Old May 19, 2007, 05:36 PM
Hoofddorp, Netherlands
Joined Sep 2004
Tri/hexa-copter or Quad/Octa-copter and Spartan AP2000i or Helicommand
I-m highy interested in using something mechanically simpler and with less large blades than an heli as an aerial photography platform. That does require it to be able to hover hands-off reasonably stably with little more than some wind drift.
I understand a number of people have successfully used e.g. 120 degree CCPM mixing on their Tx together with gyros and v-mixers to get stable flight with tri/hexa-copters or quad/octa-copters. Has anybody tried mating any of these designs with either the Spartan AP2000i helicopter stabilisation system or with the Helicommand. I would assume the first might be more interesting with it-s infrared FMA sensor as this would be introducing an additional sensor to the gyros already being used, whereas the Helicommand would effectively be adding more gyros. Both would be adding electronic swashplate mixing to the airframe instead of from the TX.
Arthur P. is offline Find More Posts by Arthur P.
Old May 20, 2007, 10:03 AM
Joined Sep 2006
Arthur,
IR stabilisation have typical sensor update frequenties of around 30 HZ, this is fine for helicopters since they are inherently are more stable.
For tri or quads a minimum of of 50 hz is required beter would be 100 hz or more.....
FYI the pulse to the (normal) servos is 50 hz but that doe not mean each pulse has a new value so the refresh rate of the sensor is the limiting factor.
I have (PCB for tricopter) combined FMA CPD4 with use of normal rate gyroscopes (before I switched to accelerometers and IMU) this works fine allthough it is a slightly expenive stabilizing solution.
Also remember no indoor flying and or flying near big buidlings possible!
Peter
Djago is offline Find More Posts by Djago
Old May 20, 2007, 03:02 PM
Joined Sep 2004
Thanks Peter, that's clear.
Found Zen G38, G45, or US 41 or Quad 42 ckangaroo70 Aircraft - Fuel - Engines and Accessories (FS/W) 3 Feb 23, 2007 07:26 AM
Are there any RTF, or ARTF planes with 10" or less wingspan for $100 or less? Dirtball Indoor and Micro Models 1 Mar 23, 2003 11:48 PM
2 or 3 Kokams w/ 4.8 or 7.3 IPS ??? JTinCT Parkflyers 39 Dec 08, 2002 10:36 AM
FS or Trade: BrshLs /Brsh ESCs, Motors, or Radios Frankenator Aircraft - Electric - Airplanes (FS/W) 12 Nov 11, 2001 11:14 PM
