Old May 25, 2007, 01:58 PM
Tram is offline
Find More Posts by Tram
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
Painting EPP?
Hey guys,
Just curious what everyone is using to paint EPP?
Anyone using Apple Barrel paints airbrushed on?
Jeff
www.CommonSenseRC.com
Tram is offline Find More Posts by Tram
Latest blog entry: Wow.. 3 years..
Old May 25, 2007, 02:27 PM
cactus is offline
Find More Posts by cactus
cactus's Avatar
United States, CO, Durango
Joined Sep 2001
Hi Tram
I have used Krylon plasic spray paint with good results.
cactus is offline Find More Posts by cactus
Old May 25, 2007, 02:51 PM
VictoryRoll-91 is offline
Find More Posts by VictoryRoll-91
You land foamies?!
VictoryRoll-91's Avatar
Livonia, Michigan
Joined Feb 2007
Sharpie markers.
VictoryRoll-91 is offline Find More Posts by VictoryRoll-91
Old May 25, 2007, 03:13 PM
Hivoltage is offline
Find More Posts by Hivoltage
Newark Ohio
Joined Sep 2001
Any spray paint seems to work well......I especially like to use the flourescent colors.
Hivoltage is offline Find More Posts by Hivoltage
Old May 25, 2007, 05:46 PM
Pedroski is offline
Find More Posts by Pedroski
UK
Joined Jul 2006
Multiplex make a product called Multiprimer for Elapor and EPP. When I use this stuff and then Createx paint over the top it doesn't chip or flake even with a finger nail and enough pressure to dent the foam.
Without the primer any paint I've used on EPP will scrape off with a finger nail.
I'll put a link up of what the tin looks like
EDIT: On well handled areas like the canopy I put a couple of coats of Createx Gloss Clear Coat over the top which protects the paint against wear over time. Just remember to either use a hot air blower to dry each coat if you air brush it on (or it dries cloudy - though you can brush it on and leave it to dry naturally ok).
EDIT #2 What it appears to do is slightly melt the surface of the foam so when it is dry it is bonded firmly to the foam. Your paint (I assume most types will work the same as Createx) then bonds to this new surface. as long as you don't put it on really thick your EPP surface is not changed. Put too much on and you get little ridges and dimples (but that is really laying it on thick and you have to try to get this effect and it is negligible...).
Pedroski is offline Find More Posts by Pedroski
Old May 26, 2007, 09:42 AM
DACeller is offline
Find More Posts by DACeller
Joined Jun 2005
Or use Design Master paints; their propellant doesn't affect ANY foam. Can be found at Michaels arts&crafts.
DACeller is offline Find More Posts by DACeller
Old Jun 26, 2007, 12:01 AM
JMSTECH is offline
Find More Posts by JMSTECH
JMSTECH's Avatar
Canada, BC, Duncan
Joined Dec 2006
Can this Multiprimer for Elapor and EPP be purchased in North America? I haven't seen anyone online as of yet who does offer this product. Or are there?
JMSTECH is offline Find More Posts by JMSTECH
Old Jun 26, 2007, 12:09 AM
Doubletap is offline
Find More Posts by Doubletap
Si Vis Pacem Para Bellum!
Doubletap's Avatar
United States, CA, El Segundo
Joined Jul 2005
I had enquired about this product on the Hitec/Multiplex forum and was told it is only available to the EU market.
My experience with both EPP and Elapor is nothing really sticks to it permanently, and it's easily peeled off with tape.
Doubletap
Doubletap is offline Find More Posts by Doubletap
Old Jun 26, 2007, 01:21 AM
JMSTECH is offline
JMSTECH's Avatar
Canada, BC, Duncan
Joined Dec 2006
I was afraid of that. Hmm I read somewhere but can't remember where that if we rubbed alcohol it would remove the residue that is used to pop the foam out of the mold. Then regular oil base primer could be used to paint over it. Of coarse a light sanding must be done first. Do you know if anyone else tried this successfully yet? I'm suppose to receive my Easy Star soon and personally I would like to change the stock blue and white color scheme to a more British Spitfire look. (one of my favorite! )
Old Jun 26, 2007, 09:47 AM
JamiePhoto is offline
Find More Posts by JamiePhoto
JamiePhoto's Avatar
USA, TX, Dallas
Joined Feb 2006
Krylon Fusion sticks like snot
I used it on a Slofly 28 SuperSlo. It even stuck to strapping tape. I can't scratch it off with a fingernail.
Since it is made for plastics that flex (plastic patio chair), it moves with the foam. Also seemed to add some strength and stiffnes to the foam.
On the other hand, the flex ingredient may weigh more than a water based paint.
The "Pepper Red" is a great color.
Got it at Michaels craft store with the weekly 40% off 1 item.
Stay Cool,
Jamie
JamiePhoto is offline Find More Posts by JamiePhoto
Old Jun 26, 2007, 10:32 AM
MarkJayne is offline
Find More Posts by MarkJayne
Part-Time Super Hero
MarkJayne's Avatar
Aberystwyth, UK
Joined Sep 2004
Flair's Spectrum paints seem to work really well http://flairmodels.co.uk/Finishing/Spectrum.htm
Mark
MarkJayne is offline Find More Posts by MarkJayne
Old Jun 26, 2007, 03:02 PM
Duf is offline
Duf
Find More Posts by Duf
Duf
Duf's Avatar
Florida
Joined Aug 2002
Originally Posted by cactus
Hi Tram
If Cactus says it works, it works!
Duf is offline Find More Posts by Duf
Old Jun 27, 2007, 12:06 AM
JMSTECH is offline
JMSTECH's Avatar
Canada, BC, Duncan
Joined Dec 2006
WOW !!! Great response here! Many thanks !
Mark, unfortunately I've never seen that product in Canada. But the Krylon is available at my friend's paint store across the street from my shop! I've used their water based stuff on my 1st generation Twinstar and it didn't stick very well to the old school foam. But now that I have seen actual proof from Jamie, I feel confident on trying out their oil base primer on my elapor Styro Easystar! (I think Micheals got it on unsale here in Canada . ( BTW JAMIE... NICE PAINT JOB!! ) I've got some Tamiya paint which I like to put over the Krylon primer. (Tamiya has nice WW2 colors) Thanks again everyone for the great response!!!!!
John
Question Painting EPP zippogeek Foamies (Kits) 9 Mar 21, 2015 11:57 AM
Discussion decorating and painting EPP poker_run Foamies (Scratchbuilt) 5 Aug 12, 2007 09:03 AM
