Old Nov 03, 2012, 03:05 PM
KevInTheSky is offline
Find More Posts by KevInTheSky
Joined Jan 2012
Hi,
There's so many posts to read, so i'll just ask....
I'm building a z2 now. Will fpv equip it.
I already have the ritewing powerset.
Im wondering if i am to go for 3s or 4s setup.
Im also wondering what prop to use.
I am no speed freak, but i want enough power to launch it without shitting my pants every time.
What i want more than all is long flight times.
I have read something about geared motors for really long flight-times?
I will be happy to buy a new power-system if someone can recomend what to get for long-hauls.
I also appreciate recomendations regarding 3s or 4s on the ritewing motor, and props to go with it.
kevin
KevInTheSky is offline Find More Posts by KevInTheSky
Old Nov 03, 2012, 04:11 PM
DoctorAudio is offline
Find More Posts by DoctorAudio
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
For a geared setup, I would look at motors in this size!
36 - 40mm 3000 KV for 4S setup maybe a little lower.
Or 3S A KV of 4000KV.
I have run a bunch of geared setup.
Himax has a 36mm motor with 3300-3600kv, that is a beast!
But I am sure you could do it for a lot cheaper!
I think I ran a 11" prop with that motor and a 2.31:1 ratio!
DoctorAudio is offline Find More Posts by DoctorAudio
Old Nov 03, 2012, 06:53 PM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
My setup is great, it very efficient and reliable.
I have tested numerous geared setups to find no real answer to meet all the requirements.
Gear boxes are not reliable if they are cheap, and they are still questionable even if they are the high dollar versions .
We have seen very low loiter and cruising speed amp draw with my outrunners.
The last thing you want is a worn gearbox failing on you when you are miles from home.
klique is offline Find More Posts by klique
Old Nov 04, 2012, 01:24 AM
brosius85 is offline
Find More Posts by brosius85
never mind the boll⁣⁣⁣ocks
brosius85's Avatar
Australia, NSW
Joined Dec 2010
kevin- if you have the ritwing motor and esc then go for 4s and a 10x5, it wil have about 1000w. it will be easy to launch and do about 100mph
you need a seperate RX battery or UBEC if running 4s.
if you want even more thrust with less speed go for 3s and an 11x5, but that makes the prop more likely to cut your hand (because its that much bigger)
brosius85 is offline Find More Posts by brosius85
Old Nov 04, 2012, 01:25 AM
Juninou is offline
Find More Posts by Juninou
United States, TX, Allen
Joined Aug 2012
Originally Posted by DoctorAudio View Post
Was you In tigard?
Near Cook Park?
There is only 4 substations in this area in an open area!
It is pretty close!
I am not 100 % but Give me a west or east I it can only be one of those!
North West!
Huge sport wear company..., ring any bells?
Juninou is offline Find More Posts by Juninou
Old Nov 04, 2012, 05:25 PM
Milwaukie , Oregon
Joined Feb 2003
haha i was way off.
I am going flying in 20 mins
Old Nov 10, 2012, 06:02 AM
Hostage-46 is offline
Find More Posts by Hostage-46
Hit my smoke....
Hostage-46's Avatar
United States, TX, Highland Village
Joined Jan 2003
TL 50 Sloper
Hey Guys,
I'm finally getting around to building the two TL 50's Chris cut for me last year.
These will be very light slope/combat ships.
what's a good CG for a slope version TL 50?
Hostage-46 is offline Find More Posts by Hostage-46
Old Nov 10, 2012, 04:00 PM
brosius85's Avatar
Australia, NSW
Joined Dec 2010
page 1 of this thread indicates 8" from the nose for CG of the 50" cg does not change weather powered or not, unless i am missing something...
your own preference may change how you like the cg
Old Nov 10, 2012, 05:11 PM
elliott000 is offline
Find More Posts by elliott000
Canada, BC, Vancouver
Joined Feb 2012
ridiculous lol I cant wait anymore to fly this damn thing.... Cmon denmark post and get my tx in for repair
elliott000 is offline Find More Posts by elliott000
Old Nov 10, 2012, 05:29 PM
Hit my smoke....
Hostage-46's Avatar
Joined Jan 2003
Thanks, glider guiders typically fly a further aft CG, good place to start....
Old Nov 11, 2012, 10:47 AM
klique is offline
Mum is the word!
Joined Jun 2003
Not usually on flying wings.
Old Nov 11, 2012, 12:31 PM
Hit my smoke....
Hostage-46's Avatar
Joined Jan 2003
Thanks guys... good to go
Old Nov 11, 2012, 03:01 PM
PHMX is offline
Find More Posts by PHMX
Never trust laughing dolphins
Joined Feb 2011
I beg to differ, getting the correct CG has extremely little to do with preference.
If you want a plane to have a downward or upward tendency all by itself, for whatever reason, it's clearly much better to just dial in some trims.
But isn't everyone looking for the best and most predictable performance with no tendency to stall, loop or whatever when you're not giving any stick inputs?
Yes, some gliders fly better with some nose weight, but that's mainly to deal with stronger winds and the fact that they should maintain speed when they're not using a motor. In many cases the actual CG does not really change or it will also start to misbehave and do all kinds of unwanted stall moves.
Anyhow, enough of me being a wisecrack about it, but ESPECIALLY with wings, the center of gravity should be spot on exactly where it is designed to be.
PHMX is offline Find More Posts by PHMX
Old Nov 11, 2012, 04:08 PM
brosius85's Avatar
Australia, NSW
Joined Dec 2010
i prefer a nose heavy CG. sue me.it may not be "correct", but it flies nicer to my tastes
Old Nov 12, 2012, 12:53 AM
PHMX is offline
Joined Feb 2011
I understand, but having a bad CG can make for an inefficient and less controllable plane. I would understand if you'd simply use trims though. Then again in strong wind, nose weight might be preferrable.
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Build Log RiteWing 48-FT build thread theclaw Slope 46 Dec 09, 2007 08:53 AM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
