Old Oct 01, 2008, 12:45 AM
Geode is offline
Find More Posts by Geode
Geode's Avatar
San Jose, CA
Joined Jan 2007
Sweet. That's some nice and smooth balsa. With a pointy tail too :-).
Geode is offline Find More Posts by Geode
Old Oct 01, 2008, 02:02 AM
Zack999 is offline
Find More Posts by Zack999
Joined Dec 2005
thanks I just used 220 grit because It is all I have. I need to find a boom though and I can't find any local sorces.
Zack999 is offline Find More Posts by Zack999
Old Oct 01, 2008, 05:51 PM
amuthajothi is offline
Find More Posts by amuthajothi
Joined May 2008
very nice looks like acompetition grade....
amuthajothi is offline Find More Posts by amuthajothi
Old Oct 01, 2008, 07:41 PM
Zack999 is offline
Joined Dec 2005
Im very particular about my wood selection If the store dosen't have a good quality I can wait a week plus with this particular pod I want to have a natual wood finish ;-)
Old Oct 06, 2008, 01:20 PM
martseger63 is offline
Find More Posts by martseger63
martseger63's Avatar
Estonia
Joined Feb 2007
Started on the wings, still rough.
100g on second pic, still to add spar caps,joining v-shaped plywood piece, little sheeting in center of the wing,throwing peg and reinforcements,covering. Ailerons gonna get also lighter, not decided yet, what kind of holes to make in them.
martseger63 is offline Find More Posts by martseger63
Old Oct 08, 2008, 12:21 AM
Zack999 is offline
Joined Dec 2005
I was wondering is anyone building there wing and useing the solid tip design? It seems all the people that have posted builds have done a hollow tip like Rendy. If you have can you please give me a over all weight of your wing Please. :-) and thankyou in advance
Old Oct 08, 2008, 02:56 PM
Rendy is offline
Find More Posts by Rendy
Rendy's Avatar
Santa Clara, California
Joined Aug 2004
Hi Zack,
I think you can make a solid wing tip very easily. Just use light balsa. When I build my wing tips, I was hopping I can build a light wing tip to reduce overall weight and Izz. Looking back on what I did.... I don't think I have reduced the weight that much. The real trick is to transfer the load from the throwing peg to the main spar. I hope this helps.
rendy
Rendy is offline Find More Posts by Rendy
Old Oct 09, 2008, 12:25 AM
Zack999 is offline
Joined Dec 2005
ok I was just wanting to save as much wight as I can. He he
Old Oct 10, 2008, 05:28 AM
Estonia
Joined Feb 2007
Here's some progress. The weight is 250grams. Elevator and rudder servos in,rx and battery in. Lightening holes to ailerons, cover the wing, and install wing servos, and that's it. I hope to stay under 320grams. My tailboom is also cut too short(10cm shorter distance between wing TE and h-stab LE, original is 45cm, mine is 35cm), but now i dont have to add nose weight to compensate longer tail.
Edit: FINISHED!
Auw- 320grams, CG at 1cm behind the spar.
Wing weighs 150grams with two servos. Can't wait to give her the first toss.
Old Oct 22, 2008, 02:39 PM
Estonia
Joined Feb 2007
She flew great! Yet again i maidened my Manta in high winds. 20mph this time to be exact. Definately launches higher with a proper tailboom. Flies better with the full size wing; turns on a dime. Im very happy, cant wait for the winds to set down a bit..
Old Oct 22, 2008, 08:53 PM
Geode is offline
Geode's Avatar
San Jose, CA
Joined Jan 2007
Congraduation on your maiden. It's a nice target weight at 320 g.
Find a nice calm day and try pushing the CG as far back as you could handle. In this way, you could get rid of some nose weight and she will detect thermal better .
Have fun,
Geode
Old Oct 22, 2008, 11:16 PM
Estonia
Joined Feb 2007
Well right now i have zero nose weight.
Old Oct 27, 2008, 02:54 AM
jcjung76 is offline
Find More Posts by jcjung76
Joined Nov 2006
request Manta printable plan~~
What a wonderful DLG plane~~!
I really want to make this model.
Could you please send me the printable plan to jcjung75@hotmail.com
best regards
jcjung76 is offline Find More Posts by jcjung76
Old Nov 02, 2008, 11:47 AM
Geode is offline
Geode's Avatar
San Jose, CA
Joined Jan 2007
Composite Manta
Just thought it might be a "safe" ideal to try out a composite version of "thin" airfoil, "narrow" chord Manta before go on to the balsa build up version.
Triple taper planform, foam tail feathers and Rendy's Carbon/Kevlar pod ....
Old Nov 03, 2008, 01:42 PM
kostuk is offline
Find More Posts by kostuk
Joined Nov 2003
Hi,
Does anyone have a good way for strengthening the wingtip for the launch blade on the Manta? I was just going to put some CF tow around the peg to the spar.
Ray
kostuk is offline Find More Posts by kostuk
Discussion Project Rays - Hyperbolic Manta Geode Hand Launch 28 Jun 12, 2008 09:50 AM
