Old May 20, 2007, 12:51 AM
Slope and thermal
Christchurch, New Zealand
Joined Apr 2003
Dual mode FM and 2.4 GHz SS transmitter
Isn't this the announcement you've been waiting for ...
Unfortunately I was just joking. Its not available yet (as far as I know). It does seem to be the right transition strategy for many of us.
Imagine buying or upgrading a JR 9X/9303 or a Futaba 9CAP transmitter that could transmit both 2.4 Ghz and 72 MHz FM. It would just be part of the model memory programming. Select the model memory for the model you are flying and that selects FM or 2.4 GHz to match the reciever in the model. No need to replace all your receivers (or any at all) from the start.
I expect that this would push up the cost of a pure 2.4 GHz transmitter by what you can buy an FM RF module for today. There might have to be some clever work with aerial placement and you'd have to remember to extend the FM aerial when using an FM model memory.
I wonder if anyone will actually make a dual mode transmiter?
Eric.
EricSoar is offline Find More Posts by EricSoar
Old May 20, 2007, 01:25 AM
Where is the lift?
cptsnoopy's Avatar
USA, AZ, Phoenix
Joined Nov 2005
The only obvious drawback would be the need for two antennas mounted on the tx.
cptsnoopy is offline Find More Posts by cptsnoopy
Old May 20, 2007, 02:47 AM
Deletedfor proving Nauga wrong
Joined Mar 2005
the transition mode is...
keep using the older 72 mhz TX(s) you have on hand for the stuff that still has 72 mhz radios installed.
Then as you buy new receivers (for replacement or for new planes)... buy the new 2.4 ghz that go with your 2.4 ghz TX.
Eventually... you'd end up with just one or two planes on 72 mhz, and be able to go ahead and replace those RX's and sell your old stuff on E-bay.
fhhuber506771 is offline Find More Posts by fhhuber506771
Sold Black Widow 600 mW 2.4 GHz video transmitter ehx Aircraft - Electric - Miscellaneous (FS/W) 2 Mar 23, 2007 05:25 PM
Question 2.4 ghz transmitter chuter1 Coaxial Helicopters 5 Mar 17, 2007 10:12 PM
For Sale 2.4 ghz Blade CX2 transmitter Eyefly Aircraft - General - Radio Equipment (FS/W) 5 Feb 02, 2007 03:12 PM
Question 2.4 GHz Micro Receiver - Transmitter on Ebay this week! paerials Aerial Photography 1 Oct 11, 2006 12:03 PM
Discussion Hitec to Release 2.4 gHz SS Radios! rutat Radios 8 Jan 26, 2006 01:53 PM
