Old Jul 07, 2007, 08:37 PM
Rendy is offline
Find More Posts by Rendy
Rendy's Avatar
Santa Clara, California
Joined Aug 2004
Rendy's Manta construction diary (continued)
Well... I have completed the D-box and the servo box. The wing panels in the photos are very rough because I have not start sanding them yet.
Update: The both wing panels together is 4.02 oz. After sanding, 3.8 oz. Currently, I am glassing the TE of the ailerons and wing tips. There is no photos for this because it is very hard to see the difference.
Rendy is offline Find More Posts by Rendy
Old Jul 12, 2007, 08:17 PM
Rendy is offline
Rendy's Avatar
Joined Aug 2004
Rendy's Manta Construction Diary
The wing is basically done. It weights about 5 oz.... about 0.5 oz heavier than I expected. I must have put in too many carbon and FG. The covering adds about 0.5 oz.
Old Jul 13, 2007, 12:27 AM
Geode is offline
Find More Posts by Geode
Geode's Avatar
San Jose, CA
Joined Jan 2007
Nice covering job. Looks like you will hit 9 ~ 9.5 oz target weight and with a stiffer wing.
Geode is offline Find More Posts by Geode
Old Jul 14, 2007, 04:22 PM
Adlerauge is offline
Find More Posts by Adlerauge
Joined Jan 2007
High Geode!
I just read your Thread of this amazing great flyer.
I send you an PM but I don`t know, what button for sending the messege.
So I Send you my messege with all the Buttons, hoping one messege came to you. (my bad english)
Wish you so much Luck with the great bird.
Thomas
Adlerauge is offline Find More Posts by Adlerauge
Old Jul 14, 2007, 08:29 PM
Rendy is offline
Rendy's Avatar
Joined Aug 2004
I have just completed the pylon wing mount. It is modeled after SG2. The inner tube is made from carbon-AL arrow shaft. The outer tube is homemade FG-Kev-FG tube.
Old Jul 14, 2007, 09:16 PM
Geode is offline
Geode's Avatar
San Jose, CA
Joined Jan 2007
Hi Thomas,
Thanks for your interests. Please check your mail box for Manta plan.
Please also note that Rendy has make several improvements on his Manta to make it stronger and lighter. Wish you enjoy the Manta build and remember to come back to share with us your experience.
Geode
Old Jul 15, 2007, 12:47 AM
Joined Jan 2007
High Geode!
I thank you so very much for the plans.
Must build my first Bird ready for maiden and then I will build your`s.
Good Luck by this great Hobby to you all!
Thomas
Old Jul 15, 2007, 10:49 AM
Geode is offline
Geode's Avatar
San Jose, CA
Joined Jan 2007
That's a really beautiful bird !
Old Jul 22, 2007, 03:36 PM
Rendy is offline
Rendy's Avatar
Joined Aug 2004
I am done with all the electronics. JR SM22 for RUD and ELE; D60 for AIL. RX Electron 6.
Old Jul 24, 2007, 11:29 PM
Rendy is offline
Rendy's Avatar
Joined Aug 2004
Rendy's Manta Construction Diary (final post)
I have maiden the plane this evening and the following are the lessons learned.
(1) The plane flies great in light wind condition. The AUW is 9.7 oz for my version. Geode's Manta is lighter. However, a 9.7 oz plane is just about right for me. The launch heigh with 60% power launch is about 120 ft easy.
(2) The CG is right on without any nose weight. My initial decaloge estimate is also correct.
(3) The wing has plenty of stiffness in bending. There is no need to add CF spar cap.
(4) The wing is a little bit thick which makes it hard to penetrate into high wind condition.
(5) The wing torsion should be improved a little bit more. It does not cause me any problem, but there are people launch with strong wrist action, which could twist the wing a bit.
(6) The aileron construction is torsional weak. The deflection angle cannot properly transfer to the tip This can be corrected by mounting the AIL servo more outboard and stiff up the structure a bit.
(7) The SG2 style wing mounting method works great even though it takes some time to make.
(8) SG2 style pod is very very small. Careful planning of the components is required. I mean even the path for the wiring.
(9) The nose section of my pod is a bit too weak. Need to put another layer of Kevlar in the nose section.
(10) The wing tip shape needs to be modified to accommodate personal launch style.
rendy
Old Aug 18, 2007, 06:36 AM
Geode is offline
Geode's Avatar
San Jose, CA
Joined Jan 2007
Any comments ?
I received lots of requests for printable plan. Surprise to find that there are more than 50% of them are outside US .
How are the progress out there, gentlemen ? I have to confess that, there are a lot of building details not covered in this thread due to my limited English capability. If you have any questions, please do not hesitate to ask in this thread or PM me privately.
Also, feel free to post any comments and recommendations (good or bad, both welcomed) on Manta DLG. I'm more than happy to take that into account for next revision. Thanks.
Happy building
Geode
Last edited by Geode; Aug 18, 2007 at 10:34 PM. Reason: Polish up my poor English.
Old Aug 18, 2007, 07:16 AM
Geode is offline
Geode's Avatar
San Jose, CA
Joined Jan 2007
Manta II
A few improvements can be made to Rendy's comments to make it better for Manta II:
The new target weight will be < 9 oz and narrower chord to keep the wing loading the same. This fits well with my constant wing loading principle. Add ballast in windy conditions if necessary
Vertical web width to be reduced from 3/8" to 1/4" for weight saving.
I like the penetration capability on my Manta.
We still not come to a conclusion yet on this regarding how to make it better. Is it due to airfoil thickness, larger wing area, non-transitional airfoil @ wing tips, wing torsional strength, balsa building skill or Icarex ????
This is the most significant difference between build-up vs. composite DLG's.
Rendy use hard 1/16" ribs in his Manta. This probably is not a good tradeoff between weight and strength. Hard 1/8" or 3/32" ribs may be a better compromise between strength and weight penalty.
Also, I like the looks and strength of diagonal ribs in Hyperbolic Manta. This will be there for Manta II.
Last but not least, geodetic ribs like "Bumblebee XL" will add another big jump in torsional strength.
Looks like I'll stick to my solid balsa or balsa (or CF) capped build-up aileron in the future.
I have >100 launches and landing on Hyperbolic Manta with balsa pod. This will be used for Manta II instead of composite pods.
Geode
Old Aug 18, 2007, 02:06 PM
kostuk is offline
Find More Posts by kostuk
Joined Nov 2003
Hi Geode,
THanks for the update. I hope to work on my Manta once I finish my Apogee Sport.
Ray
kostuk is offline Find More Posts by kostuk
Old Aug 18, 2007, 02:47 PM
Ricardo RW is offline
Find More Posts by Ricardo RW
.: Looking for Thermals :.
Ricardo RW's Avatar
Chile, Quinta Región de Valparaíso, Los Andes
Joined Jun 2002
Hey Geode,
Do you cut by hand your ribs or you laser cut them?
Ricardo RW is offline Find More Posts by Ricardo RW
Old Aug 18, 2007, 10:19 PM
Geode is offline
Geode's Avatar
San Jose, CA
Joined Jan 2007
I glue (with 3M77) two 1/8" balsa together and then hand cut the ribs (50% improvement in throughput) :-).
I'm currently working on a new methodology on my pet project to make the balsa building process more builder friendly. If it works out properly, I might come back to incorporate that into Manta II with laser cut.
Discussion Project Rays - Hyperbolic Manta Geode Hand Launch 28 Jun 12, 2008 09:50 AM
