving it into different positions as a way of answering the esc's question.
Then the esc might ask you a different question with it's sounds and lights, like "Do you want me to shut your motor completely off when I detect a dangerously low battery voltage?" And then again, you answer the question by moving the left transmitter stick to a certain position to indicate yes or no.
Now, based on what I've said above... programming an esc looks akin to building a nuclear reactor. But take it from me (and I'm no rocket scientist), once you go through the step by step directions that come with all esc's... you will find it pretty darn simple...
Some esc's come with the ability to answer all these questions from a computer software program. These are the esc's that use either 'card programming' or 'regular transmitter stick programming'.
In either case, it's something that you will find very do-able!
Chuck
NoFlyZone is offline Find More Posts by NoFlyZone
Reply With Quote  (Disabled)
Old Nov 10, 2011, 08:18 PM
larrytoo is offline
Find More Posts by larrytoo
Joined Nov 2011
Programming FUTUR(E) ESC, HOW?????
I just purchased a Dymond FUTUR(E) programmable ESC but I came with only instructions for the battery type selection. (SUpplier cannot/willnot provide assistance)
It is advertized to be programmable by "stick" as to throttle, softstart, brake, timing, autocutoff, and cutoff.
How do I enter programming mode? How do I program each function??
HELP
I'm new to electrics though not to R/C.
Larry
larrytoo is offline Find More Posts by larrytoo
Old Nov 11, 2011, 07:48 AM
flypaper 2 is offline
Find More Posts by flypaper 2
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
I always had trouble trying to use the trans. to program but would get the beeps mixed up and lose it. Went to the Turnigy ESCs that use the card and it was the best thing since sliced balony for my feebly mind. 8 different parameters you can program including music, to drive your fellow fliers nuts. I'm sure other cards can do the same thing. Thing is, you can see what you've done.
http://www.hobbyking.com/hobbyking/s...idProduct=2169
Gord.
flypaper 2 is offline Find More Posts by flypaper 2
Old Nov 29, 2011, 04:59 PM
Glenstr is offline
Find More Posts by Glenstr
Glenstr's Avatar
Canada, AB, Lac La Biche
Joined Aug 2010
I was wondering this same thing, what would be a good all round card / program for programming ESC's? I have never programmed one before, but now what I have several planes and a couple of quads, I'm thinking that learning to program ESC's is probably a prudent thing to do. I mostly have Turnigy plush ESC's, but also have the stock ones on my Gaui 300x-s, another for my Super Cub which brand escapes me at the moment, and a Pulso.
The card flypaper mentions looks good, for the price of it I'm tossing one in my next order, but are there other programs as well that are more or less suitable for most, if not all ESC's?
thanks!
Glenstr is offline Find More Posts by Glenstr
Old Nov 29, 2011, 05:38 PM
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
The programming cards will only work with their particular ESCs. The one shown above will work with your Turnigy Plush, and is one of the ESCs I use the most in all different amp ratings.
Gord.
Old Nov 29, 2011, 05:48 PM
fmw is offline
fmw
Find More Posts by fmw
fmw
fmw's Avatar
Joined Jul 2009
If it helps, I have never programmed an ESC. I just plug them in and use them. I've owned about 25 planes without so much as a hint of a problem.
fmw is offline Find More Posts by fmw
Old Nov 29, 2011, 10:59 PM
PyroMan is offline
Find More Posts by PyroMan
PyroMan's Avatar
United States, KY, Paducah
Joined Mar 2011
The defaults on ESCs are normally just what ya need. But sometime you may want to change some stuff.
I have a Castle Creations thunderbird18 and I can . . .
Turn the brake on or off - this means do you want the esc to let the motor freewheel when you turn the throttle to zero or do you want the esc to hold the motor in one position and not spin with zero throttle
LVC (low voltage cutoff) - I think I can change the voltage per cell that triggers the esc to cutoff
Hard or soft cutoff - hard is where the motor stops all at one when the battery voltage drops to a specific point and soft is when the motor slowly starts loosing power. Even when the LVC is activated you will still have control of your servos to glide the plane in.
What kind of battery - I tell what battery I'm using such as a lipo or a nimh
I think that's about it.
Hole this helps,
Nicholas
PyroMan is offline Find More Posts by PyroMan
Old Nov 30, 2011, 12:12 PM
Gedexas is offline
Find More Posts by Gedexas
CP heli ≠ 3D heli
Gedexas's Avatar
United States, NJ, Point Pleasant Beach
Joined Mar 2009
Most ESCs can be programmed without a programming card, most of the time a programming card is for convenience only.
Gedexas is offline Find More Posts by Gedexas
Old Dec 01, 2011, 08:42 PM
mmaxfield is offline
Find More Posts by mmaxfield
United States, VA, West Springfield
Joined Sep 2011
Sebart mig 29 esc programming
I have a SEBART MIG-29. Any one know what manufacturer/model ESC are used and how to get programming instructions for them? None came with the airplane.
mmaxfield is offline Find More Posts by mmaxfield
Old Dec 01, 2011, 09:10 PM
Gedexas is offline
CP heli ≠ 3D heli
Gedexas's Avatar
Joined Mar 2009
I bet it's another hobbywing clone, but if you took a picture of it, there will be a more accurate description.
Old Dec 05, 2012, 12:32 AM
lancaster1945 is offline
Find More Posts by lancaster1945
Australia, NSW, Bankstown
Joined Jul 2012
programing ESC
Hi there,
can anyone help me regarding programing the ESC so i can get more punch from my RC car the default rate is 75% but want to give it 100% punch as i just bought a new Nano Tech Turnargy Lipo battery as i can do this without a program card.
thxs
lancaster1945 is offline Find More Posts by lancaster1945
Castle Creations 35A ESC Programming Orion_V Electric Heli Talk 9 Aug 06, 2003 12:35 PM
phoenix 25 esc programming? Ryan Nau Power Systems 1 Jun 25, 2003 04:28 PM
Schulze Future ESC programming question? Steph280 Electric Heli Talk 9 Mar 14, 2002 02:51 AM
Kontronic Smile ESC programming gpeden Electric Heli Talk 15 Jan 01, 2002 01:29 PM
Kontronik esc - programming Kyri Electric Sailplanes 3 Jun 15, 2001 08:39 AM
