May 26, 2007, 11:52 AM
Dickinson, Tx.
Joined Sep 2004
I read many posts about the non-benefits that balancing a pack after a cycle (flight) so I stopped and only balance during a charge.
When I am parallel charging (4) 4S1P 2100 or 3S1P 2100 packs at the same time when (I am in a hurry), I will use the (2) LB6A's as "bleeders" where I will charge thru the Deans and switch the balancers between packs. If I am only parallel charging (2) packs, then I will balance charge thru the LB6A's.
There are problems associated with using them as bleeders where a cell could still be over charged, but I am willing to take that risk, also I am charging at 1.75 amps on each 2100 pack as my 109 will max out at 7.55 amps, I back it down to 7 amps when parallel charging (4) packs at the same time.
Challenger413
