Old May 26, 2007, 10:20 AM
emb145drvr is offline
Find More Posts by emb145drvr
emb145drvr's Avatar
Houston, TX
Joined Feb 2006
The Sh#t Stick
Guys,
I got bored while cleaning the garage yesterday and got creative with some blue core. I maidened her this morning and she flys great . Let me know what you think. This is my first scratch build from foam, and I really enjoyed it.
emb145drvr is offline Find More Posts by emb145drvr
Old May 26, 2007, 11:14 AM
Flyer X is offline
Find More Posts by Flyer X
Flyer X's Avatar
In DEBT
Joined Aug 2006
You got the name right on that one.JK The way I see it is, who cares how pretty it is while on the ground. They all look good when in the air.
Flyer X is offline Find More Posts by Flyer X
Old May 26, 2007, 11:27 AM
emb145drvr's Avatar
Houston, TX
Joined Feb 2006
thanks,
She isn't a looker by any means. But talk about STOL flying. No rollout at all on landing. She basically hovers to a stop
Old May 26, 2007, 11:34 AM
callmeishmael is offline
Find More Posts by callmeishmael
AMA 42867
callmeishmael's Avatar
Joined Nov 2003
Congrats on your first scratchbuilt! Flyer X has the right of it: They all look great in the air.
callmeishmael is offline Find More Posts by callmeishmael
Old May 26, 2007, 11:46 AM
youth must fly is offline
Find More Posts by youth must fly
feel no remorse
youth must fly's Avatar
underground
Joined Jun 2004
I like the plane, but i dont like the way your top wing carbon rod is held in place. It look like it holds on with hot glue on both ends of the rod along with a middle riser. Chances are if you land bad the rod will give it away and brake off. You might wanna attach the rod more to the wing
Tom
youth must fly is offline Find More Posts by youth must fly
Old May 26, 2007, 12:33 PM
emb145drvr's Avatar
Houston, TX
Joined Feb 2006
Thanks for all the kind words. Tom, I was thinking the same thing but I'm not exactly sure the best way of securing the rod. Any ideas?
Old May 26, 2007, 12:38 PM
JWilliams2 is offline
Find More Posts by JWilliams2
JWilliams2's Avatar
NY State
Joined Jan 2007
I like how you have a spacer on the top strut, I had not thought of that and it would probably have been suitable for my current plane.
Even if the carbon rips, you can put it back on later, but what would work is some credit card into the wing with a hole that the carbon feeds through. That way as its trying to lift up from the wing, it's got to pull the credit card, which is embedded in the wing with epoxy.
JWilliams2 is offline Find More Posts by JWilliams2
Old May 26, 2007, 03:30 PM
emb145drvr's Avatar
Houston, TX
Joined Feb 2006
Bad news. The sh#t stick killed my outrunner motor. The winds were dead calm and she seemed to really be hanging off the prop. I did a couple of circuits around the patch and a couple of landings. On one of my last patterns the motor seemed to be making a funny noise. On short final a puff of smoke came from the motor and I had to dead stick her in. I think the wing just would not produce enough lift. I think I'll try another this time the wing will have much better camber.
Old May 26, 2007, 03:32 PM
feel no remorse
underground
Joined Jun 2004
So the motor is toast now, looks like you pushed it to the limit
Old May 26, 2007, 04:15 PM
goldguy is offline
Find More Posts by goldguy
flyin' fool
goldguy's Avatar
Vancouver Island, Canada
Joined Jul 2003
I like the name...good one.
Auctually, installing CF tubes and rods with tension, as in bent, make them less flexable. If you install one as a flush wing spar, put a bow shaped slot into the foam and then fire up the hot melt. Now you can use smaller and lighter CF.
If your using wire or CF for pushrods, make sure they are also bowed by adding a bearing support at the half way point. For stays I use round paper clips that have an eye bent into them.
goldguy is offline Find More Posts by goldguy
Old May 26, 2007, 04:28 PM
goldguy is offline
flyin' fool
goldguy's Avatar
Joined Jul 2003
EMB: The Sh#t Stick, what a great name, I like it. What you need is the 'modeller's Swiss army knife' .......a wattmeter. You'll save it's cost in short order in not frying your electronic gadgets and best of all, get the right prop installed for your setup.
Auctually, installing CF tubes and rods with tension, as in bent, make them less flexable. If you install one as a flush wing spar, put a slight bow shaped slot into the foam and then fire up the hot melt. Now you can use smaller and lighter CF.
If your using wire or CF for pushrods, make sure they are also pre-tensioned or slightly bowed by adding a bearing support at the half way point. For stays on CF I use round paper clips that have an eye bent into them. For metal PRs, you'll need a plastic or nylon bearing.
Old May 26, 2007, 04:41 PM
emb145drvr's Avatar
Houston, TX
Joined Feb 2006
Thanks for the tips goldguy. Are there any tips or how to's on building with the blue core you can buy at home stores. I like the stuff because it's cheap and readily available. I'm planning on trying to build a Antonov AN-2 soon.
Old May 26, 2007, 06:24 PM
Buzz_Man is offline
Find More Posts by Buzz_Man
Fly safe, fly often!
Buzz_Man's Avatar
United States, GA, Powder Springs
Joined Dec 1999
Awesome bike - I'd rather mountain bike but road riding is great too.
Interesting plane - sorry abou tthe motor - can it be rewound - is the ESC okay?
Buzz_Man is offline Find More Posts by Buzz_Man
Old May 26, 2007, 07:36 PM
emb145drvr's Avatar
Houston, TX
Joined Feb 2006
Buzz Man,
roadie hun. I keep telling myself I'm going to get a road bike for better training but I have never gotten around to it . Also how do you rewind motors? As far a the ESC I think it still works fine. I hooked it back up just to see what the motor would do and the ESC seemed fine. The motor on the other hand just kind of stutters and won't get going.
Old May 26, 2007, 08:02 PM
feel no remorse
underground
Joined Jun 2004
Take a look here it might give you some ideas
http://www.rcgroups.com/forums/showthread.php?t=648927
now that i am on a 30 the HB flys like SH*T! obin Micro Helis 9 Aug 18, 2009 03:04 PM
Discussion Solite won't stick to itself FlagstaffFlyer Flying Wings 6 Apr 29, 2006 06:44 PM
Which one to choose!!!????? SH*T! webnetxpress Micro Helis 13 Jun 24, 2004 10:29 PM
Rant CA, why doesn't it stick? Norman Adlam Electric Plane Talk 25 Feb 15, 2004 03:57 PM
Help! Hinge tape won't stick... chrisl Foamies (Kits) 1 Aug 16, 2002 07:44 PM
