Old May 29, 2007, 04:06 PM
Geode is offline
Find More Posts by Geode
Geode's Avatar
San Jose, CA
Joined Jan 2007
Originally Posted by Cebola
Has a example, this is the fuse that I intend to build for my Manta......
Great, I like diversity. The FG/balsa/FG sandwich must be as strong as the molded wing (similar construction method).
BTW, I'm also working on a balsa pod - "sliced bread" type construction and Rendy is working on his molded pod. Keep the goodies coming .....
Geode is offline Find More Posts by Geode
Old May 30, 2007, 05:32 AM
kimhey is offline
Find More Posts by kimhey
kimhey's Avatar
nøtterøy, NORWAY
Joined Mar 2006
Great,Rendy!
Will follow this build..
Kim
kimhey is offline Find More Posts by kimhey
Old May 30, 2007, 02:01 PM
ajroahkni is offline
Find More Posts by ajroahkni
PWP!
ajroahkni's Avatar
USA, HI, Makawao
Joined Oct 2002
What's the secret to such perfectly cut TE grooves?
ajroahkni is offline Find More Posts by ajroahkni
Old May 30, 2007, 07:06 PM
Geode is offline
Geode's Avatar
San Jose, CA
Joined Jan 2007
Rendy has the skill and I have the tool .....
I got something similar to this needle file set - http://www.harborfreight.com/cpi/cta...itemnumber=468
A few pass with square file, it's done.
Well......, Rendy's cut is cleaner though.
Old May 30, 2007, 08:11 PM
Rocketman209 is offline
Find More Posts by Rocketman209
Arlington, TX
Joined Dec 2002
I must say that I am very impressed with this design. I like the covering material. is it very smoth surfaced?
does anyone have a link for a supplier of this covering material?
Walter
Rocketman209 is offline Find More Posts by Rocketman209
Old May 30, 2007, 08:26 PM
Geode is offline
Geode's Avatar
San Jose, CA
Joined Jan 2007
The surface is not as smooth as film covering. The surface texture is just like the Ripstop kite.
More detail on Icarex supplier and covering method can be found here - http://www.tufflight.com/icarex.html
Old May 30, 2007, 11:19 PM
markdrela is offline
Find More Posts by markdrela
Cambridge, MA USA
Joined May 2001
A word of warning: The "1/2 oz" weight is NOT the actual weight of this stuff. I weighed it when I used it for an IFO -- it's actually more like 1 oz/yd^2, which is about the same as Ultrakote Lite.
Perhaps the "1/2 oz" refers to the weight of the woven fabric before the polyester film is added to it.
markdrela is offline Find More Posts by markdrela
Old May 31, 2007, 08:27 AM
Geode is offline
Geode's Avatar
San Jose, CA
Joined Jan 2007
Icarex
A quick comparison of actual covering weight from my build-up DLG's (normalized to Manta wing size of 2 X 387 in2)
......................................Actual ...... Actual ......... Retailer Info
So-lite ........................... 15 g ....... 0.89 oz/yd2 .... 0.6 oz/yd2
Icarex only ..................... 18.4g ..... 1.09 oz/yd2 ..... 0.5 oz/yd2
Icarex w/ 3M77 & CA......... 30 g ...... 1.78 oz/yd2 ..... NA
Polyester is one thing and may be color is another one for the difference between actual and retailer info (http://www.wattflyer.com/forums/show...3&postcount=1).
The tradeoff is "ripstop capability" + "biased covering" vs. "15g weight penalty" + "surface texture". Perhaps this is why Betamax choose to use Icarex/Mylar combination ......... Your choice.
BTW, Rendy is with you on So-lite/Ultrakote-lite...... .
Rendy, with film covering and ligter tail feathers, your AUW target has been re-adjusted from 9.9 oz to 9.0 oz ........ ..... With 3.35 oz/ft2 wing loading, it's going to be a sweet Manta .....
Old May 31, 2007, 10:53 AM
Geode is offline
Geode's Avatar
San Jose, CA
Joined Jan 2007
Wing Tip Shaping
For those who do not like free-hand sanding on wing tips, here is something might be helpful.
The tip has been "sliced" into three-piece contours. Stack three layers of 1/8" balsa to form the tip. R+1 and R+2 is above chord line and R-1 below. Sand to shape until the ridge disappears.
Old May 31, 2007, 02:02 PM
Ricardo RW is offline
Find More Posts by Ricardo RW
.: Looking for Thermals :.
Ricardo RW's Avatar
Chile, Quinta Región de Valparaíso, Los Andes
Joined Jun 2002
¡¡¡BRAVO, BRAVO, BRAVO!!!
My hat off.
And thank you for sharing it with us.
Ricardo.
Ricardo RW is offline Find More Posts by Ricardo RW
Old Jun 01, 2007, 01:13 AM
Rendy is offline
Find More Posts by Rendy
Rendy's Avatar
Santa Clara, California
Joined Aug 2004
Rendy's Manta: tail group photos
Tail surfaces done. Total weight : 12.6 g.
Rendy is offline Find More Posts by Rendy
Discussion Project Rays - Hyperbolic Manta Geode Hand Launch 28 Jun 12, 2008 09:50 AM
