Old Dec 03, 2012, 02:41 PM
Svede is offline
Find More Posts by Svede
United States, CA, Lemoore
Joined Nov 2008
Lightweight spackle, the kind where you pick up the one gallon tub of it and it feels empty
Svede is offline Find More Posts by Svede
Old Dec 03, 2012, 04:48 PM
BldrFlyr is offline
Find More Posts by BldrFlyr
BldrFlyr's Avatar
United States, CO, Boulder
Joined Nov 2012
FPV Zephyr II with Ruby - Devils Thumb
Zephyr FPV - Devils Thumb (6 min 31 sec)
BldrFlyr is offline Find More Posts by BldrFlyr
Old Dec 03, 2012, 05:44 PM
brosius85 is offline
Find More Posts by brosius85
never mind the boll⁣⁣⁣ocks
brosius85's Avatar
Australia, NSW
Joined Dec 2010
extreme cross poster of the day!!!
brosius85 is offline Find More Posts by brosius85
Old Dec 03, 2012, 06:22 PM
murdnunoc is offline
Find More Posts by murdnunoc
Victim of C.D.O.
murdnunoc's Avatar
United States, TX, Lubbock
Joined Oct 2007
The spackle is what we're looking for an alternative for, because while it's easy and great at smoothing and leveling, it doesn't have good bonding capability or flexibility.
Mixing spackle in with the Goop won't be a good idea, since the spackle is water based and the Goop is solvent based. The filler needs to be something in dry powder form.
Microballoons mixed with the thinned Goop is the only thing I can think of as of now. Haven't tested it though so that's just my initial idea.
The thinner the Goop, the more microballoons you can add to get a spreadable filler.
But too much solvent thinning the Goop and it will lose its bonding ability.
Toluene is the solvent to thin Gooop. It's hard to get though since it's so nasty.
Xylene is widely available in the paint department as a substitute for toluene, and it works well for thinning Goop.
murdnunoc is offline Find More Posts by murdnunoc
Old Dec 03, 2012, 08:12 PM
Hance is offline
Find More Posts by Hance
Expo is built into my thumbs
Hance's Avatar
USA, ID, Niter
Joined Jul 2008
Originally Posted by dawsonh View Post
Wow! All this talk of thinned GOOP and exotic fabrics has me flashing back to CK's "Rubber Raider" days!
Dawson
I had the rubber raider in my hands at CK's place one day. I think it would fly through a brick outhouse without a scratch
Hance is offline Find More Posts by Hance
Old Dec 03, 2012, 09:30 PM
Svede is offline
Joined Nov 2008
I see where you are coming from, but that's just not the reality of the situation. It's a whole lot more spackle then GOOP/toluene substitute and both evaporate just fine. On test pieces the Kevlar would rip foam away rather than separating from the foam in many places, and had a MUCH better "peel strength" then regular composites and pink/blue foam. In my book that is way better than good enough.
If you did tests and proved that microballoons were better then spackle then I'd use it too, but if it's already stronger then it needs to be, what's the point?
Not trying to be argumentative, but that is what the tests I did showed and it has held up infinitely better then laminate as well as being lighter and looking a heck of a lot better (no offense CK).
Old Dec 03, 2012, 10:33 PM
Victim of C.D.O.
murdnunoc's Avatar
Joined Oct 2007
No I'm glad you've done the testing, Svede!
I really just didn't think the two would get along well because of the different carrier solvents.
I'd much rather use the spackle/goop than microballoons/goop for the safety factor.
Now I want to get building another Demon to try it out...
Maybe an EDF Demon. I seem to have gotten myself wrapped up in that stuff lately...
Old Dec 04, 2012, 07:34 PM
BpPilot is offline
Find More Posts by BpPilot
Molon Labe
BpPilot's Avatar
United States, CA, San Luis Obispo
Joined Feb 2008
So, you guys think that thinned goop is any better for riteweave as opposed to 3M 90?
Or should the 3M 90 still be used for the riteweave for the first layer...then spackle and thinned goop for a final layer as a paintable layer? Kinda as opposed to the old PU skim coat?
BpPilot is offline Find More Posts by BpPilot
Old Dec 04, 2012, 07:42 PM
Victim of C.D.O.
murdnunoc's Avatar
Joined Oct 2007
I would only use the thinned Goop and filler underneath the lam film to give it a smooth surface to stick to.
I think Svede is using the thinned Goop in place of lam film, and says it's stronger than lam.
For glassing with weave, I think it'll be tough to beat 3M-90. You don't get much more aggresive than that stuff. Plus, the 90 is fast and easy. And you'll tear chunks of foam out before the weave delaminates from the foam.
Old Dec 04, 2012, 08:13 PM
BpPilot is offline
Molon Labe
BpPilot's Avatar
Joined Feb 2008
So how does this sound:
Install all electronics, then fill any big holes/ruts with spacke.
Apply weave with the 3M 90.
Then do the thinned goop and spackle for a smooth layer for paint and lam.
Old Dec 04, 2012, 10:56 PM
Svede is offline
Joined Nov 2008
Overkill to do thinned GOOP/spackle over 3M90'd weave, laminate goes on extremely well over it. Just do the thinned GOOP/spacke over bare foam if there is any, otherwise I'd say it's not needed.
Old Dec 04, 2012, 11:00 PM
Svede is offline
Joined Nov 2008
Kevlar applied with thinned GOOP is stronger then lam, not thinned GOOP alone.
Old Dec 05, 2012, 01:27 AM
BpPilot is offline
Molon Labe
BpPilot's Avatar
Joined Feb 2008
Hm, i thought guys did spackle over the weave to get the surface smoother before lam.
Old Dec 05, 2012, 07:56 AM
Victim of C.D.O.
murdnunoc's Avatar
Joined Oct 2007
Some do, and I have. It gets a clean appearance to spackle/sand before spray paint.
Then after paint, you spray a coat of 90 or Loctite 200 to prime before laminating.
I've found the lam wants to come unstuck, though, when there's spackle under it at any point. The spackle just doesn't bond well to anything. Hence the Goop filler that sticks better to the underlying surface.
I think the thinned Goop/spackle will be best used for a light build without glass. It will level out the bare foam before laminating.
Old Dec 05, 2012, 01:28 PM
BpPilot is offline
Molon Labe
BpPilot's Avatar
Joined Feb 2008
So if I am going to spackle, should I just make sure to get the whole thing covered in locktite 200? As in, no where for the lam to directly touch the spackle?
Or will the spackle still be a problem for the lam?
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Build Log RiteWing 48-FT build thread theclaw Slope 46 Dec 09, 2007 08:53 AM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
