Old May 19, 2007, 11:28 PM
jay/jay is offline
Find More Posts by jay/jay
usa
Joined Oct 2006
Scratch Building the Gee Bee Model -Z 1/4 scale (thread #2
Well I guess I have given you a chance to kind of get to know me a little, from my 1st. thread, on Scratch building the Gee Bee model-Z on thread #1. So I guess it's time to share with you how the model is built. The plane builds mostly straight down on the building board, like most any other RC plane. The stablizer and elevator have notch style construction to keep it strong, straight,and light with good glue joints.The fuselage box frame crutch is tab lock construction, like that of a Carl Goldberge Kit, but differen't, and builds upside down on the building board over the top view fuselage plans like that of a Top Flite kit. The main fuselage formers #2 -thru.-#8 fin slide and lock into place on both sides of the fuselage box frame crutch, and goes together pretty quick. The plans have both wing panels drafted up so you do not have to trace over it to get the other side, also the plans have instructions and notes on how to build plane along with some photo's on building.There are 5 sheets total, Plate #1 fuselage side view left side with landing gear, #2 top view ,with boxframe crutch patterns, #3 fuselage former patterns along with stab/elev. layout #4 & 5 are the wing panels with spars, and wing rib airfoil patterns, also with fin & rudder patterns and layouts for building. Also there are Illustrations and instructions on how to build those large wing fillets with the false fillets built into the wing so that the wing fillet coming off the fuselage are flush with the airfoil on the top side and bottom side of the wing panels.
thanks so much, Johnny
jay/jay is offline Find More Posts by jay/jay
Old May 19, 2007, 11:39 PM
jay/jay is offline
usa
Joined Oct 2006
scratch building the Gee Bee model -Z 1/4 scale
More photos of building the plane,
The plane is built in this order, and by these steps.
1. - build the fin and rudder 1st.
2. - build the stablizer and elevator 2nd.
3. - build the wing 3rd.
4. - build the fuse box frame crutch 4th.
5. - mount the wing to the box frame before adding formers F-2 thur.F-8.
6. - glue the fuselage fromers F-2 thur -F-7 to the box frame with the wing
off and plank or sheet the fuselage.
7. -with no glue whatsoever, and useing only masking tape and T- pins mount the stab/elve. into place along with the (fin F-8 ) now install all radio
gear and push rod linkage put a couple stringers into place where the push rods exit the fuse., check your clearance to make sure everything lines up before going to the next step and if useing round dowl push with 4-40 hardware tape them in place inside the box frame before glueing the firewall engine mount into its location very important!
8.- decide now how you are going to cover the plane since the stab/elve . is mounted in the scale location all hinges will not work with fabric & paint because the stab/elve. is hinged together before installed with glue.
Old May 20, 2007, 12:06 AM
jay/jay is offline
usa
Joined Oct 2006
Scratch Building the Gee Bee model -Z 1/4 scale
more photo's still on building the plane ,Johnny.
step's on building the plane
9.- measure and cut the 1/8x14 balsa stringers and glue into place one left and one right as yuou go around the fuselage formers F-2 thur F8
10'- now measure and cut the 1/8x1/8 bass wood stringers and glue in place starting behind the cockpit headrest to the Fin post F-8 while working your way down into the stabilzer
11.-mount the wing back on to the fuselage useing wax paper and build the wing fillets, make sure to use the sanding blocks that are show on the plans to get the wing fillets to the right shape
12, -builld the landing gear as show on the plans before building the wing fillet belly pan
13. build the wing fillet belly pan, and the oiler cooler scoop.
14 fiber glass the wing fillets, and sand and prep the rest of the plane for covering, as any other plane,
Old May 20, 2007, 12:38 AM
jay/jay is offline
usa
Joined Oct 2006
Scratch building the Gee Bee model -Z 1/4 scale
Covering the plane with stits lite fabric and paint by F&M Enterprises, The basic primeing was done at my place, but the final paint job was done by Screwy, at Screwy Designs in Olympia WA. A good friend of mine. And it's nice to have friends like that, since He is considered to be one of they very best custom painters on the west coast, His custom Mortor Cycles and Cars are seen in just about every major custom Car show across the country
Johnny.
Old May 20, 2007, 01:07 AM
jay/jay is offline
usa
Joined Oct 2006
Painting the plane at Screwy's Place
Photos of painting the Gee Bee model -Z At Screwy Designs.
Old Nov 06, 2012, 03:35 PM
vtdiy is online now
Find More Posts by vtdiy
low tech high tech
vtdiy's Avatar
Southern Vermont
Joined Feb 2007
Nobody ever even commented on this build???!! It's a privilege then to be the first to provide a wow, five years after the fact.
WOW!!!!
vtdiy is online now Find More Posts by vtdiy
Old Nov 07, 2012, 05:46 PM
tailskid2 is offline
Find More Posts by tailskid2
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
I wonder how/when it flew....I have a Seagull "Z" and it flys like a trainer - except for the landing part
tailskid2 is offline Find More Posts by tailskid2
Latest blog entry: VQ 112" Beaver
Old Nov 08, 2012, 04:48 PM
vtdiy is online now
low tech high tech
vtdiy's Avatar
Southern Vermont
Joined Feb 2007
Just noticed turnbuckles on the rigging, and the engine details. Superb model of this plane.
Old May 02, 2013, 08:56 AM
Firebird356 is offline
Find More Posts by Firebird356
Joined Feb 2012
WOW WOW WOW !
Best GeeBeeZ model ever !
@ Jay/jay, are your plans available?
Firebird356 is offline Find More Posts by Firebird356
Old May 19, 2013, 07:15 PM
sneasle is offline
Find More Posts by sneasle
War Eagle!
sneasle's Avatar
United States, AL, Huntsville
Joined Sep 2006
He's got some really nice detail on this. The original post is so old though, I doubt he is still around the boards.
That said, I don't know of a 25% plan for the Z, so he may have drawn them up himself.
sneasle is offline Find More Posts by sneasle
Discussion Scratch Building A Gee Bee Model - Z Super Sportster 1/4 scale jay/jay The Builders Workshop 0 May 19, 2007 11:35 AM
Gallery Building the Gee Bee model -Z by jay/jay jay/jay Fuel Plane Talk 1 Oct 27, 2006 10:40 AM
Gee Bee Model Z- PRE-Flight RC Sim New Plane pingprime Simulators 0 Oct 02, 2004 12:34 AM
FOR SALE - Gee Bee Model Z 40 Bob Johnson Aircraft - Electric - Airplanes (FS/W) 11 Dec 06, 2003 10:17 AM
Rave Kyosho Gee Bee Model Z BobHH Aircraft - Fuel - Airplanes (FS/W) 0 Nov 20, 2003 10:09 AM
