Old May 21, 2007, 09:00 PM
JimDrew is offline
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
Alert
Important News and Information
Latest manual version: v2.4, firmware v3.0-v3.4
Satellite receiver manual: v1.0
JimDrew is offline Find More Posts by JimDrew
Old May 21, 2007, 09:01 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
B/T port and battery
Warning!
Plugging a battery into the port labeled B/T with the polarity reversed will result in unpredictable operation! The receiver will power up, but servo controls will not function properly. Twitching servos, blinking receiver LED and other oddities will be seen. Range will be unusable, even if a range check shows range to be normal.
Old Jul 25, 2007, 05:30 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
New cases
We will be switcing to a new case design starting next month. The new case moves the antenna further away from the bar, protects the antenna connector, and allows the antenna to remain on the unit for easy storage.
These cases will also be available for purchase to upgrade your existing unit.
Old Aug 08, 2007, 01:38 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
To check for adequate RX power via BEC:
Plug the BEC into the receiver with the flight batteries in a nearly discharged state (as they would be towards the end of their use) turn on the XtremeLink system and move the sticks around. Watch for any hint of flickering of the receiver LED. If you see ANY flickering, then your BEC is not supplying enough power. If you see the LED actually flash red briefly, it means that the voltage has dropped below 3.2 volts and the receiver is rebooting!
Installation Notes:
We do not recommend putting the receiver antenna pointed downward in any model. The closer the antenna is to the ground, the shorter the range. We do have people flying their TREX 450 and 600 setups with the antenna pointed downward without any problems... we just like the extra range.
Important news regarding memory cards and Aiptek SD cameras. RMihara Aerial Photography 10 Aug 01, 2003 12:34 AM
