Old May 23, 2007, 07:37 PM
KenP is online now
Find More Posts by KenP
St. Louis, MO
Joined Oct 2002
Question
Dual motor rpms how close is close enough?
I have a dual pusher plane with two Mega 16/14/4's and Castle creations Pheonix 25s.
I tached the motors tonight and one motor is 300 rpm slower then the other. I do have mixing to the rudders and I have tried to trim the rpms but that has not worked. So how close do duals have to be to get a nice straight flight?
KenP is online now Find More Posts by KenP
Old May 23, 2007, 08:24 PM
Sabrejock is offline
Find More Posts by Sabrejock
Sabrejock's Avatar
Winnipeg, MB Canada
Joined Jan 2000
Switch props and try it again. If the same motor is fast, switch esc's. If the same motor is fast, start trimming the slow prop by carefully shortenning it and rebalancing. Tex
Sabrejock is offline Find More Posts by Sabrejock
Old May 23, 2007, 08:56 PM
Al Offt is offline
Find More Posts by Al Offt
Boston, MA subburb
Joined Sep 2004
Great suggestion about trimming the prop (on the slower motor) to balance motor rpm. I intend to run brushed motors wired in parallel and would never have thought to do that.
Al Offt is offline Find More Posts by Al Offt
Old May 23, 2007, 10:55 PM
KenP is online now
St. Louis, MO
Joined Oct 2002
Before I go shortening props, what is considered a good range for rpms? Of course dead on is best but what is close? With the props I have now there is roughly a 2mph difference.
Old May 23, 2007, 11:03 PM
morphs is offline
Find More Posts by morphs
morphs's Avatar
UT
I just finished a twin of my own and my rpm's were off about the same as yours. I made a phone call to someone who is experienced in twins and he said 300 rpm difference is fine. 3,000 rpm would be something to worry about.. I would just fly it and see what you think.
-Jon
morphs is offline Find More Posts by morphs
Old May 23, 2007, 11:49 PM
dmiller746 is offline
Find More Posts by dmiller746
I havent decided yet
Indiana
Joined Jun 2006
if you shorten a prop to make it spin the same rpm as a larger one, it would make less thrust. i think that would make the problem worse. 300 rpm difference is ok if we are talking 30,000 rpm but at 1,000 it might be a problem.
dmiller746 is offline Find More Posts by dmiller746
Old May 24, 2007, 05:47 AM
Sabrejock's Avatar
Winnipeg, MB Canada
Joined Jan 2000
Prop Sync
I'm thinking mainly of the sound. Nothing worse to a full scale pilot's ears than out of sync props! Tex.
Old May 24, 2007, 07:16 AM
KenP is online now
St. Louis, MO
Joined Oct 2002
Oh the props sound like they are in sync, which is the reason I tached them. So sounds like I am good to go then.
Discussion How to mount a close fitting motor?? nakman8 Electric Sailplanes 2 May 01, 2006 10:09 PM
INTERFERANCE? How close is CLOSE? HELP!!!! wollins Electric Plane Talk 2 Jan 21, 2005 08:54 AM
Question How close is to close to a receiver? spudandretti Micro Helis 1 Nov 11, 2003 07:30 AM
