Old Jul 27, 2008, 11:33 AM
Geode is offline
Find More Posts by Geode
Geode's Avatar
San Jose, CA
Joined Jan 2007
Originally Posted by wyncee
Hi Everyone,
I will use bigger accu and a normal Futaba receiver, so I have to design a new a little bigger pod.
What are the experiences?
Usually nose or tail heavier the Manta when it is ready?
I use lightest possible electronics for DLG and I'm always tail heavy (still learning how to build a light and strong tail).
Nose heavy is less of a problem because of the 1:4 ratio on the moment arm. Every 4 grams on the nose only need 1 gram on the tail to balance.
If possible, you might want to consider light weight electroincs to keel the all up weight down. To keep the weight down, I remove the RX case and replace the antenna wire with the thinnest metal wire I could find.
Geode is offline Find More Posts by Geode
Old Jul 29, 2008, 02:16 PM
Smash is offline
Find More Posts by Smash
Joined Nov 2005
I think I leave this half with this weight, I don't want to make it too weak with more lightening holes, now it's strong enough.
Smash is offline Find More Posts by Smash
Old Jul 30, 2008, 09:26 AM
Smash is offline
Joined Nov 2005
Okkay, the other half of the wing is 59 gramms. The aileron is 13 gramms, so I make a new instead of the heavy one. With these the wing weight will be ~120 gramms and ~130 with the covering
I've made a boom during the night, (i never done it before) 3 layers of 25g/m2 glass and 4 carbon roving. It's 21 gramms.
Edit: One hour later...
Old Jul 30, 2008, 11:18 AM
Geode is offline
Geode's Avatar
San Jose, CA
Joined Jan 2007
Congraduations! That's a new record low for Manta wing weight.
Love that RDS for balsa DLG. Keep us posted on your progress.
Geode
Old Jul 30, 2008, 03:03 PM
wyncee is offline
Find More Posts by wyncee
Joined Jul 2008
Hi,
One wing is almost ready, the other is started.
Unfortunatelly it is a little heavier than I expected. It's 130 gr without carbon rowing; launch peg and covering. It will stop around 160-170g with servos, but its will be very strong, so I can launch it with full power .
For the next wing I will use lighter and thinner balsa
Maybe I will buy a small RX and smaller battery to keep the weight down. Next week Monday the pods will be ready from glass.
One of my acquaintance has a scheme to make one, end it looks great too.
wyncee is offline Find More Posts by wyncee
Old Jul 30, 2008, 03:13 PM
wyncee is offline
Joined Jul 2008
What are your opinion?
May I lighter the end of the wing?
I mean cut holes into the wingtips like Smash did, than stick a thin carbonlayer on it. Maybe I can save a few grams on it...
Old Jul 30, 2008, 03:56 PM
Smash is offline
Joined Nov 2005
Szevasz! (╔rtekezhetnÚnk az otthoni fˇrumon is!)
In my opinion You can make lightening holes into the wingtips, it won't be too weak, but You can save 7-8 gramms. I've measured my tips before/after.
Old Jul 30, 2008, 10:30 PM
Geode is offline
Geode's Avatar
San Jose, CA
Joined Jan 2007
That should be no problem. In Rendy's Manta, the wing tip is actually sheeted balsa like the regular Dbox. It's all hollow inside his wing tips although it looks like solid balsa from outside.
Old Jul 31, 2008, 05:25 PM
Smash is offline
Joined Nov 2005
I've made the fuse, it's 21 gramms (2 layer 80 glass and one 25) and with the boom is ~45 gramms.
I'm thinkin about the RDS now.
On the weekend I go to an F3B competition so I won't able to work on the Manta
Old Jul 31, 2008, 05:51 PM
AC5FF is offline
Find More Posts by AC5FF
Where'd The Wise Men Go?!?
AC5FF's Avatar
United States, NE, Bellevue
Joined Sep 2007
Can someone quickly explain RDS? Watching this thread w/interest and these last couple pictures threw me for a loop...
AC5FF is offline Find More Posts by AC5FF
Old Jul 31, 2008, 06:03 PM
Smash is offline
Joined Nov 2005
Hi!
Check these out:
http://charlesriverrc.org/articles/s...G2/sg2_rds.pdf
http://charlesriverrc.org/articles/s...SuperGeeII.htm
Old Jul 31, 2008, 06:35 PM
jrgospod is offline
Find More Posts by jrgospod
jrgospod's Avatar
Fort Wayne, IN
Joined May 2002
From the full size expert:
http://augiemckibben.tripod.com/site...ive_system.pdf
http://augiemckibben.tripod.com/site...hard_slots.pdf
John
Edit:
check out the rest of the pages for great build info.
Page moved: Updated
jrgospod is offline Find More Posts by jrgospod
Old Jul 31, 2008, 08:09 PM
AC5FF is offline
AC5FF's Avatar
Joined Sep 2007
Okay... RDS.. now it rings a bell. I knew I had heard of it before, but the photos above just threw me for a loop... expecially w/the servo arms still attached :P
Old Aug 03, 2008, 07:06 AM
atom007 is offline
Find More Posts by atom007
atom007's Avatar
moscow. russia
Joined Jun 2007
From Russia with love :)
Hello, Can you please send me also the plans.This is my e-mail adress cyborg3d@mail.ru
Very nice plane!!!
Thanks you very much.
Aleks.
This is my QFII http://www.rcgroups.com/forums/attac...mentid=1994042
atom007 is offline Find More Posts by atom007
Old Aug 04, 2008, 02:59 AM
Geode is offline
Geode's Avatar
San Jose, CA
Joined Jan 2007
That's a very nice and beautiful QFII with aileron. Have fun with you Manta project.
Geode
Discussion Project Rays - Hyperbolic Manta Geode Hand Launch 28 Jun 12, 2008 10:50 AM
