Espritmodel.com Heli Air
Old Aug 04, 2008, 11:58 AM
atom007's Avatar
moscow. russia
Joined Jun 2007
Thank you very much for Manta plans!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
atom007 is offline Find More Posts by atom007
Old Aug 09, 2008, 11:56 AM
Joined Nov 2005
Ready
Hello!
Manta RDS is ready. Unfortunately it's 340 gramms My fuse is too heavy, with an SG pod I can save ~10 gramms. I haven't maidened it. RDS works well.
Smash is offline Find More Posts by Smash
Old Aug 09, 2008, 11:34 PM
Geode's Avatar
San Jose, CA
Joined Jan 2007
Love that RDS in full brake position. I guess your Manta will stop right on the spot when you pull the break.
As for the weight, 340 grams is OK with the extra wing area in Manta. Good luck with you maiden.
Geode is offline Find More Posts by Geode
Old Aug 10, 2008, 09:54 AM
orting Washington
Joined Dec 2006
would you please send me a set of plans
Thank you
waltbub@comcast.net
walt b is offline Find More Posts by walt b
Old Aug 16, 2008, 02:33 PM
atom007's Avatar
moscow. russia
Joined Jun 2007
Hello, Geode!
What servos do you use for control ailerons sd100 or sd150?
Thanks.
Old Aug 16, 2008, 10:51 PM
Geode's Avatar
San Jose, CA
Joined Jan 2007
Most of 5~10 grams servo with ~15 oz torque will do the job.
Old Aug 19, 2008, 03:39 PM
Joined Jul 2008
Hi,
Finally I finished the Manta. I maden it two weeks before:
First step was some single gliding:
Nkmkhun - Manta első hosszabb repülése (0 min 17 sec)
But I had a little problem with my first discus launch:
Nkmkhun - Manta pörgős start (0 min 18 sec)
Please don't laugh, clever person learns from other person fault, stupid from his own mistake
(This was my first DLG launch )
From this bad start the fuselage had broken, so the plane needed a little rework.
During the rework the wing got the launch peg, then came the next maiden. I glided the plane without any problem.
A video from the 2. start with launch peg:
Nkmkhun manta eldobás + repülés (0 min 29 sec)
and another one:
Nkmkhun manta eldobás (0 min 16 sec)
Now it is okay from a DLG beginner, I think
Unfortunatelly it weight is 450 gr
Thanks to the too much carbon in the wing, the big and heavy pod (but it looks great), the bigger AAA size 350mAh accus, and the normal rx.
I can throw it only about 20-25 meters. From this height it flies 30-35secs.
But it will be good for improve my skills and launc technics, while I will make the second one.
All of my acknowledgements Geode, I can imagine how it can fly with 300 gr.
But I hope I can't imagine it only, but I will control it (next one)
Can we get some information about the Manta 2?
For the next one I will use the balsa pod and I will purchase smaller accus, a micro rx, and I use only a small carbon stripe on the wing to keep the strength and for the launch peg.
What do you think about the light balsa?
Is it enough strength to build all the wing from it?
Cheers,
Wyncee
wyncee is offline Find More Posts by wyncee
Old Aug 20, 2008, 02:33 PM
Villa Adriana,Rome,Italy
Joined Oct 2006
Hello Geode great model. Could you send me the plans to my adress, max.anto@inwind.it.
I have fuse and pod from Atlanta hobbyes.
Thank you best regards Max
excaliburmaxi is offline Find More Posts by excaliburmaxi
Old Aug 21, 2008, 10:18 AM
Geode's Avatar
San Jose, CA
Joined Jan 2007
Hi Wyncee,
That's a really nice Manta. At 450 grams and she still glide at a very nice sink rate. I'm very surprised.
With some practice, I believe you can lauch a lot higher. Find a nice thermal day and you're very likely to find a thermal and go all the way up.
Light balsa is a must to reach 300g target weight. If you feel the wing strength is not enough, try using light balsa in the wing center and gradually move to the harder balsa near wing tip. Using light balsa for DBOX is probably one of the most rewarding area for weight saving.
As for Manta 2, I don't thing I can keep up with you learning curve. Too many side projects on hand.
Max, check your mail box for printable plan.
Geode
Old Aug 24, 2008, 12:22 PM
Joined Apr 2007
hello Geode
I receive manta's plans, it's ok and I can build it.
thank you.
Raph.
igorstone is offline Find More Posts by igorstone
Old Aug 26, 2008, 08:11 PM
not bad for one eye
atlantic canada
Joined Jun 2008
would love to have a set of plans if you could, there are only a few more months of good thermaling left in canada, eh?
thanks
arwen@nb.sympatico.ca
dlpaul is offline Find More Posts by dlpaul
Old Aug 30, 2008, 12:36 PM
Joined Nov 2005
Hi!
I put in the throwing peg: 25 glass, laminated with CA and some carbon.
I did aorund 40 starts, higher and higher but in the end my boom gave it up and broke
I'm not so happy now, becouse I can't find any good carbon boom to my Manta so I can't repair it yet. I'm thinking about a new home made carbon boom...
Fortunately only the boom broke.
A small clip: http://video.google.com/videoplay?do...40252226988768
Old Sep 04, 2008, 04:02 AM
Joined Feb 2008
nice plane
hi i'm korean. this plane is very nice
i want make it.
would you please send me manta
nabest2@naver.com
thanks
inpuple is offline Find More Posts by inpuple
Old Sep 04, 2008, 10:29 AM
Joined Jun 2006
Hi, can you sent me the plan of this fantastic dlg please
dennis_dierckx@hotmail.com
thanks
Dennis
Dennis286 is offline Find More Posts by Dennis286
Old Sep 07, 2008, 11:40 AM
't Harde, the Netherlands
Joined Jul 2005
Hi Geode,
I'd like to build this plane as the succesor of the OFA. The Dutch DLG. The performance of this plane is good for a beginner, but I expect more. The Manta will fullfill this requirement with its ailerons and bigger wingspan.
Please send me a copy of the plans at
Looking forward hearing from you.
Br
Gerhard
gait is offline Find More Posts by gait
Discussion Project Rays - Hyperbolic Manta Geode Hand Launch 28 Jun 12, 2008 09:50 AM
