Oct 29, 2002, 06:02 AM
Punta Gorda, FL
Joined Apr 2002
Just to amplify on what Ade said. The control arm with ball kink assembly has to be located along the hinge line so that the ball link falls in line with the pushrod from the servo. Mark the control surface for drilling to take the "L" bend. The "L" bend is too long and should be cut back to about 1/2 inch in length so that the hole in the control surface won't have to be so deep. When drilling for the wire to go into the control surface, aim the drill so that it does not penetrate the surface. Make a groove from the hole to the inboard end of the control surface to epoxy the wire into the control surface leading edge including the epoxy in the hole. Be careful not to get any epoxy onto the hinges. Masking tape can be used to shield the hinges and the covering material from epoxy. Carefully wipe away any excess epoxy.
