Old Jan 03, 2008, 02:27 AM
steve wenban is online now
Find More Posts by steve wenban
Crikey never leave beer behind
steve wenban's Avatar
Mt Annan Sydney Australia
Joined Dec 2003
Oh it was good alright flew the Salto from the pieshop and lift was good ,even though it was southish there was no rotor on the approach and the Salto is in one peice after 2 successful flights.
SteveW
steve wenban is online now Find More Posts by steve wenban
Old Jan 03, 2008, 05:40 AM
OzDragonFlyer is offline
Find More Posts by OzDragonFlyer
Model Bender
OzDragonFlyer's Avatar
Australia, NSW, Newcastle
Joined Jun 2004
Originally Posted by Moth Man
Dave,
Maybe you need an opal mine to afford the spare parts
Tim.
..if i stripped the car down and sold the parts individually, it would easily pay for a new ferrari
Was a pretty good day at otford.. found out my jazz wing has quite good autopilot abilities when the battery becomes unplugged mid air. And Steves new Salto was really impressive for a first flights. Hope it's more of the same tomorrow.
OzDragonFlyer is offline Find More Posts by OzDragonFlyer
Old Jan 03, 2008, 06:44 AM
Joined Dec 2003
Possilble Jart 1 sighting but without the use of absailing gear it may stay lost even if it is the Jart '
SteveW
Old Jan 03, 2008, 07:44 AM
nator_au is offline
Find More Posts by nator_au
RC recluse
nator_au's Avatar
Australia, NSW, Fletcher
Joined Dec 2004
Steve,
I can help out with some abseiling gear!
As long as its not more than 50mt cliff, i cut my 100mt rope just last week
I can probably do next weekend, if that suits.
nator_au is offline Find More Posts by nator_au
Old Jan 03, 2008, 03:10 PM
Joined Dec 2003
That would be cool Brett ,I dont think its that far down but it just out of reach according to the young guys that spotted it. I'll be down there all this weekend .
would be nice to get the number 1 Jart home .
SteveW
Old Jan 03, 2008, 06:04 PM
Fred_L is offline
Find More Posts by Fred_L
If it flies - it's good
Fred_L's Avatar
Australia, NSW, Sydney
Joined Sep 2003
It's 10 am an FlyStanwell is reporting 16 knots ESE. I am packing the car.
The BOM says the wind direction should hold till late afternoon.
F
Fred_L is offline Find More Posts by Fred_L
Old Jan 04, 2008, 02:34 AM
greggold is online now
Find More Posts by greggold
slope soarer
greggold's Avatar
Sydney Australia
Joined Dec 2006
Friday
excellent day with wind directly east most of the day, 18 km and increasing a little above 20 km later in the day. Lots of people and lots of great flying. I had some good flights with the halfpipe and the miniblade, and 2 disastrous crashes with my bird (see my other post for details including air crash investigation report). Both times the model ended up a long way down the slope, and the second in particular on the southern end involved struggling down some very steep stretches of hill with thick vegetation. Using a lost model finder I found the model hanging in a vine attached to a tree, and as I approached the tree (I was clawing my way through thick bush on a steep slope) large magpies started to cry in alarm. I got the model, and when I came away from the tree I was dive bombed by 2 magpies, fortunately they missed.
GregG
greggold is online now Find More Posts by greggold
Old Jan 04, 2008, 02:45 AM
slope soarer
greggold's Avatar
Sydney Australia
Joined Dec 2006
2.4 Ghz Rx in a carbon fuselage
Today I had 3 episodes of radio failure while flying the bird. I was using a JR 9303 Tx and Spectrum AR6200 receiver. The model had been previously flown with a AR6000 Rx, and as I recall this was the first flight with the AR6200. (Spectrum say the AR6000 is a parkflyer rx, and the AR6200 is full range). I did not do a range check (doh). On several previous occasions when I have reviewed what I did following a major disaster, I ended up thinking surely I could not have done that, and this is looking like one of those occasions…
I had a similar setup in both the bird and the miniblade, with one key difference, on the miniblade both rxs were outside the fuselage (see photos).
