Old Nov 12, 2012, 01:29 AM
Hostage-46 is offline
Find More Posts by Hostage-46
Hit my smoke....
Hostage-46's Avatar
United States, TX, Highland Village
Joined Jan 2003
"...But isn't everyone looking for the best and most predictable performance with no tendency to stall, loop or whatever when you're not giving any stick inputs?... "
An "unstable" sailplane is more nimble and indicates lift better.
There are many long and well written threads on CG. Probably the biggest impact item on sailplane setup is CG.
Most of my flying buddies measure down to the the millimeter. I'll fly my ships, wings and conventional sailplanes at what most power guys would find unstable.
Anyway.... spars are in, covering next weekend
Dan in Dallas
Hostage-46 is offline Find More Posts by Hostage-46
Old Nov 12, 2012, 05:44 AM
PHMX is offline
Find More Posts by PHMX
Never trust laughing dolphins
Joined Feb 2011
Dan in Dallas
Perhaps this is true once you are familiar with the instability, but why complicate things by making it less predictable?
PHMX is offline Find More Posts by PHMX
Old Nov 12, 2012, 10:42 AM
Hit my smoke....
Hostage-46's Avatar
Joined Jan 2003
Start with the recommended CG, fly and move if needed based on preference. Moving the CG fore or aft a few mm at a time is hardly introducing an unpredictable scenario.
Old Nov 12, 2012, 11:13 AM
PHMX is offline
Joined Feb 2011
I think even the slighest non-neglegible deviation from where CG should be will be very noticable though. Having flown countless of planes, helicopters and what not, a bad CG always resulted in unwanted drift or control issues.
Old Nov 12, 2012, 12:53 PM
DoctorAudio is offline
Find More Posts by DoctorAudio
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
A nose heavy plane flies poorly!
I tail heavy plane flies poorly once!
DoctorAudio is offline Find More Posts by DoctorAudio
Old Nov 12, 2012, 06:48 PM
BpPilot is offline
Find More Posts by BpPilot
Molon Labe
BpPilot's Avatar
United States, CA, San Luis Obispo
Joined Feb 2008
Originally Posted by doctoraudio View Post
a nose heavy plane flies poorly!
^like^
BpPilot is offline Find More Posts by BpPilot
Old Nov 12, 2012, 08:49 PM
Hit my smoke....
Hostage-46's Avatar
Joined Jan 2003
Man I didn't mean to start a rant on CG....
Every airplane, model or full scale, has a RANGE of an acceptable CG. I'm not suggesting you fly beyond that range. On my Supra for instance, the recommended CG is 4". Turns out I like that an fly it regardless of conditions. Others will alter the CG, again by a very small amount 1/16 to 1/8 of an inch. Go forward and the ship is slightly more stable, suitable for gusty conditions. Move it aft as far and the airplane becomes very responsive to lift, such that the pilot can spot and maintain lift better at that CG compared to a more forward CG. Granted it is a higher workload on the pilot, however there is a benefit.
Old Nov 12, 2012, 11:04 PM
murdnunoc is offline
Find More Posts by murdnunoc
Victim of C.D.O.
murdnunoc's Avatar
United States, TX, Lubbock
Joined Oct 2007
Hostage, you didn't start anything.
You're right that there is a range, not just one specific location for CG.
The "BEST" location will, like all design features that affect performance of the plane, be the one that best meets the plane's intended flight characteristics.
A CG that is toward the rear of the controllable range will bring a plane that's more responsive. A must have for aerobatic planes. They need to be able to stall violently.
Aft CG also gives more efficient flight. More lift for less induced drag.
A pilot that's experienced can take advantage of the aft CG.
So your gliders do better with it at the aft end of the CG range.
Forward CG gives more stability at the expense of maneuverability. Too far forward means too stable. Read, can't move the nose...
I think you know all this. Good for a refresher for some, though.
PHMX,
Not sure how you figure a change in CG will make the plane constantly climb or dive. It can be trimmed for straight and level hands off with even a very forward or aft CG.
CG location determines how the plane departs or returns to stable flight when control input is given.
Does your radio have trims?
murdnunoc is offline Find More Posts by murdnunoc
Old Nov 13, 2012, 12:25 AM
PHMX is offline
Joined Feb 2011
PHMX,
Using trims to compensate a bad CG is pure madness. If the CG is correct you do not need trims. Sure one could trim in wind, but that always backfires if you're flying circuits. The only reason one would prefer a slightly nose heavy plane is when the design allows for that, possibly making it more capable dealing with wind. And yes a bad cg totally influences flight behavior. It makes for an inefficient plane, regardless of full scale or RC.
Old Nov 13, 2012, 05:44 AM
brosius85 is offline
Find More Posts by brosius85
never mind the boll⁣⁣⁣ocks
brosius85's Avatar
Australia, NSW
Joined Dec 2010
mate do you even fly wings at all???
read murd's post again please...
brosius85 is offline Find More Posts by brosius85
Old Nov 13, 2012, 07:34 AM
Victim of C.D.O.
murdnunoc's Avatar
Joined Oct 2007
Or fly anything at all?
Old Nov 13, 2012, 06:19 PM
Hit my smoke....
Hostage-46's Avatar
Joined Jan 2003
Thank you gents.
Old Nov 13, 2012, 06:52 PM
dawsonh is offline
Find More Posts by dawsonh
Flagstaff, AZ
dawsonh's Avatar
USA, AZ, Flagstaff
Joined Mar 2003
Hostage-46:
I have flow a bunch of CK's wings... all on the slope. My current TL50 is flying with at CG at 8 3/8" back from the nose. Very stable and just very slightly nose heavy. These are wonderful slope wings. I like them for their aerobatic abilities. They fly as well inverted as upright. I fly them at 19 ounces to 27+ ounces.
My RiteWing slope videos are here: http://vimeo.com/album/1176623
Have fun!
Dawson
dawsonh is offline Find More Posts by dawsonh
Old Nov 13, 2012, 07:15 PM
Hit my smoke....
Hostage-46's Avatar
Joined Jan 2003
Excellent ! Just what I needed
Old Nov 13, 2012, 08:14 PM
Hance is offline
Find More Posts by Hance
Expo is built into my thumbs
Hance's Avatar
USA, ID, Niter
Joined Jul 2008
I just finished up the glass this morning on a TL50 that CK cut me last spring. Mine was getting pretty beat up after it went in knife edge, full throttle because of a lockout. Me doing 2.5 rolls and yanking full elevator ten feet off the deck at full speed didn't help matters.
The TL50 is my all time favorite ritewing.
Hance is offline Find More Posts by Hance
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Build Log RiteWing 48-FT build thread theclaw Slope 46 Dec 09, 2007 08:53 AM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
