Old May 22, 2007, 12:04 PM
Vyceroy is offline
Find More Posts by Vyceroy
G G Ghost Pirates !!!
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
Build Log
Mini Boeing 314 Clipper
I Have a build of this plane posted in waterplanes but thought i would post it here also ..(More Traffic Here)
A local Flying Buddy (Wombat) gave me a hot wire cutter (Thanks Wombat)
I have been cutting bluecor in half thinckness wise .. 3mm Bluecor is a dream to work with in the smaller scales
I had been thinking about what to design and build next for my summer float plane flying and i had first thought about the Consolidated Coronado .. or many other giant flying boats.. I finally decided the 314s lines and over all exaggerated lines would be a good place to start
I have a few other projects going so i havent been able to devote as much time to her as i would like
Here are the specs .. Wingspan 32 inches .. Wing undercambered ..
Power 4 GWS EDP-50 brushed motors .. 3x2 props
Battery will probably be a 700 mah 2 cell poly (Only battery i have that small)
Here are a few pics of progress already made ..
Vyceroy is offline Find More Posts by Vyceroy
Old May 22, 2007, 12:44 PM
Beemus is offline
Find More Posts by Beemus
The Dude Abides
Beemus's Avatar
Brockport
Joined Sep 2005
Cool man!
How you gonna waterproof the whole thing?
Beemus is offline Find More Posts by Beemus
Old May 22, 2007, 12:50 PM
Vyceroy is offline
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
Believe it or not really wont need it .. the foam has such a high bouyancy(sp)
the water will barely come up to the hull line .. But.. i will run a little Probond along the seams to provide waterproofing but more importantly Strength along the joints .. plus im going to cover her with Ultracote silver ..
Old May 22, 2007, 12:53 PM
UBILDIT is offline
Find More Posts by UBILDIT
Victoria Super Mortem
UBILDIT's Avatar
BIRMINGHAM ALABAMA
Joined Jan 2006
Recent Graduate?
Good to see you back in the DIY section Mr. Brady. Plane is looking good. But having recently graduated from High School, I think I can blow you away with my BE-200 Edf waterplane.... So there it is... the Gauntlet has been thrown down, the gloves are off....it's a battle to the ....... water.
Professer Ubildit
UBILDIT is offline Find More Posts by UBILDIT
Old May 22, 2007, 01:00 PM
Vyceroy is offline
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
Arent you supposed to be at work old man?? .. BE-200 good luck with that bro .. if ya need any help doing the plans for that let me know ..
And of course the way you sling fan blades i have no worries about getting into the water first .. i think you should go with 5-6 cells on that EDF 64 ..
Have your coffee yet today??
Old May 22, 2007, 07:56 PM
Vyceroy is offline
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
Dihedral has been cut into the wings and Wing halves are glued together ..
I need to work out a wing mounting system then cover the fuse and wings .. stay tuned for more pics ..
Old May 23, 2007, 10:16 AM
bob_suruncle is offline
Find More Posts by bob_suruncle
I think I can glue that..
bob_suruncle's Avatar
Paris, Ontario, Canada EH
Joined Jul 2005
I'm watching. Very cool!
bob_suruncle is offline Find More Posts by bob_suruncle
Old May 23, 2007, 10:39 AM
Vyceroy is offline
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
Bobs your uncle .. funny funny stuff .. i like the name
Old May 24, 2007, 01:31 PM
Vyceroy is offline
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
New progress and Pics ..
I was going to cover this one before flying her but i figured it was a waste of time seeing as how as soon as i fly this one i am going to start on the revised version ..
Wing halves are together and Dihedral is in .. Nacelle tops are glued in .. bottoms will be done as soon as i get motors set up ..
Old May 24, 2007, 01:44 PM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
Exterminate!!! Exterminate!!!.... another fan of the Doctor eh, me too ... Beauty build Vyce...!!!!
gpw is offline Find More Posts by gpw
Old May 24, 2007, 01:48 PM
Vyceroy is offline
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
New Problem .. i have never made a plane this small with a removable wing ..
Any suggestions for the best way to attach the wing would be appreciated
Here are a few detail shots of the wing and saddle area
Old May 24, 2007, 02:38 PM
krazykajun is offline
Find More Posts by krazykajun
krazykajun
livermore ca
Joined Sep 2004
wing attachment
I would make two small formers out of ply and use a blind nut and a nylon bolt. If you cut thin plywood into 1/2" strips you can glue them top bottom sides and across top place wing and drill through all layers at once and assure the wing lines up properly also would fiberglass center of wing so that bolt wont pull thru
Great looking plane
good luck on maiden
krazykajun is offline Find More Posts by krazykajun
Old May 24, 2007, 02:47 PM
Vyceroy is offline
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
good suggestion Mike .. im thinking maybe 2 skewers sticking out from infront of the wing going into 2 coffee stirrers glued into a foam block into the fuselage .. then a 3mm screw on the back going into a piece of foam or lite ply at rear of wing in the fuse ..
Old May 24, 2007, 03:10 PM
krazykajun
livermore ca
Joined Sep 2004
I would use ply (stronger) unless you wrap the foam in fg and pollyglue for stength an alturnitive would be nylon darn near as strong and a bit lighter
My mom used to hate when I got Into her Nylon drawer to use them on my Planes Three nylons pulled over a fuse made them fairly strong and did not add as much weight as fg
of course now I am 50m years old and my wife has the same problem still a kid at heart. wish the bod would keep up.
Boeing 314 'Clipper' Plans Foamyfoam Scale Kit/Scratch Built 19 Jun 28, 2016 10:20 AM
Build Log Mini size Boeing 314 Clipper Vyceroy Waterplanes 50 Jun 05, 2007 12:04 AM
Discussion Airacuda and Boeing 314 Pat Daily Scratchbuilt Indoor and Micro Models 5 Mar 17, 2006 03:07 PM
Boeing 314 Clipper build thread fliir Waterplanes 0 Jul 11, 2005 03:51 PM
