Espritmodel.com Heli Air
Old May 20, 2007, 03:19 PM
Yakman13's Avatar
Joined Apr 2007
"WARNING DX 7 LOCK OUT BEWARE"
I Setup My New Yak 54 67" With A Dx7 I Flew Maybe 10 Flights With No Problems At All, It Seemed To Work Fine Untill Yesterday, I Took Off In Kind Of Heavy Winds Maybe 10 Mph,i Took It Up To About 300 Feet
Nose Into The Wind My Sato 125 Was Running Perfectly,no Problems,
Then All Of A Sudden It Went Nutts, I Had No Controll It Rolled To The Right And Started To Dive Back With The Wind, I Was Moving My Sticks Around Like A Mad Man With No Responce At All, Then I Tryed Running Tward The Plane With My Tx Held Up As High As I Could Get It
She Was 35 Feet From Disaster When I Regained Controll, I Landed With No Damage, Only By The Grace Of God,pure Luck, I Shut It Down ,and Noticed That The Orange Led On The External Rx Was Out,i Packed It Up And Brought It Home,and Checked It Again,the Led Was Back On
Im Like Thats It,i Am Not A Beta Tester,not With My Nearly 1000$ Woth Of Model, I Spent Most Of The Night Re Setting Up My Futaba 7 Chp With A Pcm Rx And New Lipo System..now I Cant Figure Out How To Setup Dual Elevator Servos On The 7 Chp I Have Them Setup
On 2 And 6 In P-mix 1 With 2 As Master And 6 As Slave It Works Fine But The Dial Acts Like A Trim For The Left Eleavator Is There Any Way To Avoid That?????
Yakman13 is offline Find More Posts by Yakman13
Old May 20, 2007, 05:08 PM
Pompano Hill Flyers
Miami Mike's Avatar
Miami Lakes, Florida, USA
Joined Mar 2003
I liked it better when you didn't use your shift key at all.
http://www.rcgroups.com/forums/showt...91#post7486191
http://www.rcgroups.com/forums/showt...83#post7486183
Miami Mike is offline Find More Posts by Miami Mike
Old May 20, 2007, 05:47 PM
Yakman13's Avatar
Joined Apr 2007
what the hell does that mean ?
Old May 20, 2007, 06:09 PM
Critical Mach's Avatar
Gilbert, AZ.
Joined Feb 2007
Yakman,
What are you using for an RX power source?
Critical Mach is offline Find More Posts by Critical Mach
Old May 20, 2007, 06:21 PM
USA, FL, Apopka
Joined Dec 2000
I believe he was commenting on the odd capitalization of the first letter of each word in your post.
But to respond to the problem, like Critical Mach, I wonder if you pulled the voltage down too low on your RX pack and reset the Spektrum RX.
bradpaul is offline Find More Posts by bradpaul
Reply With Quote  (Disabled)
Old May 20, 2007, 06:28 PM
Gilbert, AZ.
Joined Feb 2007
That's what I was thinking. Were you using a separate battery source for the RX or sharing power with the servos, from a main battery pack.
Old May 20, 2007, 06:36 PM
Speed is Life's Avatar
FREE Gene!!! Get Banned!!!
Joined Jun 2005
It means unusual application of the Caps...........
Anyways, 10 flights of how many minutes each? Lets say at least 8, and the Spektrum supplied digital servo load (how many servos?) on top of that?
Were you using just the one supplied 4 cell Spektrum 1100NiCad?
My guess is that the load on your battery after 80 minutes of prior flight drew the voltage down to below the Rx tolerance (see a couple of other threads on that issue).
As for me, I go with a 5 cell NiMh and on big models I go dual battery 1500mah each.
Cheers,
-Mike
Speed is Life is offline Find More Posts by Speed is Life
Old May 20, 2007, 06:46 PM
Yakman13's Avatar
Joined Apr 2007
i think that was {bc} in the original text i left the caps on,and when i uploaded the post it did that with the caps for some reason,i wasent about to re typ all that cuz of caps...lol
anyway i was using pac that the spectrum came with and the voltage meeter was bright green in all stick positions...
i dont think it was the pac at all,cuz it happened it the first min. of flight but i did go ahead and replace that as well "just in case" now i cant figure out how to program the futaba 7chp for dual eleavators can anyone help with that ?
thanks
jim
Old May 20, 2007, 07:28 PM
You can call me FANBOY!
