Oct 29, 2002, 03:06 PM
Seminole (St Pete.), Florida/ Seminole Crash Fest
Joined Jun 2002
hi hague
i noticed as i set up zero# 1, that i had set the elevator surface flush to the top of the hor. stab= zero 1 had the pull up stall tendency
on zero #2 i set the elevator surface flush to the bottom of the hor. stab and it seemed to pretty much take away the stall up tendency
i then noticed that the stab /elev surface seemed to be more symetric that way too, as if it were meant to be that way
had mine flying again this weekend after a 3 week rebuild and reconfigure of some things, without trimming it flew almost flat and level at 3/4 throttle and of course at full throttle she climbed..but not as bad also set up exponential nad dual rates
seemed to help alot on the overroll/ overcontrol problem i had even with throws set at 1/8" on ailerons
the rest is in the final trimming for me now
Belgy
