Old May 20, 2007, 09:09 PM
Craig Mckinley is offline
Find More Posts by Craig Mckinley
Plummet Airlines
Craig Mckinley's Avatar
Perth Western Australia
Joined Feb 2004
Help!
PC Power Supply AT the same as ATX?
Hello. I have scavenged a PC power supply. I have been reading the threads regarding converting to 12 v dc power supply. Anyway, on further inspection I noticed that it is a old AT unit. Are there any differences I should know about? can I use the same ATX threads?
Thanks so much.
Craig
Craig Mckinley is offline Find More Posts by Craig Mckinley
Old May 20, 2007, 09:14 PM
Raydee is offline
Find More Posts by Raydee
RC Addict
Raydee's Avatar
United States, NY, Niagara Falls
Joined Jun 2002
Gday Mate, I think the only diff is that the ATX has a wire that needs to be turned on. Its been a while since I built one but I remeber hearing that the AT style supplies were easier to build.
Raydee is offline Find More Posts by Raydee
Old May 20, 2007, 09:44 PM
Unterhausen is offline
Find More Posts by Unterhausen
5 miles from the geographical center of Pennsylvania
Joined Aug 2005
an AT supply has a power switch, an ATX needs to have a wire grounded. With any PC supply, make sure that the 12v line has a high enough rating for the purpose. ATX is likely to be better.
Unterhausen is offline Find More Posts by Unterhausen
Old May 21, 2007, 02:56 AM
Plummet Airlines
Joined Feb 2004
Good, thanks. The AT power supply does have a seperate on/off switch. Looking at the output it seems more than ok.
Thanks for your help.
How to make own Power supply at home? convert from PC power supply? HumbleBoss Batteries and Chargers 16 May 01, 2016 02:13 PM
Question Starting PC Power Supply (AT) bergfalke4 Batteries and Chargers 14 Apr 26, 2016 07:57 PM
ATX (PC) Power Supply for Foam Cutting? Jim Buzzeo DIY Electronics 40 Oct 14, 2004 07:18 AM
ATX 150W PC Power supply?? joebell Batteries and Chargers 1 Feb 25, 2003 10:29 AM
PC Power supply as 12 v source trickyrik Power Systems 1 Dec 19, 2001 11:52 PM
