Old Oct 28, 2002, 05:45 AM
zbrubaker is offline
Find More Posts by zbrubaker
ParkScaleModels
zbrubaker's Avatar
United States, PA, Loganville
Joined Feb 2002
Help with power supply for foam cutting
I've got a power supply from a computer that I think should work pretty well as a power supply for a foam cutter. It will put out 4A at 12V. I've got some NiChrome wire I want to use as the element. I don't know the diameter of the wire, but it has a resistance of about 7 Ohms per foot. Can anyone out there suggest an appropriate sized rheostat so I can control the heat of the wire?
Zeke
zbrubaker is offline Find More Posts by zbrubaker
Power supply for foam cutting eran_k Foamies (Kits) 5 Mar 08, 2005 04:08 AM
computer power supply for foam cutting?? RCFlyer55 Foamies (Kits) 30 Jan 15, 2005 10:13 AM
ATX (PC) Power Supply for Foam Cutting? Jim Buzzeo DIY Electronics 40 Oct 14, 2004 07:18 AM
Pryamid 14amp Power Supply for foam cutting mt_100 Electric Plane Talk 11 Sep 14, 2003 10:40 AM
Computer Power supply for Foam Cutting? dwood99 Foamies (Kits) 5 Jul 18, 2001 01:22 PM
