Old Jul 28, 2007, 11:34 PM
erich is offline
Find More Posts by erich
erich's Avatar
Holden , Massachusettes
Joined Feb 2004
Jack
Am not totally sure what you mean? But am assuming (usually not a good idea) you mean drawing up plans for the fuselage. If that's what you mean the answer is no. Have never done anything like that.
erich
erich is offline Find More Posts by erich
Old Jul 28, 2007, 11:36 PM
erich is offline
erich's Avatar
Joined Feb 2004
Got left side of fuselage covered. Used 1 full sheet cut to width, to do the side. The nose area took a little more persuasion, then the rest, but finally got it to look acceptable. Will probably end up doing the fuselage, using 4 separate pieces of covering. Gettin there...
erich
Old Jul 30, 2007, 02:16 AM
erich is offline
erich's Avatar
Joined Feb 2004
Fuselage Covered
After covering 2nd side of fuselage in the same way as first, added sheet from back of hatch to fin, then full length bottom piece. All that remained was a very small wedged shaped piece from nose to front of canopy. Soon as I finished covering fuselage, screwed down canopy for first time (since covering). Stood back and admired my imitation glass fuse. Only thing I would do different is add a little more balsa to top rear deck from back of canopy to fin. This to get a little more rounded look. With the covering on, the fuse has a somewhat flat look in this area, which wasn't as apparent before the covering went on. From the wing LE forward it looks real good. All in all fuselage came out looking very good.
Sooo.....time for the wings, one of my least favorite things to cover.
erich
Old Jul 30, 2007, 08:14 PM
schrederman is offline
Find More Posts by schrederman
Hot Dawg Glider Pilot
schrederman's Avatar
United States, TX, Weatherford
Joined Nov 2002
I don't see any flies on that one... (a compliment in West Texas)
Jack
schrederman is offline Find More Posts by schrederman
Old Jul 31, 2007, 06:06 AM
erich is offline
erich's Avatar
Joined Feb 2004
Well pardner, am hopin to git a lotta flys on this un.
erich
Old Aug 02, 2007, 05:32 AM
erich is offline
erich's Avatar
Joined Feb 2004
Hinged Rudder
Still working on covering the wings with the Trans. Blue. For a little change, decided to hinge rudder. Glued hinges to rudder first, using 30 min epoxy (applied, sparingly). Then made sure rudder was absolutely centered on fin, and glued in with 30 min epoxy (used, sparingly). Afterwards sealed hinge line with 1/2" White Ultracote strips on both sides.
erich
Old Aug 02, 2007, 06:55 AM
merlinmurph is offline
Find More Posts by merlinmurph
Dan Murphy
USA, MA, Hopkinton
Joined Mar 2006
That is one sexy tail section. Gorgeous work, erich.
merlinmurph is offline Find More Posts by merlinmurph
Old Aug 03, 2007, 01:47 AM
erich is offline
erich's Avatar
Joined Feb 2004
Rudder Control
Well....connected up the pull-pull, rudder control rod (er...string). Tied off the rudder control horn, using 3 knots (which I don't know the names of) per string, and adding a little thin CA to keep them from unravelling. At servo end tied kevlar lines the same way, to a threaded eyelet. Added a lock nut and screwed eyelet into a metal clevis. Added a little tension to strings, and rudder is all done. Now only control left to hook up, is the spoilers, if I ever get done covering these wings. Added small 1/16" ply tail skid, by making slot into bottom sheeting, glued (titebond) skid between the bottom longerons and to sheeting, to give it good support. Stained it with some polyurethane (antique walnut).
erich
Old Aug 03, 2007, 01:55 AM
erich is offline
erich's Avatar
Joined Feb 2004
merlinmurph
Thanks merlin....but I only slap wood against wood, Jack Womack is the man who should get the credit for coming up, with such a good looking tail. Butt....if you think the tail looks good, wait till you see the fuselage with the WINGS.
erich
Old Aug 04, 2007, 07:03 AM
erich is offline
erich's Avatar
Joined Feb 2004
Wing Covering
All the Trans. Blue, on wing is done. Did each wing in six sections 3 on top 3 on bottom. Basically one piece for each dihedral break. Left 1/8" gap at TE and 1/4" at LE. Will wrap each of these areas, with White covering. Before adding the wing covering cleaned wing with damp cloth, to get rid of any dust. Took almost a week to get all the blue on the wings, just did 2 sections a day.
erich
Old Aug 04, 2007, 07:32 AM
sawman is offline
Find More Posts by sawman
Air Crash Expert
sawman's Avatar
Louisiana
Joined Oct 2005
Nice , straight structure. Smooth , wrinkle-free covering.
You make me sick !
JUST KIDDING ! Very nice build.
Your an inspiration to those of us who try and end up with something that looks like its already exploded during a zoom launch.
Many kudos.
sawman is offline Find More Posts by sawman
Old Aug 05, 2007, 08:40 AM
erich is offline
erich's Avatar
Joined Feb 2004
Thanks....it's more likely due to retouching the photos. Though using ultracote, does help, as does lotsa practice.
Sorry to hear about you being sick. Just kidding.....er.....I mean no kidding. Have made more than my share of planes that look like they belong in a geriatric ward. Anywho, am glad the covering job is just about done.
green air
erich
Old Aug 05, 2007, 07:16 PM
Captain Canardly is online now
Find More Posts by Captain Canardly
who has rabbit ears down
Captain Canardly's Avatar
United States, MN, Buffalo
Joined Jan 2007
That is quite gorgeous there, Erich!
That's the fun of wood! Keep it up!!
Johnny
Captain Canardly is online now Find More Posts by Captain Canardly
Latest blog entry: Have a laugh on me!
Old Aug 05, 2007, 09:12 PM
Joined Nov 2002
Those Hawk wings are really beautiful... and YES... I am a bit prejudiced...
Jack
Old Aug 06, 2007, 12:25 AM
erich is offline
erich's Avatar
Joined Feb 2004
We all tend to be (prejudiced). Jack, being a pilot, did you ever get a chance to fly a Libelle? Or seen one fly? It's the only full size plane that looks better than all the rest. Guilty to being prejudeced here, too. Had a chance to buy one, back in '88, but blew it! Fell in love with that plane watching a John Denver video, in which he flys a 102. One of these days gonna build a scale Libelle. Also a Cherokee (3rd best looking glider), and a Schwiezer 1-23 (the 2nd best look plane). Pardon the digression.
Thanks, Captain C, thanks, Jack. The Hawk wings are comin along, just a little more trimming to be done.
green air
erich
The Houston Hawk Project - Part 2 Mauilvr Thermal 1042 Apr 01, 2016 07:15 AM
Anyone selling in the bone kits of a ruby or a houston hawk Lite2bolt Thermal 3 Dec 10, 2004 10:03 AM
The Houston Hawk Project schrederman Thermal 1004 Nov 23, 2004 02:01 AM
WTB: Houston Hawk Short Kit and/or Condor fuse thelocust Aircraft - Sailplanes (FS/W) 0 Aug 31, 2004 12:49 PM
