Old May 21, 2007, 12:24 PM
AustinTatious is offline
Find More Posts by AustinTatious
AustinTatious
AustinTatious's Avatar
Hurst, Texas, United States
Joined Jul 2003
Smallest turbine ?
Coudl anyone provide links to the smallest gas turbine ever made ?
I seem to recall seeing a 1 inch diameter someone was working on but I never saw any follow up.
HOw small COULD you make a turbine ?
AustinTatious is offline Find More Posts by AustinTatious
Old May 21, 2007, 03:19 PM
Sara is offline
Find More Posts by Sara
Joined Aug 2005
The smallest one which is available commercially is Martin Lambert's Kolibri. www.lambert-modellturbinen.de/html/english.html
One or two people have made homebuilt engines about the same size as the Kolibri but I don't know of anything much smaller which has actually been run. It is very difficult to build and balance something as tiny as that - the Kolibri does over 240,000 rpm.
Various people have shown tiny turbines over the years, and there are all sorts of rumours about the military building ones which are only half-an-inch long, but I don't know of anyone who has seen anything smaller than the Kolibri that actually works. It is comparatively easy to make something that looks like a small turbine and to colour the tailcone by heating it, making it look as if it has been run, but unless an engine is seen working in public it's not a turbine, only a shelf ornament.
Sara Parish
Wren Turbines
Sara is offline Find More Posts by Sara
Old Mar 12, 2008, 09:15 PM
Alfredo Rubio is offline
Find More Posts by Alfredo Rubio
Moderador.
Alfredo Rubio's Avatar
guadalajara, jalisco, mexico
Joined Sep 2002
WOW!!!! as a micro planes lover this is great
Alfredo Rubio is offline Find More Posts by Alfredo Rubio
Old Mar 31, 2008, 12:57 PM
A G G is offline
Find More Posts by A G G
Andres Gtz.
Guadalajara
Joined Jan 2007
i think is the best idea for replace at edf in the park jets.
look
Twin Jet mit Kolibri (2 min 8 sec)
A G G is offline Find More Posts by A G G
Old Apr 22, 2008, 02:02 PM
Bryan Davison is offline
Find More Posts by Bryan Davison
Joined Mar 2006
Here is the smallest one....
Bryan Davison is offline Find More Posts by Bryan Davison
Old Apr 28, 2008, 01:54 PM
rapidrabbit is offline
Find More Posts by rapidrabbit
United Kingdom - Midlands
Joined Jul 2005
WOW! That's small! Any more details on this Bryan?
rapidrabbit is offline Find More Posts by rapidrabbit
Old May 07, 2008, 10:45 PM
Joined Mar 2006
Not much.
I heard it was a Darpa project, and it turns 600,000 rpm on air bearings. But I cant find any confirmation of this. I also cant find any pics of it in the casing, or running.
Old May 08, 2008, 12:51 AM
Speed is Life is offline
Find More Posts by Speed is Life
Speed is Life's Avatar
FREE Gene!!! Get Banned!!!
Joined Jun 2005
Sweet! Turbine powered Gold Finch..............
Speed is Life is offline Find More Posts by Speed is Life
Old May 23, 2008, 02:52 PM
jcantara is offline
Find More Posts by jcantara
USA, MA, Methuen
Joined May 2008
The smallest I've heard of are mems-scale turbines (millimeter size and smaller). They're being used as generators though, not for thrusting. Maybe one could make some sort of fuel-electric hybrid aircraft
jcantara is offline Find More Posts by jcantara
Old May 24, 2008, 07:02 PM
stvienna is offline
Find More Posts by stvienna
Joined Apr 2008
guys the smalles turbine is much (!!!) smaller and from MIT gas turbine laboratory.
The micro-gas turbine is a 2 cm diameter by 3 mm thick Si
or SiC heat engine designed to produce about 10 W of electric
power or 0.1 N of thrust (!!)
its really 3mm thick, including compresser, combustion, turbine wheel, electronics, etc.
look at this site and photo on right side of the page:
http://web.mit.edu/newsoffice/2006/microengines.html
stvienna is offline Find More Posts by stvienna
Old Oct 15, 2009, 04:12 AM
Tartago is offline
Find More Posts by Tartago
Plane crazy
Tartago's Avatar
Joined Apr 2006
You can get a cheaper one (~1500usd) from jetjoe.com, it is called Jet Joe jr.
http://www.jetjoe.com/main.php
Nice to see one on a Su-30M!!
Tartago is offline Find More Posts by Tartago
Old Oct 15, 2009, 06:29 AM
BJ64 is offline
Find More Posts by BJ64
The wheels touch down FIRST??
BJ64's Avatar
Australia, VIC, Melbourne
Joined Jun 2009
Just LOVE the colour co-ordinated matching gas bottle there A G G.
And the fact that you start her with the turbine facing the inside of the back of the car
Just hope it don't flood and fart a huge plume of wet burning Kero there one day .... Frazzled seat-covers if it does...
BJ
PS - wonder what the insurance company would say.... LoL
BJ64 is offline Find More Posts by BJ64
Old Oct 15, 2009, 06:55 AM
BJ64 is offline
BJ64's Avatar
Joined Jun 2009
Regarding the smallest working Turbine - there must be a finite cut-off limit to the mechanics and fluid-dynamics of air itself and being able to deliver and vaporize the Kero (assuming that we are talking 'Jet' as in paraffin-burner). And, of course, to be able monitor and supply the correct amount of oxygen to efficiently burn the micro-vapour of fuel being supplied.
I would think that once you go a certain tiny size, you'd only be able to run the thing on Propane or a similar gas, where the relatively huge viscosity of a 'heavy-oil' fuel would be just to 'thick' to be able to atomise and regulate accurately through the injectors.
The enormous RPM would require extremely accurate bearings etc, I would assume - the tolerances once you go really small would be so tight that any bearing slop or end-float would be critical to avoid catastrophic failure of the extremely fast moving parts, not to mention drastically altering the air/fuel flow though the turbine. A thousandth of an inch either way is probably something like a 30% shift in efficiency. Maybe even the difference the difference between a start, and a no-go.
Some of the 'micros' out there that actually run are already pushing the boundaries.
How much smaller can we realistically go - until shear Physics takes over and says "Nup - can't go no smaller" ??
Smallest turbine..? K3Cut Engines 10 Oct 15, 2009 05:56 PM
Discussion Smallest turbine motor/plane combo? bv1311 Fuel Jet Talk 9 Apr 09, 2007 06:59 PM