Goodlettsville, TN
Joined Sep 2006
There was another thread where the same thing happened and after calling Horizon they recommended switching to a 5 cell pack.
chrisf testpilot is offline Find More Posts by chrisf testpilot
Old May 20, 2007, 09:34 PM
59 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Yakman:
Could you just clarify the state of the battery. Was this the first or the 11th flight of the day? (I assume the first, but others read it differently). Had you given the 1100 mAh pack a full charge with a suitable rate charger?
Daedalus66 is offline Find More Posts by Daedalus66
Latest blog entry: Polaris Aileron Pushrods
Old May 21, 2007, 12:24 AM
The Shadows are coming!
Sirion's Avatar
Glen Forrest, Western Australia
Joined Dec 2006
Yakman: On the Rx battery low volts aspect perhaps you consider investing in an audible or audio/visual alarm for the LiPo pack - have a look at http://www.tjtrc.com/LiPoV2.html.
"Thanh" runs it and has several kits from just a low volt 93db beeper alarm up to strobing LED's. Tell him how many battery cells are involved and he'll set the safe "under load" volts on the PCB so that the various alarms go off before you suffer power loss and/or battery damage. The costs are reasonable - either make-up kit or fully assembled and with a power takeoff from your battery to the PCB plus a signal connection to a spare Rx channel. There are several other makes available but Thanh can talk to you about your exact needs. Cheap insurance.
Good luck.
Sirion is offline Find More Posts by Sirion
Old May 21, 2007, 07:35 PM
Big Extra
USA, CA, Lincoln
Joined Apr 2003
Hi Yakman,
There are probably a lot of us who are interested in the power system details.
I just want to confim...
What servos were you using and how many were there?
This has been reported in other posts and I've seen in my own tests that the small 4.8 volt and even AA 6 volt packs do not handle digitals well. 1 stalled digital can pull around 1 amp.
Can you put the stock pack on a discharge cycle of 3 - 5 amps and see what the resulting voltage is? It would be worth it to find out it it is dropping below 3.5 volts. The rx is rumoured to reset at about 3.1 volts.
If you had a beefy pack that was charged up well that's another matter.
Thanks in advance for the info.
By the way, what Yak are you flying. 67" sounds good. I might want one.
rino is offline Find More Posts by rino
Old May 21, 2007, 11:41 PM
Christchurch, New Zealand
Joined Jun 2006
The RX resets at 3.*7* volts. That's rather high for a typical RX.
Short answer: use 5 cell or a proper regulated setup, especially on something expensive. A 2-cell lipo and a big switchmode BEC is lighter than a nickel pack anyway, and a trivial fraction of the cost of the plane.
Andrew McGregor is offline Find More Posts by Andrew McGregor
Old May 22, 2007, 12:31 AM
The reviewer
XJet's Avatar
Tokoroa
Joined Mar 2004
The 7C doesn't support dual elevators.
Although it's billed as a 7-channel version of the 9C, the 7C is actually missing quite a bit of its big brother's functionality and dual elevators (with linked trim) is just one of the nice 9C features that was dropped.
XJet is offline Find More Posts by XJet
Old May 22, 2007, 12:56 AM
Big Extra
USA, CA, Lincoln
Joined Apr 2003
Someone on another post both recently and extensively tested the 7000 RX with a variable DC power source on an oscilloscope and consistently got a reset voltage of 3.1 volts. See my next post.
How did you arrive at 3.7 volts?
Have you tested this and with what type of equipment?
Thx,
r
Discussion DX-7 locking out? basmntdweller Radios 0 Mar 23, 2007 10:19 PM
For Sale Snap-on Deluxe Lock-Out kit/Slim Jims, lock picks, wire picks, case/Serious Inquires dgfisher2004 Non R/C Items (FS/W) 6 Jan 09, 2006 05:32 AM
K&B 7.5 Out Board Engine sschults Boats (FS/W) 8 Mar 08, 2005 07:53 PM
FMS 7 is finally out!!!!!! Eco8gator Electric Heli Talk 14 Nov 13, 2001 03:10 PM
GWS DX-A motor cutting out tom_yellowblue Parkflyers 9 Sep 07, 2001 05:58 PM
