Old Nov 13, 2012, 09:41 PM
Hostage-46 is offline
Find More Posts by Hostage-46
Hit my smoke....
Hostage-46's Avatar
United States, TX, Highland Village
Joined Jan 2003
Dawson what are your throws?
Hostage-46 is offline Find More Posts by Hostage-46
Old Nov 14, 2012, 09:53 AM
dawsonh is offline
Find More Posts by dawsonh
Flagstaff, AZ
dawsonh's Avatar
USA, AZ, Flagstaff
Joined Mar 2003
Hostage-46:
I use three flight phases:
Normal: 10 of elevator up/down and 20 of aileron up/down. This is perfect for general smooth flying, carving big figures and doing rolling maneuvers.
Max: 12 of elevator up/down and 32 of of aileron throw up/down. It gives me maximum roll rates and carving abilities... great maneuverability for close in flying (AKA in-your-face).
Thermal: 8 of elevator, 12 down elevator, 12 of aileron throw, and slight up elevator (reflex). This gives me best "float" for staying in thermals or when "scratching" in low lift conditions.
Dawson
dawsonh is offline Find More Posts by dawsonh
Old Nov 14, 2012, 09:34 PM
Hit my smoke....
Hostage-46's Avatar
Joined Jan 2003
Perfect, thanks...
Old Nov 19, 2012, 07:39 PM
BpPilot is offline
Find More Posts by BpPilot
Molon Labe
BpPilot's Avatar
United States, CA, San Luis Obispo
Joined Feb 2008
Hey is there a Doppler app for iPhone?
BpPilot is offline Find More Posts by BpPilot
Old Nov 19, 2012, 11:55 PM
BpPilot is offline
Molon Labe
BpPilot's Avatar
Joined Feb 2008
Also, for a 6s Rocket 28-56-1900 6x4 build, do I REALLY need 6mm bullet connectors or are 5.5mm bullets ok?
Old Nov 20, 2012, 12:24 AM
murdnunoc is offline
Find More Posts by murdnunoc
Victim of C.D.O.
murdnunoc's Avatar
United States, TX, Lubbock
Joined Oct 2007
5.5mm will be fine if that works out better for your setup or availability. The 1900 on 6S and 6x4 will be pulling around 70A unloaded on healthy batteries, so not enough that smaller connectors will cause a problem.
murdnunoc is offline Find More Posts by murdnunoc
Old Nov 20, 2012, 12:27 AM
Victim of C.D.O.
murdnunoc's Avatar
Joined Oct 2007
RC Speedo.
Awesome little field tool for speed checks. It's as accurate as stand-alone doppler analysis programs, though it misses a pass now and then. But it's good.
Long as you know if you see 135, 138, 131, and 219, there's one pass to throw out
Old Nov 20, 2012, 12:49 AM
BpPilot is offline
Molon Labe
BpPilot's Avatar
Joined Feb 2008
Originally Posted by murdnunoc View Post
RC Speedo.
Ya, you throw out the 131 because it's weak sauce and tell your friends that your recorded a 219 pass!
The reasons for the 5.5mm are that they come on the Zippy batts and I have a bag of ten pairs for the esc and pigtail setup...
Old Nov 25, 2012, 06:07 PM
Victim of C.D.O.
murdnunoc's Avatar
Joined Oct 2007
Been a little quiet on the virtues that gave Ritewings their fame...
SPEED and NOISE!!!!
I've been sitting on my latest Demon 40 for over six months, waiting for weather, schedule and motivation to all line up.
Finally they did this weekend
This Demon runs a 36mm motor. We've very nearly topped out the speeds that can be got on 28mm motors (though I figure Peter M may be holding back a little on his performance numbers )
...So into the 36mm realm of beasts I go!
The new plane can run 9S 4400mah (3 x 3S) as max battery.
Maiden flight was with:
7S 4400mah 65C
Mega 22/30/1.5SE 1707kv
7x5 Sport prop
ICE 100 ESC (soon to be replaced with CK's 160A 9S ESC)
full size HV digi servos. I forget what model.
AR 7000 receiver
2S 600mah Rx pack
The plane is not much heavier than my 16/40/2E powered Demon running 6S 5000mah.
It carves the turns just like a Demon should!
7x5 Sport prop took care of the maiden flight, and the motor was bone cool at 155mph level, no wind.
Ready for some serious speed, I put on the 7x7 without looking at the 7x5 data log. In flight the ESC repeatedly hit overcurrent cutoff no matter how gently I tried to get to full power. But ooh boy the plane was moving!
Looking at the data log, I can see why! The 7x7 prop on 7S pulled 198A and 5000W!! Whoopsie. Good thing it only had to bear it for a half second.
Looks like 7x6 prop will be the ticket on 7S.
Running 6S will let me run 7x8-7x10 props at 30K RPM to run the pitch speed through the roof
I have no reservations now about putting a much larger motor and 9S into the plane. The Demon flies so well, I know it can take the extra pound and still not threaten to fall out of the sky.
Future setup may be...
9S 4400mah
Mega 22/40/2.5SDE at ~1385kv, or
Mega 22/50/2DE around 1450kv
Them some big motors
Old Nov 26, 2012, 03:43 AM
brosius85 is offline
Find More Posts by brosius85
never mind the boll⁣⁣⁣ocks
brosius85's Avatar
Australia, NSW
Joined Dec 2010
mind = blown
this is so insane it's not even funny
brosius85 is offline Find More Posts by brosius85
Old Nov 26, 2012, 06:27 AM
Peter M is offline
Find More Posts by Peter M
Peter M's Avatar
Newcastle, New South Wales, Australia
Joined Sep 2007
Nice work Murdo!
I haven't flown a Demon since July after my so called speedy one couldn't break the necessary 181mph mark. I think 176 was the best it could do so was tossed aside. So disappointed I didn't even bother recording any data.....
I like what you have done with running a 36mm motor, 7 inch props and up to 9 good sized cells.
Keep us posted please!
Peter M is offline Find More Posts by Peter M
Old Nov 26, 2012, 02:25 PM
elliott000 is offline
Find More Posts by elliott000
Canada, BC, Vancouver
Joined Feb 2012
Murdn, would love to see a ground video!
elliott000 is offline Find More Posts by elliott000
Old Nov 26, 2012, 06:47 PM
BpPilot is offline
Molon Labe
BpPilot's Avatar
Joined Feb 2008
Hmm, all this talk of 7-9 cells makes me want to do the same with my D40. Problem is, it's probably the only D40 that i'll ever build and I want to make the best out of it. Up until now, I have been planning it to be a 6s build running the rocket 28-56-1900 on 6x4, 6.5x3.7, or possibly 6x5 with only short runs of WOT.
Now I am seriously considering going at least 7s...
Old Nov 26, 2012, 10:17 PM
Gonzo 1971 is offline
Find More Posts by Gonzo 1971
This is BAT country!
Gonzo 1971's Avatar
United States, MI, Ovid
Joined Nov 2003
So Demons are no longer available?
Gonzo 1971 is offline Find More Posts by Gonzo 1971
Old Nov 26, 2012, 10:36 PM
jpinn is offline
Find More Posts by jpinn
jpinn's Avatar
United States, CA, Poway
Joined Jan 2006
just posted mine for sale in San Diego, not quite finished but a good kit.
http://www.rcgroups.com/forums/showthread.php?t=1778046
jpinn is offline Find More Posts by jpinn
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 09:28 PM
Build Log RiteWing 48-FT build thread theclaw Slope 46 Dec 09, 2007 09:53 AM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 11:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 05:48 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 10:34 PM
