Old Dec 09, 2012, 03:00 AM
Peter M is offline
Find More Posts by Peter M
Peter M's Avatar
Newcastle, New South Wales, Australia
Joined Sep 2007
Murdo,
Congratulations on taking the crown! Well done and nice flying.
Regards
Peter
Peter M is offline Find More Posts by Peter M
Old Dec 09, 2012, 03:27 AM
DoctorAudio is offline
Find More Posts by DoctorAudio
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
Originally Posted by BpPilot View Post
So if I am going to spackle, should I just make sure to get the whole thing covered in locktite 200? As in, no where for the lam to directly touch the spackle?
Or will the spackle still be a problem for the lam?
I hate spackle .
I would use the good. I'm am using good mixed. with micro ballons . It fills and is same color as foam.
DoctorAudio is offline Find More Posts by DoctorAudio
Old Dec 09, 2012, 08:18 AM
elliott000 is offline
Find More Posts by elliott000
Canada, BC, Vancouver
Joined Feb 2012
What the hec are micro ballons...
elliott000 is offline Find More Posts by elliott000
Old Dec 09, 2012, 10:12 AM
Svede is offline
Find More Posts by Svede
Svede's Avatar
United States, CA, Redlands
Joined Nov 2008
http://www.cstsales.com/cst_epoxy_fillers.html
Svede is offline Find More Posts by Svede
Old Dec 09, 2012, 11:53 AM
D.B. Hooper is offline
Find More Posts by D.B. Hooper
Flirtin With Disaster !!
D.B. Hooper's Avatar
United States, OR, Mt Angel
Originally Posted by Hance View Post
What's your in flight amp draw like with the 6x5? On the 6x4 I am seeing 90 or so amps in flight.
Amps peaked @ 109 but this was spike. Average was around 90 to 95amps.
Temp 159
voltage average was 22.5 with my 3year old XPS 65C 4000mAh
2265watts peak
D.B. Hooper is offline Find More Posts by D.B. Hooper
Old Dec 09, 2012, 12:00 PM
Originally Posted by murdnunoc View Post
YOWWEE!!!
Took the 36mm motored Demon up for a spin today in a field where I could really open it up.
189mph level, averaged passes!!
Nice run! That's hualing A$$!
Old Dec 09, 2012, 12:12 PM
murdnunoc is offline
Find More Posts by murdnunoc
Victim of C.D.O.
murdnunoc's Avatar
United States, TX, Lubbock
Joined Oct 2007
Temp 159
2265watts peak
3.75V/cell at 90-100A isn't unheard of, but it's not expected, either.
If you go to the Castle data graph for that setup on that prop, and place the cursor at a place where you're at full throttle, does the "cursor" line read 22.5V at the same location as the 100ish amp/100% power mark?
Max and Minimum data points don't do a lot for us, as they're usually spikes that don't tell what the setup is doing under a constant load.
Average data points over a whole flight are the same, as they average in times when the model is idle, which raises average voltage and lowers average amp draw.
Are you able to get a hold of a screen shot of the data graph, Hoop?
I promise...
All this geeky data stuff is in the interest of getting the perfect motor!!
Mega has a LOT of options, and you can really get the ideal motor if you put in a little work.
murdnunoc is offline Find More Posts by murdnunoc
Old Dec 09, 2012, 10:52 PM
I promise...
I cleared the log after I looked at it. I did have a good look at the data.
The averages I gave for amps and voltage didn't include the spikes.
Looking at the graph my fast passes where drawing around 95amps and the voltage was dropping to 22.5. So, what you are saying about the cursor line on the graph is true.
Whatever motor, prop, battery combo we come up with I would rather not be on the edge of total meltdown with my lead thumbs I'll be getting some new batteries 4000 to 5000mAh 45/90C Nano's ? I do want to keep the ICE 100 ESC W/ heatsink. Looking for at least as much power as the rocket motor and 160mph+.
Hoping to have it here before Xmas so I can buzz Santa and the raindeer.
Old Dec 09, 2012, 10:59 PM
Hance is offline
Find More Posts by Hance
Expo is built into my thumbs
Hance's Avatar
USA, ID, Niter
Joined Jul 2008
I smacked in my demon and trashed my batteries when I did. I ended up going from 2 3s 5000 nanotechs to 2 3s 4000 gens ace packs. The gens ace match the nanotechs almost perfectly as far as the voltage they hold and the current I am pulling. The kicker is the gens ace packs are way cooler when I land.
edit: I sent my flying buddy a pic of my Zephyr 2 and his reply was nice Zagi. Is it ok to punch him in the throat next time I see him ?
Hance is offline Find More Posts by Hance
Old Dec 10, 2012, 10:16 AM
Permission granted!
One of my first few hand launches with the Demon went bad and it turned my new XPS lipo's into a taco shape. I figured they where done for but I flattened them out recharged them and have been using them 3 years now.
What motor are you running in the Demon? How fast is it? Anxious to get mine back in the air.
D.B.
Old Dec 10, 2012, 10:22 AM
Milwaukie , Oregon
Joined Feb 2003
Nope, he didn't try to steal your car or you Z.
So, I say that a junk punch is more than acceptable.
Permission granted!
D.B.
If you un-taco your batts vry quickly, you can save them!
Now if the one of the cells pop open or split that is another thing.
Old Dec 10, 2012, 10:24 AM
Hance is offline
Hance's Avatar
USA, ID, Niter
Joined Jul 2008
Permission granted!
D.B.
I have the 1900kv rocket motor on mine so basically the same setup as you. We have clocked it on a certified police radar at 165 several times. I was going for top speed so I was using a long shallow dive to try and be at 10 feet or so of elevation when the plane passed me. I don't recall what the wind was doing at the time.
Old Dec 10, 2012, 02:43 PM
BpPilot is offline
Find More Posts by BpPilot
Molon Labe
BpPilot's Avatar
United States, CA, San Luis Obispo
Joined Feb 2008
How do you guys normally attach your 28mm cans with the big ole hpi heatsink?
BpPilot is offline Find More Posts by BpPilot
Old Dec 11, 2012, 01:46 AM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
Hi Murdo,
Fantastic video. I had to watch it twice in a row.
....just wow.
22/50 next ???? Oh my god.
Among the various options, consider this one too:
Drop 1 cell count on the MEGA you have in there now, and try over pitch prop.
......yeah yeah, I know that you supposedly will get more torque roll, but worth trying to see what happens.
You already have a 22/60. I assume the reason you are not going with that is due to C.G.
I better go watch your video again.
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Dec 11, 2012, 11:04 AM
Guess I'll see if I can get another Rocket motor from CK. Worked great for over a year and the price is right. Not sure I want to gamble with the Mega only to have it go up in smoke. Too many choices for me to come up with the right one. Maybe someone has a Rocket motor laying around they would sell?
Just want to get the Demon back in the air.
D.B.
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Build Log RiteWing 48-FT build thread theclaw Slope 46 Dec 09, 2007 08:53 AM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
