Old Oct 27, 2002, 08:26 AM
Far4nugn is offline
Find More Posts by Far4nugn
Far4nugn's Avatar
Raleigh, NC
Joined Nov 2000
Best AR for RG-15 at 500 in2? (Q-500)
I want to scratch-build a Q-500 pylon plane and plan to use a foam core/sheeted/glassed wing. I need to stick to 500 in2 and would like to know if a span of longer than 50" would be appreciably faster on a pylon course.
Also, I've noticed the V-tail trend is to mount the stabs from the bottom of the fuse rather than the top, thus leaving the tail end of the fuse 'inside' the "V". What is the advantage to this? Are the acute angles formed at that point on the top less draggy than the "Y" style intersection?
TIA!
Far4nugn is offline Find More Posts by Far4nugn
Old Oct 27, 2002, 09:22 AM
DaveSawers is offline
Find More Posts by DaveSawers
Canada, NS, Lunenburg
Joined Oct 1999
Q500 pylon rules normally state that the span has to be between 48" and 52" (I think) at constant chord. This prevents high aspect ratio models or any kind of design that might be considered pretty.
As for the V tail positioning. I've not seen any of the low mounted ones but I don't imaginé there's much if any aerodynamic advantage.
I'm going to move this to the gas high performance discussion, leaving a link here.
DaveSawers is offline Find More Posts by DaveSawers
Old Oct 27, 2002, 10:09 AM
Far4nugn is offline
Far4nugn's Avatar
Raleigh, NC
Joined Nov 2000
Dave, thanks. I intentionally left out any 'dirty' words because I figured I'd get better response over here.
As for the V-tail mounting, the Vixen is one notable:
Photo from: Matney Models web site.
Old Oct 28, 2002, 01:35 AM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
After looking at the picture, could they be doing this to enclose the linkage? That would help decrease drag.
GregG is offline Find More Posts by GregG
Old Oct 28, 2002, 06:14 AM
Far4nugn is offline
Far4nugn's Avatar
Raleigh, NC
Joined Nov 2000
Possibly.?
Another reason I like this design is that the servo is pulling to give up elevator. I've had pushrod flex problems before that have almost wrecked my plane because I couldnt pull out of a high speed dive.
Old Nov 06, 2002, 01:57 PM
banktoturn is offline
Find More Posts by banktoturn
Joined Nov 2002
Those little "V" shaped junctions do cause drag, and having two of them like that is worse than having one on top with a less acute angle. I bet that GregG is right, and this configuration is used to hide the control horn. I would guess that the exposed horn would cause more drag than the acute junctions, but it's only a guess.
banktoturn
banktoturn is offline Find More Posts by banktoturn
Discussion Best prop for Jeti 15/4 and Electrostreak? jmparsons Power Systems 17 Nov 25, 2007 10:01 PM
Contest Q-500, Q-40, & Micro Pylon Racing at the Basin (9/30) pdawg High Performance 37 Oct 06, 2006 12:10 AM
Center of Pressure for RG 15 flusterfly Slope 19 Oct 26, 2005 05:44 PM
Best battery for Filip 600 w/geared Speed 500??? jshelton Electric Sailplanes 13 Apr 27, 2004 03:14 PM
Best outrunner for 400-500 watts? StefV Power Systems 21 May 06, 2003 02:54 PM
