Michigan
Joined Apr 2001
ScottGTO:
They are ball bearing motors from Miracle Mart. They are also available from a US source: http://www.slickzero.com/Merchant2/m..._Code=Upgrades I consider these to be a worthwhile upgrade because the motors run so much cooler - I expect them to last longer. The rudder trim drift is also significantly reduced. See: http://www.rcgroups.com/forums/showthread.php?t=638388 |
Joined May 2007
How long before you get the batteries cx2parts.com klondikes? I am assuming you got on the pre-order list for their new batteries. No? The ones from cx2parts(if I order 2) are about the same price as the 2pack of DN power from xushobby.com. So if the cx2parts ones seem better let me know.
Thanks |
Thanks Rob. Just installed Stersman's boom, awesome. Now just need to find lower cost batteries, E-flite swash and upper&lower rotor assy's on the list
Joined May 2007
Just had a couple bad crashes today. The first just smashed the two from canopy holders all to hell. No the canopy holder on the lower front doesn't do a whole lot. Second crash I snapped a blade in half and bent my fly bar a little. I got the fly bar as straight as I could, but is that bad and should I get a new one?
Thanks Also those ball bearing motors sound nice, but I can't find them on the U.S. source. |
Well I flew a pack tonight after the boomtown stuff installed. I have a real bad vibration. It was there prior to the new boom, little less noticeable now with the carbon tail but I think it is causing my battery to lose juice faster maybe due to the gyro having to correct the wobble. I think I have a bent flybar, and the last time it was apart I noticed the outer shaft was a little bent. Maybe this is the issue. BTW. I just got back from the lhs and picked up Alum Swash, upper and lower alum rotor assy, and alum bearing cup.. Here is some pics
Joined May 2007
I've read that unbalanced blades will cause the tail vibration. I noticed a vibration in my tail(stock) and then I balanced the blades and the vibration was then unnoticeable. Also I did a full load volt test on my battery today, it looks like under full throttle the battery voltage drops about .30 vdc.(I did this full load test when my cells where both at about 3.84 and they both dropped to about 3.54/I did the cells at separate times.) So when I ran my batt. down to when one cell was 3.00 vdc, I probably only loaded it enough to just dip below 3 volts. I would notice it losing power so I would set it down then just give it about half a stick and it wouldn't lift so I know the batt. is low. Hopefully my boom and skids from Jamie will be here Friday or Saturday.
Joined May 2007
Just got my boom and skids from Jamie and what a difference it made in ease of flying. My only problem is I crashed it yesterday and hadn't spooled up after the crash until I installed the new parts. Well I fired it up today and my lower drive gear is missing a tooth, the place closet to me that sells parts closed over an hour ago. Well I ordered new batteries(DN power) from Jamie and those should be here a few days. I assuming it will be bad to fly the heli with the missing tooth(well I flew it for about 7 min. today to try out the boom), so I guess I'll have to wait.
-Adam |
Cool. I think I have 2 issues causing the wobble/vibration. I balanced my blades which helped a bit. My outer shaft is bent and I also have a bent flybar. I hope to find this carbon one: read post #1167
http://www.rcgroups.com/forums/showt...607057&page=78 The boom is awesome and the skids too. Let me know what you think of the DN battery. |
klondikes |
Joined May 2007
I have an idea for charging the batteries in your car and wondering if anyone else has done this. At a local department store they sell 12v cigarette lighter plugs with just the wires hanging out. So I'm thinking I could use this to charge if I'm driving and keep an eye on it. I would hate to clip it to the battery under my hood and drive away.
-Adam |
| Thread Tools | |
| Discussion Just got my first micro e-heli. Need noob help! | diy_guy | Micro Helis | 2 | Jun 19, 2007 08:05 PM |
| Help! just got my first heli , eflite blade cp | Rcgary20 | Micro Helis | 7 | Mar 15, 2006 02:42 PM |
| Just Got My First Heli!! ECO Piccolo V2 | The1User | Micro Helis | 8 | Mar 09, 2005 12:38 PM |
| Just got my first lithium charger...need help!!!What is a jumper? | thor4944 | Batteries and Chargers | 4 | Jun 28, 2003 07:50 PM |
| Just Got my first look at the GWS Tiger Moth-Small battery compartment! | mrebman | Parkflyers | 3 | Jul 10, 2001 08:47 PM |