In the first episode the bird nosed up violently, and also yawed sharply; I said at the time Wow! And then since the model was in strong lift at the time I concluded I hit a big updraft, and I continued to fly; everything then seemed normal. Five minutes later in the same flight while a fair distance from the Tx the model gave some major twitches, then entered a spiral dive and descended maybe 100m and hit the slope. When found it was suspended 10 cm off the ground in a low shrub and was undamaged.
The third episode is hard to imagine and involves (a) without disassembling the radio and proper testing, I concluded on the basis of careful examination of the model and viewing the action of every control surface that there was no damage, AND (b) I again decided to fly the model without doing a range check.
The flight appeared perfectly normal for about 15 minutes, then when the model was at quite a big distance, again there were major twitches and again a spiral dive. This time up elevator seemed to alter the steep nose down attitude to about a 30 deg nose down attitude, slowing the plunge. When the model was found it was in a small tree, having snagged on a creeper vine, and was suspended a metre above the ground. Again it was completely undamaged (the cockpit cover was still in place, although displaced a little).
The controls all worked normally. When I got it home I did a range check without touching anything, and I found that at 12m if I pointed the TX away from the model the controls stopped working. I removed the cockpit cover and the range check was then OK. I replaced the cover and I could reproduce the problem.
Old Jan 04, 2008, 03:01 AM
ZIPPER is online now
Find More Posts by ZIPPER
by ZIPPER
ZIPPER's Avatar
East Kurrajong Sydney Australia
Joined Aug 2004
Here is some video of Steve's Salto and a bit of a Drongo from yesterday.
http://www.rcgroups.com/forums/showt...17#post8855307
Glenn
ZIPPER is online now Find More Posts by ZIPPER
Old Jan 04, 2008, 04:04 AM
BMtech is offline
Find More Posts by BMtech
Scorpian 60'' 2012
BMtech's Avatar
Kurrajong Australia
Joined Jul 2005
Greg, I think I read some were that you are to have 1 set off aerials vertical & 1 horizontal & don't bend them !!!! just a thought.
Rick
BMtech is offline Find More Posts by BMtech
Old Jan 04, 2008, 04:06 AM
BMtech is offline
Scorpian 60'' 2012
BMtech's Avatar
Kurrajong Australia
Joined Jul 2005
Ill be there after lunch on Saturday
Hay Steve, it could be my Eraser that my son lost the same day as my Moth went MIA ,may be one of us will be happy
Rick
Old Jan 04, 2008, 04:24 AM
Joined Dec 2003
Yeah could be Rick I'm not building my hopes up but the area they are saying its at is where the Jart disappeared.
SteveW
Old Jan 04, 2008, 05:33 AM
Model Bender
Joined Jun 2004
omgz is that freds banana?
Old Jan 04, 2008, 05:54 AM
slope soarer
greggold's Avatar
Sydney Australia
Joined Dec 2006
"re: Greg, I think I read some were that you are to have 1 set off aerials vertical & 1 horizontal & don't bend them !!!! just a thought.
Rick"
Yes, that is one change I am going to make. I had thought the AR6200 would not be fussy about that point, but maybe it would be useful after all. (Actually both points, as my 2 receivers had the wires a bit bent, and not at rt angles). The AR6000 which is DSM1 technology and allegedly not as good as DSM2 may have a better aerial arrangement as I have flown the bird with it in place. I am doing a few more tests and then I might post the example on the radio forum
GregG
Have you seen Peter Jensen at your slope or flying site??? Admiral_Red Slope 7 May 07, 2004 02:14 PM
Slope soaring site in Carson City NV??? hmhoshi Slope 3 Dec 13, 2002 11:50 AM
Slope soaring site in Carson City NV??? hmhoshi Slope 0 Nov 27, 2002 02:35 PM
Slope soaring site locator LJH Electric Sailplanes 1 Jul 24, 2002 09:46 AM
