Old Oct 27, 2002, 06:52 PM
Magna is offline
Find More Posts by Magna
Malaysia
Joined Jun 2001
why you should gear your glider and played with the cg location...
Hi all
I was pondering for quite a while if I should gear my elipsoid 2.8M.
It fly great with good climb with Mega 22/30/3 DD with 11x6 on 8 RC2400. AUW about 72oz. The thermal here sucks(much lesser), very rare you get a good one unless you fly around 12 noon with the hot sun. Usual flight time about 20 mins.
Finally, I plunked in for a model motor GB(Aircraft-Japan David) 2:1. Now it run on 14x9.5, wattmeter show about 225 watt/24amp = 50w/lbs. I also adjusted the CG about 1.5mm rearward ie tail heavier.
Now it climb slower and more graceful rather than frentic. But the best part is that its lower amp drawn. I can have about 8-9 climb and it will take about 4 mins to come down with no thermal. Because of CG adjustment, it fly a lot more slower(good for indicating thermal) and land a lot more gentle too. Yes!
I did not go all out in trying the setup but I can see the plane fly a lot more different. Its more graceful, all my buddies agreed too. After flying for about mins. I landed and I still have about 70% juice left. It may not sound much but I fly early when the sun barely warm the ground(it rain heavily 7 hrs earlier with puddles of water on the landing strip). So I think I hit it right!
Thanks to all those who share the idea of gearing and adjusting the CG advice.
Magna is offline Find More Posts by Magna
Discussion Why you should stay away from power lines (3m composite carbon glider) midrian Sailplane Talk 16 May 02, 2007 10:40 PM
Discussion Why you should keep your eye on the bird dwayne_carlin Beginner Training Area (Aircraft-Electric) 2 Dec 10, 2006 10:52 PM
Discussion Why you should keep your eyes protected around a spinning prop. maestro7879 Electric Plane Talk 10 Apr 10, 2006 12:52 AM
Help with CG location. Ian Easton Electric Sailplanes 5 Jan 21, 2003 11:21 AM
Why you should not run an MP Jet planetary gearbox in reverse...... Steve McBride Electric Plane Talk 1 Nov 12, 2001 05:07 PM
